Hi all.
R32 gts-t.
R33 Gts-t clutch master cylinder
R34 GT-T clutch slave cylinder
NPC clutch.
Have bled the clutch multiple times but it doesn't seem to get full disengagement. I am unable to change gears very easily when the car is turned off. With the car idling up on jackstands it takes noticeable effort to put the car into gear witch my foot on the clutch fully depressed.
When it selects a gear the wheels start turning at the appropriate speed and you can feel that the clutch is not fully disengaged as even pushing against the the gear without selecting it the wheels start to turn.
I think this means a dodgy master cylinder correct? I bought a second hand one from an R33 and bled it up, there is definitely movement at the slave as you can see it move the fork maybe an inch or so but not enough to disengage the clutch.
Just wanting to confirm it is the master?
Thanks
https://www.sau.com.au/forums/topic/448489-suspect-failed-clutch-master/
If your looking at the slave and it doesnt look like its pushing the fork enough then yeah its either your master or slave, but Im assuming your slave is new since you only mentioned the master was 2nd hand? Have you played around with the rod adjusment on the master?
Did you bleed the master then the slave? I think if you still have the standard loop line (which I think is used to cool the oil for some crazy reason) down at the slave then there is a block there with a bleed nipple also
At that stage it shouldnt matter but I would still bleed along the system just to be sure. Master ----> Line -----> Slave
I could be wrong about that loop line or you may not have it fitted, but have a look anyway
Hi new to sau so not sure if I can ask question here or start a new thread. So I apologise in advance if I'm wrong.
I am also having a clutch problem. I drove the car down the shops today heard a small noise like something broke and finding a gear after tht became progressivEly harder after that to the point where I can not select a gear. I eventually limped home I noticed the master cylinder resovoir was completely full of fluid. When previously fluid level was normal. Could this be also a master cylinder failure?
Clutch had seemed normal till then accept it was kinda squeaky.
I think my issue lies in trying to use a 33 clutch master with 34 pull type slave. No matter what I seem to do adjustment wise it just does not exert enough pressure on the slave to fully disengage the clutch.
Anyone successfully used a R33 master and 34 slave? Or can anyone else recommend something that has more pressure (I guess this is related to the bore size?) and still is short like the 33 item as I have a greddy forward facing plenum so need something nice and short.
Surely there is plenty of people out there with R33 masters in R32's?
You may have broken the pivot ball or the pedal bracket. I believe these are the 2 most common problems in R33's
Edited by 89CAL
Not to sure about the pivot ball. I have broken one before probably 12 years ago in my s13 and completely different symptom. .. I also looked at the pedal bracket and all seemed ok there too. Only thing different is the reservoir is full to the top of brake fluid when previously it was in the normal range.
When my clutch master failed it produced noise before it eventually collapsed on it self and i could only get home in one gear.
The system is a pain in the arse. The whole loop is redundant. If you can get.your hands on a braided line id eliminate the entire loop and go straight to the slave. It would help you ensure you've bled correctly .
There was some noise previously was a profound squeak and then a clunk of sorts. It then got worse. Pedal still has pressure behind it it just doesn't engage clutch properly to allow me to select a gear or change gears.
The squeak is usually a sign of the cylinder not sealing properly or a worn spring. In my unit the spring snapped and the piston inside wasn't sealed causing the clutch to semi disengage and the excess fluid in the system to backwash into the reservoir.
OK.
So if you are confident that the system has been bled 100%, have checked for leaks then I think you need to grab a second person, get under the car and watch the slave cylinder to see what it is doing. If it looks like it is travelling a good distance (I think the throw is about 2cm? But someone correct me if I'm wrong, this is an educated guess)
If the slave is travelling the distance fine, then it may be a problem around the clutch itself. If the travel is not so good then it can only be slave, master or clutch pedal (adjustment, bracket etc)
If it were me, thats where I'd start
Yep have done this. It looks like it's moving it a good distance (around an inch) but it still won't disengage. It is a pull type clutch and the equivalent of the throw out bearing engaged properly on the fingers of the clutch cover.
Have tried 2x R33 masters now and both have the same issue. Also the shank on the bolt that connects to the clutch pedal on the R32 master is longer than the R33 one. So i put the 32 one on the 33 and tried that hoping it would exert more pressure on the slave, but even this didn't work.
Might just have to shell out the $140 for an R34 master :(
Wait wait. You say the slave is moving a a good distance, and an Inch sounds about right. But you are still looking at the master?
If the slave is moving that far, it sounds like you have a problem AFTER the slave. Maybe you are hoping not, because pulling the box off is a big job, but I think you are wasting your time with the master at this point. You need to look inside at the clutch/fork/throwout bearing etc. You might be able to peel the boot away enough to have a look inside.
I understand what you are saying but it requires lots of effort to try and move the clutch fork, and I heard it engage on the fingers of the clutch cover. I will try and have a look but I really think that everything inside the clutch is fine, just a gut feeling.
Even though the slave is moving it feels like I have replaced the pedal with a wet fish, that's about how much feel the pedal has.
I had the same issue when i first installed my clutch. i adjusted the pedal and it selected gears fine.
If the master doesn't return to the correct point in it's stroke it will cause all sorts of problems. I agree, adjusting the pedal is where i would start. I have had many head scratching moments caused by this.
Can you look inside the bellhousing and check the thrust bearing?
  • 6 years later...
Did you get this sorted? I am in the same position. R34 bigbox with a pull clutch and a R33 master. Pedal basically drops to the almost the floor then starts working. Does not return under its own power.
This is a new build as such, conversion from auto. I am pretty sure I have bleed the master and slave, at least I can not get any more air out.
Edited by elohim_imanu
Yes, RB30 crank is like ~3mm longer than RB25. This caused the tube that the throw out bearing slides on to physically push the centre of the clutch disk into the flywheel.
Which basically means that i was never able to disengage the clutch.
Trimmed 5mm from the end of the tube and never had an issue again
    • A 1.5 way is a 2 way. It is just a 2 way with a less aggressive ramp on overrun.
    • The ABS and/or TCS being missing/broken will not cause the engine to misbehave. It just casues CEL to come on and annoy you. The CEL is useless if it is always on, so you have to do the things you have to do to get rid of it, so it can be useful. Being a Stag ECU, then yes, it will not expect TCS to be present. But it will expect ABS to be present and working. You will need to either make the ABS CU talk to the ECU (don't ask me what that will take on an NA R34), and make sure the hardware is working....or, you just need to blank it out in Nistune. Do not persist with the stock ECU. You will just have problems. Gte it Nistuned. Start from there. DO YOU HAVE A BOOST SENSOR? The ECU's boost sensor that it. It is connected to the loom at the rear of the coil cover. Usually rides on the firewall on an R34, but is usually bolted down to a bracket along with all the other crap at the back of the coil cover when a Neo is dropped into another car. If you do not have it, the ECU will shit the bed. So, do you have one?
    • So sadly the fuel pump etc was not it. The pump and filter is new and it is still cutting around 4000 rpm. A read something about ABS/TCS (engine is from stagea and ECU too so no TCS) and i dont know for 100% that my car has ABS. It has ABS "cube" in engine bay but i dont think it works(or at least from my braking experience). Can be something like that?  I will be driving the car next week to Nistune tuner to properly see what is wrong...
    • the Tomei LSD fluid with lsd kit. frustrated that it was shaking the car to crap and affecting everything else negatively, I pulled the diff last night, and removed the lsd carrier, could not find anything wrong, however it seem to be 100 locked up acceleration, and deacceleration, wondering if they sent me a 2 way not a 1.5??  either way I installed the stock open carrier back in place. test drove everything smooth as butter again. no shake, shutter, random, what felt like clutch slip and grab or drive shaft play, etc. something differently wrong in side the lsd. I might bother taking it apart (if possible) to figure out what's going on inside this carrier, as bought too long ago to return.  only draw back is its back to a one wheel wonder.
