As the topic would suggest, I have a set of Xspurt/Bosch/EV14/id1000 injectors for sale.
The only difference between the above is who seems to sell them. They're all the same injectors. These ones are Xspurts, which are sold locally in AU, and are flow matched and such. (they're what scotty sells, exactly what he sells, because that's where I got them)
I used these for about 5000kms without issue. I only replaced them because I THOUGHT they ran out of flow, but it turns out it was a bad fuel filter. (really.)
I'm looking for $500 for the set of 6. I can negotiate within reason.
These are the 3/4, 14mm length style, so they'll fit in a variety of different cars. How to fit id1000's into XYZ will yield you info on whatever you want to put them in to!
Please send a PM on forums, I reply to these super quick.
I'm in VIC - Can deliver them if you want, otherwise can post them if you're happy to have them posted out.
Greg
https://www.sau.com.au/forums/topic/445440-xspurt-bosch-ev14-1000cc-injectors/
Bigger is always better with Injectors Mr Platts.
Why wouldn't you want 450FWKW in the Micra?
Why not use them on half duty cycle? How lovely that would be. Longevity and shit!
$400 now, plus postage if you aren't in VIC (I'll bring them to you if you are)
Note: These do not have plugs. Pm scotty nm35 for some (about $60).
No plugs because these can go into a variety of different engines, all of which require different plugs. ;)
^^ That is for adapter plugs. I can do crimp on plugs for half that.
If anyone wants these but are worried about them being used, I can flow test them for a minimal charge. Removed due to upgrade by myself. ;)
  • 1 month later...
Hi mate are these still for sale? What were you running them in? Im pretty interested in them for my R34 gtt.
No, I converted them for RB26 use and Greg sold them. I can help with new ones if you need a set. ;)
He was running them in his Neo, 34 4 door.
    • You know what, I am enjoying your updates, but I have to say it is pretty poor form to walk into a shop that is paying for space and stock on the floor, try all their seats to work out what you are happy with, then buy somewhere else. If everyone did that the shop will be out of business with no opportunity for anyone to try a seat before buying. 👎
    • Good work, and thanks for posting up your solution for future people!
    • Yeah mate that’s the plan, I just want something I can have fun in and work on during weekends.  There’s really only 1 road fit to drive the car on and luckily is been redone recently.  I do want to tune it next year sometime, no dynos here so I’m looking at an ECU that can be remote tuned.
    • Initially I thought having a pair of Recaro seats would be a big bonus, it turns out these do get a little uncomfortable on long journeys (my fault, not the seat). I had a look through the GSM Performance website at reclining seats and booked an appointment to visit their show room. I got the Recaro Sportster CS for the R34 from here, was very happy with the service received so of course a re-visit was in order. Unfortunately the two Corbeau seats I had chosen aren't on display but they had 4 other options available. Two seats dug into my back, one dug into my legs and the other was perfect. I also found out that Recaro seats use a larger bolt pattern so some adaption was required. Luckily GSM offer some universal adaptors that should solve this problem. I searched the interwebs for price comparisons and Corbeau themselves were the cheapest at £300 cheaper (for the pair). I asked GSM if they could price match, unfortunately they couldn't. I later received an email saying Corbeau would honour them the same discount, but the purchase was already made. I did however order the brackets from GSM, both arrived on the same day. I started with the passenger side seat, knowing this was going to be a little trial and error. There are 3 mounting holes at the front and 2 at the rear on these JURAN Racing seat rails.  With the adaptor brackets mounted, the allen cap bolts started to push into the seat, NOT GOOD!  The rear mounting holes lined up but there were issues at the front. The holes were 1/2 hole out, so the brackets got a tickle with the drill to modify the holes. The supplied bolts weren't going to be long enough and a spacer was needed to stop the adaptor bars from bending. A local fasteners company supplied be with some nylon spacers and longer bolts (M8x30, although these will be replaced with 35mm long shortly) A before and after I pre-drilled the front bracket before making a start on the driver's seat to save some time. And in no time at all that was in the car too. The all black seats have transformed the interior and these are MUCH more comfortable. The only downside with the new Corbeau seats is I sit a little higher, but I'll happily accept that over discomfort. The Youtube video can be found here: https://www.youtube.com/watch?v=wPyttKPktXA
