  • Replies 50
Top choice of forged pistons there Andrew. Is that the off-the-shelf RB26 CP kit, or are they customs? I went for CP customs due to 8.0 CR.
I emailed Darius @ CP Pistons at length, and he presented me with quite a few options. I couldn't believe how many different ring combinations they had available!!! Coupled with custom compression ratio, and CP Groove, and lateral gas porting, I had my hands full with choosing the right custom piston for me.
But although lateral gas porting helps achieve a greater ring seal, apparently the ports can fill up with deposits and reduce the efficiency of the porting, and are more suited for race applications where engines are pulled down and rebuilt every few races.
But the off-the-shelf piston, comes with the CP Groove, and raises compression from 8.6:1 to about 8.8:1... Coupled with decking the block/head (increasing compression slightly) and 1.2mm head gasket (lowering compression slightly), I should end up with a net compressoin ratio of about 8.9-9:1 which sounds perfect.
I'm really against dropping the compression ratio to facilitate using higher boost.
Yes I must admit I was a touch concerned about the 8.0CR. I was thinking it may result in a lag monster that needed 30psi to produce the goods, but thankfully this was far from the case.
Here's my latest dyno sheet so you can see how my engines 8.0CR, porting and turbo combo actually performs (apologies for the black and white, but I had it faxed to me) The dip up top is due to boost dropping (possible BOV leak issue?)
My combo has damn near the same response as a 9.0CR, HKS 2835R Pro S with manifold and Greddy inlet manifold (same dyno same day). It also made more power on the same boost. A few people were surprised that mine was as responsive as it is. Not only is it 8.0CR but I also run a POS old school plain bearing T3/TO4E. *Note* - the back to back comparo is not the dyno run from above.
I agree that more boost is required (1.3-1.4bar is perfect) to make the numbers on lower compression, and this in turn puts more demand on the turbo.
EDIT: Oh yeah... and I know, I need a set of cams. If someone has a spare set (or even just the exhaust), then feel free to give them to me. I say give, as $ is bloody low atm :cheers:
    • LOL.... a good amount of people (not all) on that continent seem to know everything and like to measure things in bananas, football fields, statue of liberties instead of the metric system lol.
    • I assume the modules are similar enough, so if you've had no issues I don't see why I would. I have tried to find a wiring diagram for the FPCM / fuel pump circuit, but I can't find it anywhere. Otherwise, I would just do some wire cutting and joining at the FPCM and give the 12 V supplied to the FPCM directly to the pump instead. If you know anyone that could help with wiring diagrams, I'd be very happy
    • If it dies, then bypass. The task isn't difficult. I have one running on a standard R32 FPCM. That's after nearly 20 years of it running an 040, which pull substantially more current than the Walbro. They're not the same module, but I'd hope it indicates that the R33 one should be man enough for the job. I think people kill them when putting proper sized pumps on them, not these little toy pumps we're talking about here.
    • Silicone spray won't hurt anything. And if it does, that's an opportunity to put some solid steel spherical bushings in, so you can really learn what suspension noise sounds like, If you're going to try it, just spray one bush at a time, so you can work out which one is actually noisy. My best guess is that if the noise started only since putting the coilovers in, then it is just noise being transmitted up through the top mounts of the struts, and not necessarily "new" noise from bushes. But it's almost impossible to know.
    • Are you saying the 34 is SUV height, and not that we're talking about an SUV here? (because if we're talking about an SUV, you don't fix them. You just replace them when something breaks. Not worth establishing sufficient emotional connection with an SUV to warrant doing any work on one). I wouldn't jack my car up on a short little loop of 10mm steel rod poking out through a hole in the bumper bar, front or rear end. I realise that we're probably not talking about that type of loop at the front, being the one under/behind the bar on a Skyline.... but even for that one, trying to jack up on what amounts to a thin piece of steel, designed purely for withstanding a horizontal tension force, not a vertical compressive force (and so would be prone to buckling/crushing) and, my most particular bitch about it - located RIGHT AT THE EXTREME FRONT OF THE CAR, applying a load up through the radiator support panel, etc, with almost the entire mass of the car cantilevered between there and the rear wheels? Nope. Not doing that. Not on the regular. That structure out there in front of the front crossmember is not designed to carry load in the vertical direction. Not really designed to carry any load at all, really. The chassis rail that the tow point is connected to would be fine loaded in tension, as per towing. Not intended to carry the mass of the whole car, especially loaded all on one rail, with twisting and all sorts of shitty load distribution going on. No, I will happily drive up on some pieces of wood, thanks. That can only happen on driven wheels, and they are at the other end of the car, and this problem does not exist at that end of the car. And even then, I have been known to drive up on at least 1x piece of 2x8 each side at the rear, simply to reduce the amount of jack pumping necessary to get the car up high enough for the jack stands. What really really shits me about Skylines is the lack of decent places for chassis stands at either end of the car. You'd think they'd be designed into the crossmembers.
