Just a suggestion on the rims as a cheap alternative, what about a 15 steel band to what ever width you desire and use a ford steel rim centre, that way you can weld the centre to band at what ever set you want.
  • 1 month later...
Going to need more injector than what I first thought so I've got six Precision 225s and six more Precision 550s coming for it. They hurt the back pocket but they're worth it and a proven combination with methanol.
  • Like 1
So thats about 8200ccs per cylinder if my maths is close. Geez thats alot of fuel. Go hard or go home!!!
Did i miss what size turbo your running?
It's a Precision Gen-2 8891. Rated around about 1600hp. I'm looking for about 1200-1250 from it. If it makes anything like 1000kW I'll be rapt.
  • 4 weeks later...
Ross balancer, triggers, oil pump, block-offs, brackets, drives, pulleys and more arrived today to go with the Ross billet sump pan from earlier.
It all looks amazing. Can't wait to bolt it up.
  • Like 1
I have this 2nd hand Peterson dry sump tank of which I don't have any use for anymore if you are interested in purchasing it mate. Just needs a clean up and it's ready to go.
Make a cruisey offer and it's yours mate. Sorry about the sideways pics,,,my puter is not behaving.
Cheers
Neil.
Hey mate after looking at their website it looks like this one, so 3 Gals. It's a bit dirty and has the usual scratches that would polishout. The 3 straps don't have the factory bolts but thats an easy fix.
3 Gallon - 16” tall x 9” dia.
08-0009 3 Gallon Single scavenge inlet, -12 AN Female Fittings.
08-0010 3 Gallon Dual scavenge inlet, -12 An Female Fittings.
Cheers
Neil.
    • That's probably OK. That's a face to face compression joint between two surfaces with the clamping load provided by those bolts. So.... it's unlikely that the bolts will end up feeling that load in shear, unless the clamping surfaces are not large enough, bolts not got enough tension on them, etc etc to prevent the two faces from moving wrt each other. Which... I would hope the designers have considered, seeing as it's probably one of the most important things the upright has to do apart from resist collapsing in its own right. But yes, it would definitely be worth asking them what their safety factor on that part of the design was. I tend to think that the casting, being a casting, is not necessarily the strongest bit of material in the world. It's about an inch square, and when you think about the loads that are being put into it, you have to wonder what safety factor the Nissan boys (and every other OEM engineer who has designed all the millions of other uprights that look essentially the same) used to account for defective casting, aging, severe impacts on the wheel, etc etc.
    • Those bolts would be orders of magnitude stronger that cast aluminium though.  And its mainly clamping force, not shear they are dealing with?
    • Except all that twisting force that is breaking a cast piece, appears to be going through 4 bolts in the picture Johnny posted of the BryPar one...
    • The smart approach is to use the gearbox loom from the manual car. Makes it a lot easier - just plugs into the switches on the box and plugs into the main loom up near the fusebox. Then you only need to deal with bypassing the inhibit switch. The other approach requires you to use the wiring diagram to identify those wires by colour and location, perhaps even indulging in a little multimeter action to trace them end to end to make sure, and then.... you will have the answers you need. The R34 wiring diagram is available on-line (no, I do not have a link to it myself - I would have to do a search if I wasn't able to go to the copy I have at home).
    • Hi, i’m converted my r34 4dr auto to manual but need help with gearbox wiring. There are bunch of wires no idea which one for speedo drive, neutral, reverse can anyone help me. IMG_6860.mov
