Yeah I know. Ive been looking into suspension lately for my R32 GTR as well.
Im not sure what racepace would charge to modify them.
Ive also spoken to MCA about their gold series. Looking at close to $7000 delivered!!
I have also been looking out for some Nismo Type R, there has been a set for sale for a while on yahoo auctions, probably because the buy price is around $4400.
Or the other option I have been trying to track down is Ohlins Flag R, but cant seem to find them anywhere.
So I would also be interested to see what has to be said here if anyone else has any input.
Oh lines flag R's and the Nismo's are basically the same shock painted in grey and red. They're not very forgiving on the street.
If you want to get the Ohlins new, Greenline do them, well they did last time I looked.
The Racepace modified Teins are awesome. Having been in Nismoid's car when he had them in there, Definately worth considering.
Ill also give racepace a call and see what they recommend with their teins.
I just had a look at Greenline and the Ohlins Flag R are about the same price as the MCA coilovers by the time they get to my doorstep.
  • 2 months later...
Are there any other canister type shocks on the market? Would the MCA shocks require modification like the tein circuit masters?
EDIT: Found these on Yahoo Auctions: http://page.auctions.yahoo.co.jp/jp/auction/171373687
Is that a good price? Can Racepace modify those also?
Can I ask why you want remote reservoir shocks? The quality of the shock valving matters more than a cheaper shock running external reservoirs. Typically with external reservoir shocks you are getting features such as separate high speed, low speed bump and rebound adjustment etc rather than just a single dial to do everything. Its more those sorts of features then simply a bit of extra fluid volume that make them kick ass...provided you have a clue on what your car really needs in teh way of separate bump and rebound adjustment
  • 4 weeks later...
ive also ordered a set of reds for my street car will post results when they get here
I was looking at ordering a set of reds for a 32 GTR also, it's not on their list of available products however?
They have only recently become available i believe.
Street to track were doing a group buy on here not too long ago on blue and red series.
I asked about their gold series, but they declined to offer in the group buy as they are completely custom jobbies.
  • 3 weeks later...
Have just ordered a set of the reds front 10 rear 5 will post back on the results once there fitted. :thumbsup:
Jebuz - who recommended 10 and 5? I would assume that going to be a whole new world of understeer....(assuming you're talking spring rate in kg/mm)
What MCA recommended for a street/ occasional track day set up. No a massive or expensive job to change the springs if i find them too soft but thought i'd just go with what they recommend first and change from there.
Agreed tho are a little unusual spring rates
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
