R33's have a double latched setup from factory... you could pull the bonnet release cable at 200kph and it wouldn't fly open...
Of course you're more than welcome to make your own additional restraint with a carrabeana and a loop of wire to secure it further.
Edit: I would be running the additional if I had an aftermarket bonnet, carbon fibre, bracing removed, or something like that which could allow the bonnet to flex more than normal
Well bugger me... I come back after a day and have to cater for a few more!
BBQ for Members:
Tony +1
John P
Simon
Anna & Luke
Paul S
Michael +1
Jamie
Owen
Dave
Allan
Matt L
Snowy
Gorjan
Chris T
Richo
Pete
Jamie L
Jamie G +1
Lebo Luke
Mark
Matt B
dan.1337
Total - 26 people
Is there ANYONE else??? Given it's a pretty hefty increase in numbers already
  • Like 1
Hi guys, I have been reading the supp regs and the cams manual and just want some help with one thing.
Do I need to run an extra bonnet restraint cable or is the factory latch ok??
Cheers
Luke
You should be ok, a long as it has the two methods of fastening.
They can be a bit picky on after market bonnets though.
Not required. Just eat and be merry.
Squires Loft Nunawading is supplying the food at cost and cooking/extras for free. In return SAU-Vic picks up the raw food bill on members behalf as it's a Members Only BBQ - one of the many member perks!
Great too see so many faces around.
Yes I did try and remove the speed limiter from the Evo. Only to have the battery go flat...
The speed limiter is gone now and car working fine. (Frkn Evo's)
Thanks too Squires for the food, amazing as always.
Not sure what others thoughts were, but this day ran better than previous days of late.
Bearing in mind a wrx dumped oil and some chev driver painted the armco.
There is a discussion in the champ thread about the 30th of August at Winton. Get in there and have ur say.
Obviously gutted for members with day ending issues
But yeah, excellent day, started to run so quickly at the end that my car couldn't take it anymore and I believe quite a few were setting PBs etc, big crowd, excellent food - missus complaining I'm getting fed to well, what diet :-)
Was a much better day, even if i didn't make full use of it. Some minor attention this week and I'll be sorted. :)
100 cars, awesome. 120+ cars, shithouse.
Day was run perfectly compared to the other 4 rounds so far this year, which the oversubscribed side was pretty much the cause.
Let's hope it continues!
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
