Within a fully secure underground complex car park some prick has used what looks like a pick and hammer to try bust my lock out or a screwdriver. They never got into my car but the lock is completely totally destroyed.
I have an alarm, immobiliser and steering wheel lock that is always in a hard-lock position when parked.
Is there any way i can just replace the key hole with a metal plate or replace with a keyless entry door handle? This is the 3rd time - 1st in Newcastle, 2nd in Brisbane, 3rd now in Melbourne someone has tried to break the key/lock to get into my car..
Anyone got suggestions? Otherwise im over this car im selling it next week..
Unless it was your own personal lock up garage that only you have the remote/key for, I wouldn't assume it's "fully secure"... even if you had your own garage, nothing is ever secure. Anyone who can gain entry to the basement car park can physically get to your car.
R33 yeah.
Since i have alarm, immobiliser and steering lock fitted ive just removed the barrel key lock from the handle, covered it with a metal plate, painted it same colour as car. Only way they can get in now is smashing window or stealing my keys..
Hate these maggots.
Just FYI you don't need to smash the window to get into an R33. The windows have enough flex in them to pry away and get a coat hanger in there to flick the lock.
It's how my previous 33 was stolen, and also how RACV get in when keys are locked inside.
Passenger door?
disconnceted the locks on passenger door now too - its fully keyless entry.
f**ked if my battery goes flat, but at least less a chance of these maggots stealing my car.. i hope.
  • Like 1
haha fyi the r33 door unlock trick was covered about 9 yeas ago from memory
there was a how-to thread on how to disable it as well in the tutorial section, very old news
  • Like 2
What is the trick? just jam a screwdriver in and turn it?
So they had another go last night, now passenger door lock is ruined, drivers side door lock even more so than last week and now they jimmied the window scratching the f**k outta my window and ripping the rubber seals to pieces...
AGAIN didnt get in.. There goes about $500 replacing the seals and locks. :(
Getting really tired if your shit junky thieves.
wow.... that's no longer opportunistic dude, that's targeted at your car... I would either sell it or move it to a new location. Does your 'secure' carpark have CCTV? Have they audited the swipe access at all entry and egress points?
^^^ Good one mate now it's everyone's information. Hell of a lot of captains about to set sail!!
Old news. You can sometimes tell if an R33 has been broken into because the metal/trim above the window is creased from being pried open.
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
    • My wild guess is that you have popped off an intake pipe....check all of the hoses between the turbo and the throttle for splits or loose clamps.
    • Awesome, thanks for sharing!
    • To provide more specific help, more information is needed. What Android screen? What is its wiring diagram? Does the car's wiring have power at any required BAT and ACC wires, and is the loom's earth good?
    • So, now all you need to do is connect the 2 or 3x 12v feeds into the unit to permanent 12v, ACC 12V and IGN 12V that you can find in the spot behind the stereo, and the earth, and then it will switch on with the car.
