I'm in two minds about whether these will look any good on a white BNR32.
I'm appealing to your advice.
Possible Pros
* Japanese made
* Eliminates the orange contrast > cleaner look from a distance
Possible Cons
* Tacky looking
* Lens is not ribbed like the headlight lens > misfit, up close and personal
Thoughts?
depends if you want the authentic look Tez
any pics in the white 32 thread with clears to compare?
I run those clears ^ on my R32GTR (modernizes) :)
I do have a set of brand new smoked Dspeeds with the ribs in the lens that I'd let go to you for half price.
They look better with the N1 headlights over the projector type.
You could also go the clear dspeeds with ribs ($400+) RHDjapan
Thanks for feedback Richard. Those smoked Dspeeds with the ribbing sound good! (Sounds like smoked ribs huh?)
I'd always keep the original amber lenses for authenticity (wow 5 syllables).
Still weighing up...
Well from another R32 owning Richard: No. Just no.
i was gonna post that pic of my car to show how the clear dspeeds look, guess you guys beat me to it LOL
Personally the only set I would ever run are the ones above, the match up with the stock head lights perfectly and almost looks oem.
The JJR clear ones come with the black surround. Unlike the Japanese ones from RHD in your first post.
Dspeeds also come with the silver surround but easy to paint black
Here are the smoked JJR and Dspeeds to compare (bad pic but you get the idea)
Note* the JJR set have a more solid tab for the screw at the top than Dspeeds (so be careful when installing not to snap off)
and a close up of the dpseed clears
Edited by Sinista32
DSpeeds look the best then I'm thinking.
Many thanks Richard, Anthony and Ravi.
  • 1 month later...
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
    • There is a really fun solution to this problem, buy a Haltech (or ECU of your choice) and put the MAF in the bin.  I'm assuming your going to want more power in future, so you'll need to get the ECU at some stage. I'd put the new MAF money towards the new ECU.
