Power Loss On Downshifts, Bouncing Idle And Slight Hesitation At Specific Rev Point -R34Gtt
Sorry my bad. I assumed that going a 3L you would upgrade the supporting mods, water and oil pump, timing belt, clutch and at least a dyno tune. Obviously not the case, I apologise.
You can't do it without a timing belt. Water pumps are cheap as. The rb30 oil pump is fine. Shim the relief valve for free.
And I tuned it on the dyno.
Widebands are the best.
I also thought my car was running rich.
Bought wideband.
Observed AFR.
Changed fuel maps to suit.
Car running correctly.
See also:
Got tune. Cold start was terrible. Idle was terrible (17:1).
Made 30 seconds of changes.
See also:
Car tuned on E85. Corrections for 98 not entirely right (known).
Get E58 or something in tank after tank swap.
Made 15 seconds of changes in correction map.
See also:
Changed injectors from 1000cc to 1400cc.
Car not running correctly.
Made 2 minutes of changes to fuel map.
GET A WIDEBAND
  • Like 2
Doing a RB25/30 conversion for less then $3k can be done IF you can do all of the work yourself and all good and well these guys say you can cause i did it is not a fair statement, you couldn't take you car to someone ( and not a mate ) and get it done for that, no way in hell
It also come to what supporting mods you do and to what level and how properly you do the conversion as we all know there are cheap way to do some stuff which isn't exactly the best way of doing it
So the real question would be can Ron do it for less then $3k done and dusted ?
  • Like 2
Again with the wide band, if tuned properly you shouldn't need one, nice to have but not needed cause really you can only do so much on the street before it should be put on a dyno and tuned properly
^^ This really clever fellow here knows me more than I know myself !!
Yes.
It's based on many things you have posted.
For example.
You specified how exactly you were going to block up your bov return. And did it weirdly anyway.
Someone who knows what they are doing just does stuff.
I do really hope you can get the car sorted out.
22 pages on AFM vs. BOV lol
I reckon, sell Power FC, BOV, AFM - buy Adaptronics, block up BOV port/return dose & bake tyres all day
  • Like 1
So in in Rons case it would go
Nistune, sell
Power fc sell
Adaptronic
Profit?
Edited by Ben C34
flutters is the shit man... you won't look back.. and no more reversion, no more stalling crap, no more dirty AFM, etc.
rip skids & be happy
  • Like 1
True enough for anything over 100kmh with a power run. The 97% of the driving you use a street car for however can be done with a wideband and some tinkering. The power runs is what the dyno is for but that is really only a small fraction of the time (money!) it takes for a tuner to tune the car, but I agree - it's no dyno replacement.
    • For once a good news  It needed to be adjusted by that one nut and it is ok  At least something was easy But thank you very much for help. But a small issue is now(gearbox) that when the car is stationary you can hear "clinking" from gearbox so some of the bearing is 100% not that happy... It goes away once you push clutch so it is 100% gearbox. Just if you know...what that bearing could be? It sounding like "spun bearing" but it is louder.
    • Yeah, that's fine**. But the numbers you came up with are just wrong. Try it for yourself. Put in any voltage from the possible range and see what result you get. You get nonsense. ** When I say "fine", I mean, it's still shit. The very simple linear formula (slope & intercept) is shit for a sensor with a non-linear response. This is the curve, from your data above. Look at the CURVE! It's only really linear between about 30 and 90 °C. And if you used only that range to define a curve, it would be great. But you would go more and more wrong as you went to higher temps. And that is why the slope & intercept found when you use 50 and 150 as the end points is so bad halfway between those points. The real curve is a long way below the linear curve which just zips straight between the end points, like this one. You could probably use the same slope and a lower intercept, to move that straight line down, and spread the error out. But you would 5-10°C off in a lot of places. You'd need to say what temperature range you really wanted to be most right - say, 100 to 130, and plop the line closest to teh real curve in that region, which would make it quite wrong down at the lower temperatures. Let me just say that HPTuners are not being realistic in only allowing for a simple linear curve.
    • I feel I should re-iterate. The above picture is the only option available in the software and the blurb from HP Tuners I quoted earlier is the only way to add data to it and that's the description they offer as to how to figure it out. The only fields available is the blank box after (Input/ ) and the box right before = Output. Those are the only numbers that can be entered.
    • No, your formula is arse backwards. Mine is totally different to yours, and is the one I said was bang on at 50 and 150. I'll put your data into Excel (actually it already is, chart it and fit a linear fit to it, aiming to make it evenly wrong across the whole span. But not now. Other things to do first.
    • God damnit. The only option I actually have in the software is the one that is screenshotted. I am glad that I at least got it right... for those two points. Would it actually change anything if I chose/used 80C and 120C as the two points instead? My brain wants to imagine the formula put into HPtuners would be the same equation, otherwise none of this makes sense to me, unless: 1) The formula you put into VCM Scanner/HPTuners is always linear 2) The two points/input pairs are only arbitrary to choose (as the documentation implies) IF the actual scaling of the sensor is linear. then 3) If the scaling is not linear, the two points you choose matter a great deal, because the formula will draw a line between those two points only.
