Looking forward to seeing all the new cars and improvements!
I think the other classes are going to be just as interesting to watch this year (a little bit easier to relate to with all the wild aero modifications going on in pro). Managed to catch up with SAU member John Richardson to see how his preparations for Clubsprint are going and wrote about it on my blog. Have a read and support SAU'ers :) - John Richardson's R33 GTST
  • Like 1
Yep 32 will be there. I'll be even further from the leaders this year as my car is essentially exactly as last year only it's running now!
We all know standing still is going backwards in this game...
33 is on standby.
  • Like 2
It didn't have any of it's aero on so hard to say. Looked like any other GTR from the outside.
I'm sure it will be a totally different beast under the skin though and when the aero is bolted up.
It was parked on a flat bed truck in Powertune's driveway.
I just happened to be driving past at the right time, which led to a reverse gear being selected and another sticky beak. :yes:
  • Like 1
Could have a little problem, like no front right wheel soon..... :angry:
Don't know how this has been missed but I've worn through the nut and arm.
The bolt is showing through on both, only just holding on!!
Found it when taking shocks out for freshen up.
Not sure where to from here just yet. Not like I have a spare arm at home or time to space out the rotor/calipers, machine new hats etc....
Any suggestions ??
Any suggestions ??
Wow no good... What is the cause of that? Wheel bearing? :huh:
Can you elaborate on the "spirit of time attack"?
I thought the idea was to just go fast?
Sorry, I seem to have missed this post.
I believe the spirit of time attack was so that you could actually identify what car it is. And was supposed to be a TUNER event, ie you can purchase everything off the shelf. Now I'm all for going fast, but this current crop of cars (with the exception of a few) are not with that spirit of time attack.
In fact, it is easier to count the cars that ARE rather then not... (All in my opinion - PRO class)
-Tilton Evo 9 (always has been. EVERYTHING they run, you can buy yourself)
-Top Fuel S2K
-Re Amemiya RX7
-Prep'd Motorsports Exige
Nothing else gets close to being in the spirit of time attack... Cut up front ends... Swapping in double A-Arms.... Pushrod suspension.... Is not in the spirit of time attack..... custom one off chassis / wide body is not in the spirit of time attack.
I'm sorry but so many cars just look like complete ass this year.
I think people may interpret the "spirit" differently.
I don't think any guy off the street can go and "buy" the Cyber Evo's undertray/splitter combo off the shelf.
To use your example, look at Tilton's front end. I'm sure you can buy it from them but it's hardly "off the shelf". Same goes for RE Amemiya's RX7, rear mounted cooler, wide body, hektik diffuser.
The concept of being able to "buy" it is loose anyway, you can buy anything with enough money. If you mean off the shelf then a lot of former TA cars are also disqualified from running concept/prototype parts or making one off bits to suit the car - though technically you could still buy those parts with enough coin.
I get what you're saying though, we were used to see stock bodied/lightly body modified cars running great tyres and suspension with huge power, but now people are getting into crazy aero, customising suspension and chassis geometry and the like in the search fo seconds and it's not something the average punter can do - which is why they have specific classes to address this.
Edited by ActionDan
  • Like 2
Any suggestions ??
no idea on how to fix it but ill be checking my ikea shit tonight
i did notice that it was about 8mm from the rotor when i stuck them on which is alot closer than your pick
    • Depending on how long the car sat it is very possible for injectors to be stuck open or closed, I'd get them cleaned and flow tested. Other than that, obviously when the loom changes and the car doesn't start any more....the loom is suspect so some tracing / comparing may be required
    • Harness is for a s1 Rb25det, and it is engine and lower harness.  the old harness had broken off plugs and was in very rough condition/exposed wires and splices etc. it is not able to be put back on the car, I could visually inspect to see if they had rewired any pins on the ecu plug. The fuel pump definitly isn’t turning off it’s an external pump and very loud you can hear it. Will look at the other harness tonight, am also going to pull the fuel rail and watch the injectors spray, will update here with what I find. Pretty sure at this point it has to be something to do with injectors because car will fire up on starting fluid and cas is clicking the Injectors. Fuel pressure is steady 43psi
    • Check the injectors flow evenly, and are actually flowing what you and the ECU think they should be flowing. If it's starting up on starter fluid, you have a fuel issue. Is it possible under cranking your fuel pump is turning off?   The harness you replaced, is that the whole engine harness? Do yourself a test, and drop the old harness on and plug it into the Z32 ECU. It's possible they've wired things different. From memory S1 to S2 is different in RB25 and you may have a wrong loom
    • I haven’t pulled the injectors to watch them spray yet but they are clicking from the cas and all of the spark plugs are wet with fuel. I’ve thought the cylinders were being flooded from the beginning and was hoping fuel pressure would fix it. Tonight I am going to pull the rail and watch the injectors spray. Don’t know how to test/diagnose if the plugs are firing in correct sequence but that should be a timing thing and as far as timing goes my car still has the half moon for the cas can only install it 1 way. And my mechanical timing is 100% correct I posted photos above. Confirmed with the balancer on and off.
