#@scotty nm35
I had the diff seals leak in my car, general wear and tear.
Usual problems generally happen to the AYC, they start whining due to improper servicing or wrong oil used. AYC needs to be serviced/flushed every 20,000ks as per mitsubishi. The AYC is part of the rear diff, both requiring their own set of oils. Keep an eye on the reservoir from time to time.
https://www.sau.com.au/forums/topic/446394-wtb-parts-car/#findComment-7359874
oil-evo-4-10.pdf
Use the attachment as a guide and you'll be fine. Shouldn't have whine problems :)
In my opinion the transfer case is what takes the most load, considering that its a FWD setup AWD, unlike the GTRs and STIs. So i would just keep the rear diff the way it is, service as and when due and it should be fine.
Edited by Deza3000
https://www.sau.com.au/forums/topic/446394-wtb-parts-car/#findComment-7359881
WTB, evo 7/8/9 super-AYC diff in good condition.
Only the evo 8/9 had super AYC, evo 7 has the standard AYC, You could get it straight from mitsubishi dealer, they distribute evo 8 9 and 10 spare parts from body kits to turbos, might cost ya an arm and a leg though haha.
Edited by Deza3000
https://www.sau.com.au/forums/topic/446394-wtb-parts-car/#findComment-7359886
    • This looks great! Awesome to have the 5 speed with an LSD in this. The Recaro's look like SR2's or SR3's. It's a shame they've been retrimmed as they would have looked sweet in their original colours. I think I'd want my agent to be a little more up front and informative too. I've never imported but I reckon it would make me a little nervous, so the more info the better.
    • Thanks for doing that Duncan! Makes you a good person in my books. We don't get kangaroos or wombats here. But we have bats and it's similar. AFAIK it's often the mums with a baby attached that get hit because they drop lower when starting from a tree. If you hit an animal, check on it. https://www.ifaw.org/au/resources/wildlife-rescue-app An app to get the closest wildlife rescue contact.
    • My dream is also to have a proper hoist, but I don't think it will ever happen. My quickjack is probably as close as I'll ever get, it really is very good though.
    • Yeah we keep on in the dailies, it is pretty poor how many animals get hit and the driver leaves without checking....have saved a couple of little ones over the years. Bit of a gruesome job though, pouches generally need to be cut open because they are so tight and often the joey doesn't realise mum is gone so they are still locked onto the teat. I checked the modules in front of the DS wheel where an oil cooler should go.... There is the radar unit - that can go for race use) One of the 2 HX water pumps, the silver cylinder. That needs to be kept but might be able to be relocated But the bad news, the big computer mounted vertically in front of the wheel (blocking any potential air exit) is the electric steering computer. That is required until/unless i do a hydraulic steering conversion, and in CAD based modern car design it is not like I can just pop a big unit like that somewhere else (plus the loom would be too short anywhere else too). So, the passenger side is OK to clear out (just use a smaller washer reservoir, potentially elsewhere), but the DS no beuno
    • Well, all the best with the new camry It was interesting to hear about the UK process, it is generally a lot more streamlined here with a shipping agent looking after all the import side (noting the exact final price can still be a surprise.....) and I've used a few different brokers on the japan (or US) side, and never had any trouble with any of them....luck of the draw I guess. You mentioned you didn't get the auction sheet (understandable since you bought it from a dealer, not auction), but I always try and get hold of that because they are pretty thorough. I've imported 2x R grade vehicles over the years and both were fine, repairs in Japan are pretty thorough compared to here in Oz.
