Hey guys,
Recently picked up a 2001 250t RX four Stag. Got her cheap, but inherently with a few issues. Having a few problems sourcing an oil leak! If anyone has any ideas it would be an amazing help!
It isn't a big enough leak to lose too much oil and never drips on the ground. It does, however drip directly onto something hot as it smokes up the engine bay and smells of oil. It seems to be coming from the turbo side of the engine. What I have worked out, is that it only seems to leak under load - It could sit and idle forever and not leak, but take her around the block and she stinks!
I have recently replaced both rocker cover gaskets (as they were rock solid and pissing oil everywhere) and I had hoped this was the cause. Unfortunately not.
Any help/guesses/suggestions would be amazing guys!
Also, upon replacing rocker cover gaskets - what a pain in the ass that was (backyard mechanic over here lol), she now seems to miss upon acceleration. At idle, smooth as, revving in park smooth as but as soon as i drive it feels like its bogging down/missing. I have checked all vacuum lines and connectors and I have put back everything seemingly correctly. (most things will only fit in one spot!). Im stumped! Maybe I should study mechanics so I dont have these problems hahah! :( All learning I suppose!
Any advice greatly appreciated! Cant wait to get this badboy on the road!
Corey
https://www.sau.com.au/forums/topic/448400-vq25det-help/
Hey mate, thanks for the reply! Ah I had that problem initially but its in 100% now! No leaks at all from rocker cover. I'm thinking might be old oil stuck between heat shield and exhaust still burning off...
https://www.sau.com.au/forums/topic/448400-vq25det-help/#findComment-7384951
Hey Daleo havnt had a chance to take her for a solid spin yet to doubje check the oil leak. :( still got the running rough problem tho, cant work it out!! Ive noticed there us a random miss/murmor at idle too but very infrequently...arrgh
https://www.sau.com.au/forums/topic/448400-vq25det-help/#findComment-7386575
Could be crank or cam sensors, it can be hard to fault find these without a consult reader and a few spare parts... I assume the plugs have been changed?
If you still have an oil leak and it still smells after a drive, there are a few other things to check, the cam sensor Orings can leak, and the dipstick can blow oil out if it isn't in properly, or the seal is damaged. Both these will cause oil to burn on the manifold.
  • Like 1
https://www.sau.com.au/forums/topic/448400-vq25det-help/#findComment-7386649
I didn't change the plugs, however it ran perfectly fine before?
https://www.sau.com.au/forums/topic/448400-vq25det-help/#findComment-7388907
I would have at least checked one while I was in there, otherwise you may need to do the whole job again just to change the plugs.
Can you remove one and check the gap?
I did check one, seemed worn but I didn't have the time to get a set soi just put it all back. I assumed it ran fine before so? Ehhh :(
Engine light has now decided to come on, maybe that's a good sign as I can get it scanned...
https://www.sau.com.au/forums/topic/448400-vq25det-help/#findComment-7390482
Hey Scotty,
Oil smell cleared up - seems it was just some old oil on the exhaust :)
As for the rough running - don't know how i didn't spot this before, but found this badboy snapped off today!
https://drive.google.com/file/d/0B2Y9a42ue_rIa04ybDFYU203N2F1aWxmMlpOdnZ0dzQ4Z1Jz/edit?usp=sharing
(Sorry, couldn't work out how to wack a pic on here)
The snapped off bit comes from a line that hits a t-piece then goes off to what looks like somewhere near the turbo, and the other way goes to the piping from the intercooler close to the throttle body. The small line you can see goes to the piping just after the airbox. Obviously the line was just hanging loose and i didn't notice! Could this be why shes running terribly?
Cheers :)
https://www.sau.com.au/forums/topic/448400-vq25det-help/#findComment-7392742
I doubt it. It would have just been running high boost (14psi) all the time.
Did you get it scanned yet?
Did you unplug any coils while you worked on it? I have seen the plugs for them mixed up more times than I can remember.
https://www.sau.com.au/forums/topic/448400-vq25det-help/#findComment-7392746
Ahh, wasnt even sure what that sensor was for!!
I did unplug some. I thought if I had put one in wrong, it would miss terribly even at idle? It seemed pretty obvious which was which as the length and position of the cables went to the right place. But maybe not. I feel like an idiot haha! :(
Ill kick myself when I work out what dumb mistake I have made!
https://www.sau.com.au/forums/topic/448400-vq25det-help/#findComment-7392750
    • The fab work can be as simple as a couple of silicon hoses and clamps to the factory piping.
    • Just sounds like either way you need to do some fab work to get everything to fit, so why limit yourself at that point? If the GCG high flow option is zero effort in and out swap though I'd probably do that. It's almost certainly lowest risk, lowest cost, etc. The HKS GTIII-RS option that Kapr mentioned is laughably expensive for what it is, they charge the exact same for two turbos on the RB26 so their margins are off the charts on that thing.
    • Intake manifold is not a part of the issue. The turbo bolts to the exhaust manifold. That is easy. But close your eyes and picture the physical situation. That is a T3 flange on the manifold and a T3 flange on the turbo. As long as any new turbo has a T3 flange on the exhaust housing, that exhaust housing will bolt to the exhaust manifold. This places the exhaust housing in the same place as the stock one. But now move your mental attention a little further forward. The location of the compressor housing is set by the length of the turbo's core. The stock turbo had a long core. Let's say that it is..... 100mm long. So that would place the compressor housing 100mm forward of the exhaust housing. But a highflow, might well have a centre core that is shorter. Let's say that it is only 70mm long. Now the compressor housing will be 30mm further back in the engine bay than the stock one. This DOES move the turbo's compressor outlet backwards. It also moves the compressor's inlet backwards. You will very likely have to do some work to both the inlet and outlet piping to make everything connect again. I am not say this to make it out to be a bigger deal than it is. I am just pointing out that "bolt on" is sometimes not quite bolt on. The highflow from GCG that Murray linked above (https://gcg.com.au/turbo-charger-upgrade-skyline-gtst-2iu-xtrgts-s1.html ) uses a core that is the same length as the stock core, and so does not require this extra work. It will look very much like the stock turbo. No-one uses GTR turbos of any flavour (stock, or aftermarket) in a single turbo application on RB20/25. It's not a thing. Yes, people have been putting on GT3076, GTX3076 (and bigger and smaller versions of those) and G30s (of various sizes) onto RB20/25 since forever. But these are not "bolt on". Everything except the 4 bolts to the exhaust manifold change with these. And genuine Garretts are expensive. Non-gen, like Pulsar, etc, are cheaper, variously as good or nearly as good. But still not bolt on. No-one in the right mind would pay for an HKS turbo. Not in this modern day and age. Well, yes, the GCG highflow. You could ask HG what he can do to make the compressor housing sit in the original location. There are surely others doing highflows around the world. And some of the eBay/Temu ones (as reported by Dose) work and don't die. Bit of a lottery though. I would send your turbo to GCG (here in Oz) to be highflowed if you want a trivial no-extra-work option. But seriously, the work required to change inlet and outlet piping is not that hard. That's a boost control problem, not a turbo problem.
    • Thank you all for the replys 🙂 I know that intake would be different but that is one pipe at it is not that hard to get(custom one). I meant mainly bolt to the stock manifold and the turbo elbow. I looked and many sites/forums but they are just "old" with some old HKS turbos from GT-R i guess? What about some Garrets?  Or any other turbo? Is there even a turbo which i can just bolt on? 😄 And yeah i know about that new HKS but that is like 2000k USD without taxes/shipping in here   Iam getting a touch up tune but my "problem" is that on the "not" hot day iam getting peaks around 0,9 bar...and when it was around 15 Celsious i saw peak around 1 bar which is just too much for stock turbo. And of course turbo is old and i like to get some new one for a piece of mind 🙂
    • I'm working on the assumption that our friend Jasmine here is a Russian (or, possibly Ukrainian) spammer/spambot, based purely on the number of such that I have been having to neuter in the last few weeks. IP address for the OP above was in WA. But that could have been via VPN. Posting at quarter to 4 in the morning is a good sign of being from somewhere in Europe. The last Jasmine that I kicked in the cooch was IP addressed in Ukraine. Even that could have been via VPN, and the bitchbot could have been from Russia, Serbia, China or anywhere. Regardless, was a spambot, so I killed it with fire. The fact that our new friend Jasmine here did not respond in any way to my tart query strongly suggests to me that this OP was just the establishment phase of a user able to be activated for spamming in a week, or 3 or 10.
