few days ago I purchaced my first skyline an r33 gtst
iv been tolds its running 16 pounds of boost which I find ridiculous
as it doesn't feel or seem nothing like it, iv had a look at the ecu
and looks like a stock one to me as I said im not to well with skylines
so after abit of reading around I have a couple questions
if getting an aftermarket ecu is a nistune board still needed for a tune?
iv heard of several places that now remap the r33 ecu?
im just after a basic tune, an alternative to paying $800+ just for the nistune
just to get everything back on track for now as the car seems like running shit for that much boost..
how would this prove the ecu isn't stock though
I don't doubt the boost im just assuming he upped the boost to that amount of pressure with zero ecu upgrade or tune
which I believe is the reason why the car feels so sluggish
Because a R33 GTS-25t will run like absolute shit at 16PSI on a stock ECU. The standard ECU will dump in fuel and retard timing pretty harshly.
That's a stock R33 turbo auto ECU. Unless it has been Toshi tuned or similar (which is not so likely) then it is a piece of crap that will not appreciate being run over 10-12 psi. Massive pig richness and a complete absence of ignition advance will occur. Horrible brick wall lack of power feeling to go with it.
Also, if you are running 16 psi, there is a good chance that you will destroy the turbo any time you boost it up. They just don't like it. Too hot, too fast, too bad.
Turn the boost down to something safe an keep it that way until you can afford to replace the ECU totally.
By the way. Just in case you think you can, you cannot Nistune that ECU. R33 ECUs won't do it. The alternatives are to use an R32 or a Z32 ECU, both of which are less than ideal solutions. For the effort and compromise involved, if I were trying to tune an R33, I'd get an Adaptronic or some other suitable aftermarket ECU and just live with the defect threat, such as it is.
No. Nistune is a daughterboard conversion that you put into a Nissan factory ECU (as long as it's not an R33 one!) to turn it into a programmable ECU.
Your car is an auto? That can be a complicating factor. A lot of people like to use the PowerFC, but as far as I can remember they don't like to work on auto R33s. The problem is that there is a comms link between the ECU and the TCU (gearbox computer) that gets upset when it's not connected. The TCU goes into a sulk. I think - I don't know for sure, because as soon as I hear "auto" I go to sleep and dream of manual conversions.
yeah though so, I doubt its toshi tuned either according to a quick look up his located in NSW and im from VIC
so back the the actual question what would be a slightly inexpensive alternative then getting nistune installed?
Second hand powerfc.
    • Nah - but you won't find anything on dismantling the seats in any such thing anyway.
    • Could be. Could also be that they sit around broken more. To be fair, you almost never see one driving around. I see more R chassis GTRs than the Renault ones.
    • Yeah. Nah. This is why I said My bold for my double emphasis. We're not talking about cars tuned to the edge of det here. We're talking about normal cars. Flame propagation speed and the amount of energy required to ignite the fuel are not significant factors when running at 1500-4000 rpm, and medium to light loads, like nearly every car on the road (except twin cab utes which are driven at 6k and 100% load all the time). There is no shortage of ignition energy available in any petrol engine. If there was, we'd all be in deep shit. The calorific value, on a volume basis, is significantly different, between 98 and 91, and that turns up immediately in consumption numbers. You can see the signal easily if you control for the other variables well enough, and/or collect enough stats. As to not seeing any benefit - we had a couple of EF and EL Falcons in the company fleet back in the late 90s and early 2000s. The EEC IV ECU in those things was particularly good at adding in timing as soon as knock headroom improved, which typically came from putting in some 95 or 98. The responsiveness and power improved noticeably, and the fuel consumption dropped considerably, just from going to 95. Less delta from there to 98 - almost not noticeable, compared to the big differences seen between 91 and 95. Way back in the day, when supermarkets first started selling fuel from their own stations, I did thousands of km in FNQ in a small Toyota. I can't remember if it was a Starlet or an early Yaris. Anyway - the supermarket servos were bringing in cheap fuel from Indonesia, and the other servos were still using locally refined gear. The fuel consumption was typically at least 5%, often as much as 8% worse on the Indo shit, presumably because they had a lot more oxygenated component in the brew, and were probably barely meeting the octane spec. Around the same time or maybe a bit later (like 25 years ago), I could tell the difference between Shell 98 and BP 98, and typically preferred to only use Shell then because the Skyline ran so much better on it. Years later I found the realtionship between them had swapped, as a consequence of yet more refinery closures. So I've only used BP 98 since. Although, I must say that I could not fault the odd tank of United 98 that I've run. It's probably the same stuff. It is also very important to remember that these findings are often dependent on region. With most of the refineries in Oz now dead, there's less variability in local stuff, and he majority of our fuels are not even refined here any more anyway. It probably depends more on which SE Asian refinery is currently cheapest to operate.
    • You don't have an R34 service manual for the body do you? Have found plenty for the engine and drivetrain but nothing else
    • If they can dyno them, get them dyno'd, make sure they're not leaking, and if they look okay on the dyno and are performing relatively well, put them in the car.   If they're leaking oil etc, and you feel so inclined, open them up yourself and see what you can do to fix it. The main thing you're trying to do is replace the parts that perish, like seals. You're not attempting to change the valving. You might even be able to find somewhere that has the Tein parts/rebuild kit if you dig hard.
