So, it appears that my monitoring is terrible as I'm not being notified of a lot of times the site is down, or it tells me after the site is back up (helpful ... )
So, as I'm desparately trying to get to the bottom of these outages, please let me know ...
Time the site was down (eg 25/08/2014 8:10pm - 8:22pm)
What you got when it was down (plain white screen or error message)
Whether you noticed how many people were on the site just before it happened (It doesnt seem to be related to numbers ... )
This is starting to drive me crazy and I appreciate the patience.
C
https://www.sau.com.au/forums/topic/447255-downtime-registry/
Around 9:35 for at least 5-10 minutes I couldn't load any of the forum. Attempted the general section, motorsports section and nsw members sections.
Was just a blank screen with the writing "No input file specified." at the top left of the white screen.
Hiya,
I'm getting a weird one. I'm on iPad.
When I navigate to the forum index page, for some reason I get redirected to the App Store without clicking on anything. It's always this app. Amusing the first time, but getting annoying! Any idea if it's something to do with the averts on SAU?
4.40pm
Have problems getting into Projects, overhauls and build-ups. Get white screen.
If I sign out I can get to it.
Mainly use firefox but same issue with IE as well
Is it still happening? Or just for a short period?
Still happening when I tried it just then.
I can access other parts of the forum.
Just tried logging out, accessing projects, overhauls and build-ups (which I could) and then logged in again once there and got the white screen again.
So every time you try? refreshes dont fix?
What skin/theme ?
What skin/theme ?
I tried refreshing and clearing the browser cache and ti didn't fix the problem.
Just changed the theme and it now works. I think I must of had an old skin that you can't choose anymore.
    • Ok thanks..that was my second question if i can somehow bypass this even with Nistune(that is all i have right now...aparat from stock ECU. So with some aftemarket it can by "bypassed" or make it work?  I know there is Link or Haltech (mainly used). We have ECUmaster here so i will gather some info about it.
    • Yes. You will need to get the original boost sensor and wire it in. That is.... if you plan to use a stock ECU - even a Nistuned ECU. The Nissan ECU will not operate correctly without it connected. And yes, it will do annoying stuff like you are experiencing. You will almost certainly be better off with some aftermarket ECU, than trying to hunt down rare sensors.
    • Ok so ABS/TCS is "not" the problem. Yeah i know now about the ABS with Nistune(i told that to the Nistune guy) but iam not 100% why or why i dont have ABS. ABS cube is in the engine (always has been) but i had braked couple of times rly hard and brakes just locked and scream. Does all Skylines have ABS cube? That boost sensor https://www.sau.com.au/forums/topic/367633-wtb-r34-gtt-turbo-pressure-sensor-pics-inside/ Is this it? I need to ask but i have a picture of engine bay and i do not see that (100% is not in that place) If i do not have this the car can do what mine is?(cutting around 4000 rpm) Here is the pic of my engine bay(only one i have) BUT i think i dont have that cuz loom was used from my RB20DE NEO and i know (obviously) that it does not have boost control or any wire to that...) so maybe that is the problem? (i dont know for 100% if that car where the engine is from had that)...but i dont have the loom from that
    • I'm with you here. It's either loom has an issue, OR, injectors are not functioning properly. It could even be they're just constantly dribbling, hence the wet, but not firing.
