Power Loss On Downshifts, Bouncing Idle And Slight Hesitation At Specific Rev Point -R34Gtt
Gareth, you have put 300k KMs on your 25, what are you doing laps of Australia or do you live in your car cause dam !!!!
I've owned my car since 2002. when i bought it it had 134,000kms on it. i've still never lifted the head off the motor and i've done all the maintainence myself....most of the problems are with the ancillary parts of the motor failing over time e.g turbo....
If you keep standard internals its well within the realm of possibility.
So you are saying it is possible with a blown 25 to build a 25/30 on the road for that price? Don't think so. Not even close.
My bet is that your highly strung 4G63 will grenade long before my 25 will! Crankwalk anyone? :woot:.. Mick O
Edited by rondofj
Lol care to place money on that Ronaldo? Dunno how its more highly strung? Im running a pound or 2 more boost than your car on Ethanol with a lower comp ratio and probably make similar to a little more power than you.
Its just a better designed more efficient engine than the old RB :)
agreed, RBs are old dinosaur tech
Where did they over engineer it?
Certainly not the oiling system....or the cooling system....or the cylinder head....or the turbo chargers......did I mention the oiling?
Stock engines weren't designed to rev at 8500 rpm for 10 secs bouncing off the limiter at double the intended boost. Do that to most engines and you will kill them.
Edited by XGTRX
Micko Atleast knows where his timing is sitting... Just saying.
  • Like 2
Yes, and I know this because I have done it. Thanks champ.
Same here. Stock bottom end untouched. All up less than 700 including oil etc for everything including retune. Took a whole week working on it a bit after work.
Not what I would call built though, as it's untouched.
But.... I know what I'm doing.... can set timing etc :)
Can't really see the point building one when a 200 buck engine does aso well!
Edited by Ben C34
  • Like 1
Sorry my bad. I assumed that going a 3L you would upgrade the supporting mods, water and oil pump, timing belt, clutch and at least a dyno tune. Obviously not the case, I apologise.
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
