Its running a pfc, and while it was tuned atleast three years back, it hasnt had any probs.
Im thinking ill have a play with some wiring and see if it changes idle at all... Just wish i had more time to play cars...
Yep, front of the head, sticks out about 50-70mm and has a red/black plug on it
Pull that out and see if it either fixes the problem, or makes the problem constant. If so then not so bad news, might just need a new VCT Solenoid/Switch (this thing your unplugging) or a minor re-tune just to touch up the VCT issue. Perhaps a mix of both
Start the car. Take a screw driver and put the metal tip against the injector. Put your ear to the end of the handle. You can hear the injector clicking, it's working. Go thru all 6 and learn what to listen for. This is the first step of diagnosing a bad injector. Step two is ohm resistance. With the motor off, unplug the wire clip to suspected faulty injector. Use a multi-meter to read ohms. You're looking for anything that is not in the 14 ohm area plus or minus 1.5 ohms. You'll use both prongs of the multi-reader and touch each of the injector electrical prongs. Polarity won't matter. This will tell you if the electrical coil is bad inside. Unfortunately they cannot be rebuilt and the whole injector will needed to be replaced. If replacing a single injector, it's wise to remove the rest and having them professionally cleaned and flow matched to the new one.
If you have side feed injectors (i.e. stock or aftermarket), yes they will be high impedance. If you have top feed injectors, you could be running lows. You can only run lows using an aftermarket computer. Stock ECU only runs high impedance. post-116132-14045372547201_thumb.jpg
These are Nismo 550cc side feed at high impedance.
These are aftermarket top feed that can be high or low impedance depending on your personal engine build goals. Easy to spot. The stock side feeds are purple in color if I remember right.
Here is a website that can help you more with specs:
http://webbersrbguide.com/index.php?option=com_content&view=article&id=64:skline-rb-standard-injectors&catid=45:wiring-electrical-a-ecu&Itemid=23
  • Like 1
Yep ive done the screw driver listen and also the swap, injectors are fine it seems so its electrical or vct, ill check it out further and find an answer...
Thanks for all your input it is much appreciated, just wish i could dedicate more time to it...
If you have side feed injectors (i.e. stock or aftermarket), yes they will be high impedance. If you have top feed injectors, you could be running lows. You can only run lows using an aftermarket computer. Stock ECU only runs high impedance. attachicon.gifImageUploadedBySAU Community1404537253.775014.jpg
Thanks for the link mate, very helpful :)
Ok im still trying to sus this out, ive tried unplugging injectors one at a time and all make a slight difference to how it runs, ive changed spark plugs, removed coil plugs ones at a time each makes a difference to how it runs...
I havnt had a mechanic do anything on my car other than tune or fab work for years, normally do everything myself, but i may have to bite the bullet cause this has stumped me... Silly cause i feel i caused it.
Could an electrical issue cause by moving old heat and weather affected wiring harness...
It could be, but the filter isnt that old, and it was running fine before painting some parts...
But now that youve said that perhaps i should change it just to be sure...
Put a mesh 40 micron on there, all the blocked ones I have seen lately have been Ryco style paper ones. Never had an issue with stainless mesh filters.
It could be worth checking the contacts on your ECU plug. I had a similar issue with one injector not firing and it turned out to have a bad connection for that injector on the ECU plug.
I closed the female connection a little, plugged it back in and the problem hasn't resurfaced.
    • Just trying to get my head around this. At 5psi of boost, you turn on your wmi pump, and then you're using a 3000cc injector, to allow flow upto the actual engine, where you have your 6x200cc injectors and a 500cc injector. If the above is correct, what advantage are you obtaining by having the 3000cc injector blocking flow, is this just incase a line breaks between that injector and the motor you can stop flow immediately? Or are the 6x200cc and 500cc less injectors and just spray nozzle?
    • Welcome! New member myself, but I had an R33 back in 2002. Best advice I could give, based on my experience: if you're running the factory turbo, be very conservative with boost. I made the mistake of just fiddling around with the boost controller and cranking the boost for fun, and the end result was my intake pipes popping off frequently from the constant deluge of oil that was being blown into the recirc by the stressed-out turbo, which itself was siphoning oil from the engine and farting it out both sides of its centre bearing (or something to that effect). If I could do it all again, I would have gotten a new turbo and had a tune dialled in professionally and then just left it alone! Funny you mention the metal shavings in the gearbox, as I had the same thing - the probe plug (magnetic drain plug, essentially) would come out caked with shavings. At least it was doing its job. Not sure if that's just sacrificial wear and part of the deal, or if my gearbox was shagged, but I wasn't abusing it. Enjoy the R33 - they're a dying breed, and if they weren't $35k+ on CarSales in Queensland, I might have picked up one of those again, instead of the 370GT I own now (though I'm loving the 370GT, that big 3.7L V6 just hits different).
    • Howdy folks. I owned an R33 back in 2002, which was thoroughly beyond my capacity (financially speaking) to maintain/insure, so we parted ways in 2004. Fast forward 21 years (to literally yesterday, in fact) and I'm now the proud owner of a 2007 V36 370GT. I'm happily surprised by how much power the VQ37VHR makes, compared to the RB25DET, considering the latter is turbocharged. I had planned to add a turbo at some point but I'm on the fence about whether I'll even need it (though I do love the sudden onset of extra torque). Any other 370GT owners around the traps, I'd love to hear about your experiences with this car (good and bad).
    • Perhaps the answer is... more jacks!* *proper jacks must be used.
    • I NEVER think about using a scissor jack unless there is absolutely no other alternative. f**king things are dangerous, annoying and stupid.
