It is with much regret, that I put my R34 GTR on the market due to relocation overseas. I've owned this beautiful vehicle for just under 2 years, in which time it has put nothing but a smile on my face.
Imported privately through a broker in 2009 on 48,000kms stock standard down to the exhaust, the car was graded 5A at auction before leaving Japanese shores. Documents associated with the de-registration, auction, purchase, importation and Australian compliance of the vehicle are in my possession and will be passed on to the future owner.
Since then, the vehicle has been meticulously maintained and modified with a goal of subtlety. A compression test was carried out 10,000kms ago at C-Red, yielding results of 180,180,180,180,180,175.
All modifications were performed in the last 20,000kms, and purchased brand new either through Nengun or X-Speed. Car currently makes 440HP.
Engine:
K&N Air filters
HKS Type SPL intake and intercooler piping kit
HKS GT2530 x 2 with HKS actuators
HKS 680cc injectors
HKS fuel pump
HKS fuel rail
HKS fuel pressure regulator
Splitfire coil packs
Tomei Poncam Type B Int & Exh camshafts – 260/9.15mm
HKS Duralumin Cam pulleys
HKS timing belt with pulleys and tensioners changed
N1 water pump
Custom Racepace Motorsport oil catch can
Exhaust:
Tomei Expreme exhaust manifolds
HKS extension kit – turbo dump pipes
HKS stainless steel front pipe
Trust Ti-R titanium catback
3.5″ MetalCat catalytic converter
Electronics:
Apexi Power FC D-Jetro
HKS EVC V boost controller
Nismo LED tail lights
Drivetrain and Suspension:
Tein Type RA coilovers
HKS GD Max twin plate clutch
Cusco brake master cylinder stopper
Nismo clutch slave and braided lines
18×10.5 +15 Volk/Rays LMGT4
Toyo R888 Tyres
Project Mu brake pads
Exterior:
Full Z-Tune kit including rear over fenders (Installed <1000kms ago)
Altogether, $102,000 of receipts are present for this vehicle including purchase, import, maintenance and modifications.
I can be contacted on 0466653693 to answer any questions and to arrange viewings for serious buyers.
Photos can be found at: http://www.carsales.com.au/private/details/Nissan-Skyline-1999/SSE-AD-2927666/?Cr=10&sdmvc=1
No swaps, cash only. Car is located in Perth, WA.
Price: $56,000
Thank you.
  • Like 2
https://www.sau.com.au/forums/topic/446038-r34-gtr-v-spec-5a-import/
Open to reasonable offers?
I feel the asking price is more than fair given the condition and quality of the car, so it would have to be a very near offer.
Thank you.
I can vouch for this car, and the owner. Lyndon has cared for this 34 meticulously over the time that he has owned it. It is a perfect example of what a GT-R can be, mechanically and aesthetically, you can't fault this car.
All the best with the sale.
Cheers
It is a wonderful example, kudos for keeping it in that nick and the tasteful mods
lowballing is in bad taste. I'm sure a lot of people price their cars considering current factors and try to get it as close a price as they can. If he priced it at 45k, I wouldn't expect someone to say 40k, or if it was at 40k for someone to say 35k. 56k is at an awesome value.
Edited by RosieR34
Yeah...are you OP? I couldn't give a shit what your perceived value of a car or price is. I respectfully asked a reasonable question of the seller and he gave me a reasonable answer, respectfully...no problems. Nowhere did I state what I intended to offer, so speculate away. Negotiation is part and parcel with selling a car, deal with it.
Asking if he was able to negotiate on an already good price.. Yeah mate, heaps respected question you asked there. I'm sorry you wanted to offer 55.5k instead of the 56k. I bet you're that guy who goes into coles asking for best price on the discounted items, amiright?
You must have missed the part where I don't care what your perception of a good price is. My question didn't appear to offend the seller, but for some reason offends you, someone I'm yet to determine actually has anything to do with the sale? Mind your own business.
  • Like 1
    • What copper washer do you guys use on the bleeder bolts? The existing one I have I had no idea where to find it in a local store, I did buy some online but that are only 1mm thick whereas my old one is 2mm+ thick and when I put the new washer out and squeeze the top radiator hose I can hear a bit of air but not with the old one. Does this matter? The new one doesn't leak, but the inner diameter is a bit loose whereas the old one threads on the bolt.
    • Howdy all, after being out a few weeks ago on a spirited drive in my GTR I have 2 issues that oddly have appeared at the same time. Whilst accelerating quickly through the gears all of a sudden i’ve lost power at the top of third gear (below redline around 6000rpm) for no obvious reason.    From that point onwards the car has been running rich on idle, won’t really rev under load without a ton of black smoke and the odd backfire, and dying as a pull up to a set of lights unless I keep the revs up around 1500rpm. In addition when shutting down the car that same night (I was 10 minutes from home) I noticed one of the turbos was significantly noisy on wind down when shutting off the engine. After letting the car cool down overnight it starts up fine, although once it gets to temp the revs start to creep up and down, the exhaust is darker than it should be and it also sounds like it’s running rich (fat note) I’ve put a new set of plugs in it - no change, the old plugs all seemed OK with two of them being somewhat richer/fueled up than the other 3 with 1 being borderline. I’ve smoked tested the intake system via the front of the Turbos, found a split vacuum hose going to the factory boost gauge sender, which I have since replaced.  Also found another leak on the gasket coming off the rear turbo outlet, have also replaced this. After fixing both of these leaks - still have the running rich issue. I’ve also tried another pair of AFM’s - no change here After pulling off the front turbo intake pipes, there is obvious shaft play in the front turbo, which now hisses loudly on light revvs although I can’t see why this would make the car run funny even under idle. I’m curious to know why it’s running rich before I potentially replace/rebuild turbos. The car is completely stock <50,000kms  other than an exhaust. Oil and coolant are all clear. I haven’t bothered with coil packs as it looks like they won’t be the issue due to condition of the plugs. Any help appreciated as I cry myself to sleep!
    • No probs at all. I used to love trying to dig up obscure info for those in need where possible going back 20+ years on SAU.  I did have another look and couldn't come up with any closer match. I'm leaning towards those skirts in your first pic are custom fitments, cut down/extended or from another car entirely and modded to fit an R34 sedan. I would've thought someone in Japan had them and taken a photo at some stage over the last 2 decades but there's nothing. Someone out there must know surely.
    • Welcome mate. Any pics? Even with a DE I'd be well happy if I had that as a 1st car.
