Been doing a lot of reading and to my understanding, hot/cold temp recommendations vary based on amount of KM's on engine?
Motul 8100 5W40 vs Motul 4100 10W40 with 151,xxx k's?
I can afford 300V oils if that would be a better option too - just really confused as to which I should buy. Previous owner (4000 k's ago) got it serviced and they put Penrite 20W60 in :\
https://www.sau.com.au/forums/topic/448862-engine-oil-for-rb20det-gts4/
nothing wrong with using a thick oil mate. those engines are approaching 25 years old. ~10w40 or thicker I would suggest. Depending on boost level I guess; you want to keep the oil film strong when it's hammering.
personally I don't use the super expensive fully synthetic oils as I end up burning most of it or blowby ruins it anyway. Just use a $30-40 bottle of semi-synthetic, make sure you don't ever run low on oil and change it very often.
Edited by Blackkers
Will likely go Motul 300V 10W40 Fully Synthetic and see how I go.
I understand the turbolight is roughly half the price, but I've also read synthetic esters are worth their weight in gold and will allow me to shoot for 10,000k oil change intervals.
I'm using valvoline synpower 5w30 which is a fully synthetic oil. After 5000 km i flushed it and made an UOA.
The oil was pretty thinned out but wasn't worn out chemically speaking.
I never went over the 120°C with it and was only street driven seeing 80~100°C most of the time.
So I wouldn't go much over 5000km between flush with low viscosity index like 5w30.
The next flush is due in about 200 km, I'll make an other UOA as I trashed this oil both on the street and on track and I stayed quite a lot of time north of 100°C. Nothing major but still worrying me a little as the previous oil was thinned out with softer driving.
I'll go for an other turn with 5w30 index as winter is coming and maybe go for a thicker oil if the UOA calls it.
I used to use motul 8100. I use Penrith synthetic (cant remember the proper name) now. I wouldn't hesitate to suggest the motul 8100 or even 4100. Nowhere stocks it where I live anymore so that's one of the reasons I don't use it now
I wouldn't dare go 10k on a factory original RB no matter what the oil is. But suit yourself, I guess keep an eye on the level and it will live
I ran Penrite 5W-60 in my GT-R for years, serviced every 10,000km when it was driven as a daily. Never burnt oil either (I warmed the car up obviously).
OP, I wouldn't bother with the expensive oils, get Aussie ones (Nulon/Penrite)! But anything around 10W-40 will suffice. HPR10 is fine.
What sort of driving will you be doing?
    • Hi, i’m making a rb25det coil loom for Vag short coil. Can anybody tell me which Ecu signal wire belong to coil number 1 and 2,3,4,5,6? The connecting switch in above pic is 8 wire i think white is for +12v and black for earth.
    • Was there ever a model of the Stagea m35 that didnt have a badge on the grill? I thought I saw that somewhere, some aero edition or something? I cant find it again? davemoto
    • Its a 2002 vr-x four VQ25DET, silver. Coil overs, lowered, polished alloys and sport exhaust. Bit of a project, was sitting in a shed for a while but runs and drives great.
    • I wasn’t able to replicate the sound anymore. It was a one time sound so maybe it was just coincidence but it was like small pebbles being dropped in a coke can.   should I try cleaning the MAF? It could be it’s functioning but dirty? I don’t know.
    • Update 4: Hi all. The car drives again! Haven't driven for long, only to store it in the garage again, but the test drive was successful. The coolant and oil leaks seem to be fixed for now. Temps on the engine were also very good, while moving I never even saw 80C water during the approx. 30 minute drive. Ate up all the coolant in the reservoir though so will have to fill that even more when I go to the car next time. One thing that pisses me off is that the RPM gauge is still f**ked, I even resoldered the board twice and used copper paste on the silly screws that are used as connections. Next time I take it out I'll take apart the board and fit new components, I'll see if I can get a replacement IC for it.  I have an appointment set for 22nd of September for the engine tune to 370hp. Alignment also still needs to be done. My hope is that I can get all the legal stuff over with by the end of this season. Anyone of you have advice regarding intercoolers? Currently there is an APEXI core fitted, one of those weird hybrid ones, 600x270x76. I don't think it's bad but it's not new and now I still have the chance to change it now to legally include it in the paperwork. Only issue is that the only options that would arrive in time are a HKS Type R intercooler or generic Ebay spec intercoolers comparable to a JustJap one. Ideally I'd order a Plazmaman but it takes over a month to receive which would mean making the car legal has to wait until next season. Would love to hear some input on this. Same story for my injectors, the previous owner was a nunce and put ID 1050x on the engine. They work but are obviously not ideal at "normal" power levels. But I don't see a reason to change them unless the tuner says it's necessary. I read online before buying a different exhaust that the top secret style rear diffusers won't fit due to the size of the rear resonators. My buddy and I made it work by slightly "adjusting the shape" of the mounting bracket and making some spacers out of 3d print for the mounting bolts. Fits like a charm. Just putting this here in case someone has this problem. Even the hefty HKS Silent Hi Power rear can fits without hitting anything.
