It is with much peer pressure that I create this build thread. More to give everyone an opportunity to hassle me if I'm taking too long on certain items. I was reading a couple of threads just now and got really motivated to lock some things down and make a start on this sexyass car!
So here is is
1984 DR30
I imported this earlier in the year through Iron Chef imports after only a month of looking. It's clear that it's been sitting dormant for a seriously long period of time, but most importantly, the body is pretty straight (and fairly rust free (the fuel tank is a different story)) so I knew i could work with that no matter what happens.
It's fairly standard, except for the rs8's, front and rear strut braces, old school recaro's... that's all I can remember at this point. Between Feb and now i really haven't done anything except clean the injectors, oil change, change all filters etc and as far as doing much else, I really don't have the time or motivation to be doing these things so I've enlisted some help from some friends.
I bought it for track but still want to make it streetable, my last car I feel i went too far the track way and couldn't enjoy it on the street.
What's next? Here is a list of things that are getting done immediately (hopefully that will be finished by end of next week.)
- AFM is broken, have a new one on the way
- All fuel hoses are disintergrated so they are all getting replaced
- Petrol tank is getting cleaned out, resealed and probably relined
- Fuel float needs replacing
- New Walbro fuel pump will go on
I also have the following things on order or ready to go on.
- S13 hubs and knuckles so I can run the s13 coilovers, they have arrived.
- I bought this kit http://www.brysport.com/shop.html because using the s13 coilovers isn't without it's dramas... the back doesn't fit directly but this kid converts the two bolt strut top to three and also allows the car the standard amount of travel as the s13 coilover even at full extension does not allow for the standard DR30 height. Then up front, there is a tie rod end to dial out the bump steer issues. For the price and the issues involved, I'm pretty keen to try it out! It was designed by a forum member clubracer. Just waiting for him to finalise the package as it's a new product.
- MCA Red Series coilovers - I'm taking advantage of the group buy, just need to let them know what springs to use.
Once I have these three things delivered, a forum member will be working with me to set up the car properly as it's going to be a pig to handle and out of things that are not my forte, suspension is the worst of them!
https://www.sau.com.au/forums/topic/445479-dirty30/
Sorry kids!
I always was cooler than you, troy!
thanks guys! MCA have kindly agreed to reverse the fittings in the camber tops to they fit perfectly without losing the adjustability so I'm pretty stoked with that, the coilovers are base height adjustable too. I just need to send them a standard strut top thingymabob to do this
Now im just waiting for a replacement fuel tank.. my one was corroded so badly beyond repair!!! Couple more days I expect.
so once the suspension arrives, I can get down to work!
https://www.sau.com.au/forums/topic/445479-dirty30/#findComment-7346586
    • Thanks for doing that Duncan! Makes you a good person in my books. We don't get kangaroos or wombats here. But we have bats and it's similar. AFAIK it's often the mums with a baby attached that get hit because they drop lower when starting from a tree. If you hit an animal, check on it. https://www.ifaw.org/au/resources/wildlife-rescue-app An app to get the closest wildlife rescue contact.
    • My dream is also to have a proper hoist, but I don't think it will ever happen. My quickjack is probably as close as I'll ever get, it really is very good though.
    • Yeah we keep on in the dailies, it is pretty poor how many animals get hit and the driver leaves without checking....have saved a couple of little ones over the years. Bit of a gruesome job though, pouches generally need to be cut open because they are so tight and often the joey doesn't realise mum is gone so they are still locked onto the teat. I checked the modules in front of the DS wheel where an oil cooler should go.... There is the radar unit - that can go for race use) One of the 2 HX water pumps, the silver cylinder. That needs to be kept but might be able to be relocated But the bad news, the big computer mounted vertically in front of the wheel (blocking any potential air exit) is the electric steering computer. That is required until/unless i do a hydraulic steering conversion, and in CAD based modern car design it is not like I can just pop a big unit like that somewhere else (plus the loom would be too short anywhere else too). So, the passenger side is OK to clear out (just use a smaller washer reservoir, potentially elsewhere), but the DS no beuno
    • Well, all the best with the new camry It was interesting to hear about the UK process, it is generally a lot more streamlined here with a shipping agent looking after all the import side (noting the exact final price can still be a surprise.....) and I've used a few different brokers on the japan (or US) side, and never had any trouble with any of them....luck of the draw I guess. You mentioned you didn't get the auction sheet (understandable since you bought it from a dealer, not auction), but I always try and get hold of that because they are pretty thorough. I've imported 2x R grade vehicles over the years and both were fine, repairs in Japan are pretty thorough compared to here in Oz.
    • BTW I measured the jack I have, it is 70mm at the saddle but you only have about 700 until it returns to 150mm high at the cylinder so it is good but no magic bullet.
