Cheer and if anyone has the above mentioned bits for sale in SA let us know Cheers!
RB20 (R32?) Actuator - http://www.gumtree.com.au/s-ad/salisbury-north/engine-engine-parts-transmission/r32-r33-rb20-rb25-parts/1053295328
Not mine, no idea who it is, don't know if it is the right one, 2 minutes searching....
Edit - another one - http://www.gumtree.com.au/s-ad/kidman-park/other-parts-accessories/nissan-parts-r32-s13-s15-skyline-silvia-180sx/1049901329
And a Z32 ECU - http://www.gumtree.com.au/s-ad/para-hills/other-parts-accessories/parts-300zx-z32-tt-manual-2-seater-ecu-black-carpet-interior-/1054098498
Edited by GeeDog
https://www.sau.com.au/forums/topic/446752-r33-s2/page/2/#findComment-7365622
SO let me get this straight
this
Z32 (300ZX) or R32 ECU plus a Nistune daughter board - this will allow a tuner to modify the factory tune
R32 Wastegate actuator (10 psi vs 5psi stock)
or an aftermarket ecu like the power fc at this stage seems like my best bet for a bit more usable power.
https://www.sau.com.au/forums/topic/446752-r33-s2/page/2/#findComment-7365631
this
Also worth noting that a PFC and a commander allows you to monitor and change settings easily. Nistune requires a license and cable as an extra cost. It is another thing to consider before committing one way or the other.
https://www.sau.com.au/forums/topic/446752-r33-s2/page/2/#findComment-7365850
Cheers mate second hand ok for the pfc found one with controller for about 700. Would i still need the r32 actuator as well?
https://www.sau.com.au/forums/topic/446752-r33-s2/page/2/#findComment-7365871
Being able to monitor some settings is pretty handy IMO. There is an extra cost for the cable and license and should be accounted for if choosing Nistune to get this functionality.
I have used both ecu's and both are good so I have no inherent bias for a street car.
You are spot on about people messing things up....but we can only hope we are advising sensible people.
  • Like 1
https://www.sau.com.au/forums/topic/446752-r33-s2/page/2/#findComment-7365920
I've got an R32 Rb20det factory wastegate actuator (10psi).
according to the gauge I had it was actually 0.8Bar which is more like 11.75 psi. Depends slightly on your exhaust and FMIC set up, and where you source boost from for the actuator.
anyway it's sitting in a box doing nothing let me know if you want it
https://www.sau.com.au/forums/topic/446752-r33-s2/page/2/#findComment-7365931
You in adelaide mate? would be keen flick us a message.
I had about 7psi before i put the front mount in and now i get 9psi after the install.
is the z32 ecu good value at $200 second hand? Say if i go to jaustech or morpower can they supply the nisstune board to suit or would i have to source that my self. Looking at $900 for a tune so price wise looking pretty good at the moment. I would like to run 10-12psi once tuned fingers crossed.
Also read through the rb25det dyno sticky and there seems to be a huge variance in power with same mods. Would most put it down to a dud motor or just flogged out.
https://www.sau.com.au/forums/topic/446752-r33-s2/page/2/#findComment-7365946
The Z32 seems good value. You can get Nistune to install the daughterboard for you, as previously posted they are in Adelaide. Have a read of http://www.nistune.com/equipment-products-type2.php - $300 installed
If one of those actuators are still for sale I would grab it - as posted (GTSBoy?) they can be hard to locate as everyone with an RB25Det wants one.
There are cheaper tune options in Adelaide. We went to Graham West & it cost $350 - we got 215RWKW with the mods listed in my original post, although we did have a base tune for similar mods already. Very happy with the attention to detail & the results.
Edited by GeeDog
https://www.sau.com.au/forums/topic/446752-r33-s2/page/2/#findComment-7365953
How many people does the power fc hand controller actually help?
Everyone i see it just confuses them and the mess stuff up with it!
helped me when I couldn't get 98 and put in 95 RON.. just went into the controller and trimmed of 3 degrees of timing - happy days..
not to mention I ran the Apexi Boost Kit too.. so hand controller was tits.
these days, wouldn't touch that dinosaur.. rawr lol
  • Like 1
https://www.sau.com.au/forums/topic/446752-r33-s2/page/2/#findComment-7365979
    • Drain it. I got official Matic D but you can get whatever is listed as Matic D compatible.
    • Thanks guys,  Yeah I should at least have them dynoed, at least then I know what I've got as a starting point.  The springs on these are hard as rocks. I vaguely remember Russman saying he was going to sell the shocks to me with the rocks fitted, as he was keeping the softer springs for his new setup.  I didn't click at the time but of course that was to let me know the shock/spring wouldn't be matched.  I also remember pricing up new springs around 2014-15, but, house, money etc. it never happened. So that was another reason to have them rebuilt. I have rebuilt the forks on many motorcycles so I think I could handle the seals on these easily enough, but getting the valving right would be a rabbit hole I cbf exploring.  Duncan, interesting to hear RP was tuning these back then. I might give them a call.  In the mean time I have been busy fitting sway bars. The Whiteline rear sway bar I purchased 15 years ago finally got fitted, along with the Whiteline front bar that showed up last week. Just waiting on new links for the front sway bar to finish that off.  And my spare set of advan AVS VS5's should be back from the powder coaters in a Pearl White finish sometime this week, with a set of Hankook RS4's lined up for fitting.  And then I just have all the suspension bushes to do. A comprehensive kit is on the way... Lots to do before the Ararat hill climb. Cheers guys 🍻
    • Nice car! I’m glad folks in the US have gotten past the FnF and are buying real cool cars like the 260RS I was with a bunch of mates in Portland about a year ago and spotted a green Stagea (just a regular 2.5T AWD) parked about 2 blocks away and they were like “a what?” So I made a bet with them for a round of beers and said “ok one of you run down there and tell me if the steering wheel is on the correct side” 5 mins later the American comes trudging back up the hill and goes “he’s right guys. Ok what beer do you want?”
    • Should replace OR drop the tank, give it's good clean. Might be worth replacing that entire fuel level/pump/cradle thing with this: https://frenchysperformancegarage.com/products/fpg-s13-180sx-r32gtst-single-pump-hanger-kit-billet-hat-6-v3-fpg-089?gQT=2
    • Thank you so much for the help
