Hi guys,
I recently got my r34 tuned. While in the dyno the car was over heating and my tuner told me that there is lot of rust in the radiator and I will need a replacement. I was looking at some of the radiator in ebay and couldn't find any direct fit radiators for the car.
My question,
Is there any direct fit alloy radiators for r34 or will I need some modification to the standard fan shroud ? Or is it cheap to buy alloy radiator with fan and the shroud ?
Car:- R34 GTT manual 1998
I'm new to SAU.. So any help would be much appreciated.
Thanks.
Sam.
https://www.sau.com.au/forums/topic/449082-r34-gtt-radiator-help/
Thanks for the reply Benc34 and wolverine. If the trimming is minor it should be all right. Just to clear things out.. when im purchasing a new alloy radiator it should be 42mm ?
Thanks. Sam
On the stock setup will an upgraded radiator help with oil temps at all? I find my oil temps getting to 120 deg c in summer on 40 deg days just cruising around with the stock radiator.
Nope.
Get an oil cooler with a built in thermostat.
Thanks for the replies guys.. I was looking at ebay and found this cheap alloy radiator.
http://www.ebay.com.au/itm/Full-Aluminium-Nissan-R33-R34-Skyline-42mm-Alloy-Radiator-W-15-Cap/161386477821
any comments on this ?
Thanks.
Sam
Any reasonably priced suggestions? I was just surprised that on a stock setup it would get that hot..
Well you can buy Japanese brand named stuff for up to $1000 or you can just get a sandwich plate with built in thermostat for about $100 some rubber hose (yes it works fine) and a small oil cooler radiator (spend the money on a good one). I'm in NZ so can't point you to the shops.
(Like this - not sure if this exact one will fit your car but I have a Mocal one for my RB)
http://www.ebay.com.au/itm/UNI-MOCAL-OTSP1X-OIL-COOLER-SANDWICH-TAKE-OFF-PLATE-WITH-THERMOSTAT-SEAL-SR-/121385762319?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item1c4327be0f
    • Hi all,  I am in the market for an R200 longnose diff out of a Z31 300ZX, or S12 RSX, DR30 skyline, or similar, in a 3.9 ratio.  Preferably a late model one with the M12 crownwheel bolts.  The only easy to find advert for one of these was my ad back in 2007 when I sold it on this forum.  I sold the diff as I had sold the car it goes to, but as it turns out, after 18 years I got the car back late last year, so now I'm looking for the diff !  If anyone knows where to find a longnose R200 LSD with the M12 crownwheel bolts, drop me a line at [email protected] - Bonus paid if soomeone comes up with the original diff (stranger things have happened !).  Cheers   Ben D
    • Hi everyone, I used to post here a bit from 2004-2013, when I owned various Nissans, in particular my S12 RSX gazelle, which was sold in 2007.  As luck would have it, after an 18 year hiatus, the car found its way back to me last year, and over the past 11 months I have had the pleasure of restoring it with my kids.  One thing that I am after in particular is a 3.9 ratio R200 LSD for it.  I actually sold the one out of the car here back in 2007 , and it would be incredible if I could track down who I sold it to, so I can see how they have progressed over the years (and to be honest, to see whether I can get the diff back !).  Anyways, hi all and let me know "where are the R200 Longnose diffs all at these days ?  Cheers Ben D
    • Arms will be the same as the G35 or 350Z, but as above, there was a change in the lower control arm where it connects to the ball joint.  That said, you can remove the ball joint cone from your old ball joints and fit them to the new ball joints.  To be honest, I didn't think the ball joints themselves were different. The main ball joint is a bit awkward to replace, you really need to remove the steering knuckle to press out the old one.  Some people have used tools to remove it in place, but it just seemed too hard to get to. If you are going to press out/in that ball joint, then you may as well just replace the bushings in the LCA and the compression rod.  You can buy the compression rod bushing from Nissan, but the LCA bushes, you will need to go aftermarket. Much cheaper than buying the whole arm.
    • Ha, well, it's been.... a bit of a journey. Things have taken much longer than I'd hoped. I'll probably put up a thread at some stage. Hopefully soon. The car's not done any kms since my update in June though, put it that way.
    • Here's the chart for fuel pressure vs. current draw, assuming your base fuel pressure is 3 bar and you run like 0.5bar boost on WOT, you should only momentarily hit 9amps here and there. (Ignore my prev post, I cannot read a chart these days it seems)
