  • Replies 83
What a top day guys, will look forward to the viewing night at Dundans to check out all the days bloopers and random shanigans
And congrats to Kel for picking up the dented VW hubcap award for the most flag fatalities :)
hahaha that was a great day out, shame about the weather but it was perfect for bad behaviour.
This is the only footage I've ripped so far:
http://www.hgeconsulting.com.au/whataboutt...ebrakestosh.wmv 3.8mb
Looks like everyone had a heap of fun :)
2 words about the datto...... F**KING HANDFUL
took me a bit to get used to it as it handles like a boat but after a little bit of advise from a friendly rotary driver I was starting to get the hang of slinging it sideways....
As Duncan has already said it needs a few things:
1. STIFF AND LOW suspension
2. Smaller steering wheel
3. MUCH tighter handbrake
4. New Seat
5. New Engine and 5 speed gearbox (pending compression test)
6. New Radiator
All in all I was fairly happy with the way it went throughout the day, the locked diff certainly provided some entertainment for the crowd watching at times :P
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
