Oh, and NEVER use a ratchet to apply lots of force. They are not made for it.
Pffft bitch please. My 25 year old Sidchrome socket set says otherwise (I've never met a bolt it couldn't undo - sometimes with big pipe on the end of it)
I've seen some godawful things done to snap-on ratchets and socket sets too. Decent quality ratchets can handle a massive amount of abuse.
But to answer the OP's question, a decent rattle gun should make light work of it.
Meh. I do it as well. 1 meter pole off my ratchets ain't nothing but a g thing.
And mine aren't even sidchrome. 1 is repco and the other is some American something something ratchet.
Are yours calibre maybe?
Op have you gotten this sorted yet?
Hmmm better tell the guys at work to stop using the 900ft lb ratchet torque wrench, then.
Besides, the breaker bar was only a very recent addition to my kit. Have used it a few times, and definitely more comfortable wailing on that with a big pipe. As I said, a decent ratchet will handle anything you can throw at it without using an extension, and I have seen plenty of people using pipes on ratchet handles without any failures (tbh I've never used a cheapo ratchet, so can't comment).
Me doing something doesn't make it right, but having seen something done plenty of times gives you a feel for what they will handle.
I definitely wouldn't be loading up the fine splines in my ratchet ring spanners, though.
Edited by warps
You guys would cry if you saw what I do to my Strap On ratchets, I snapped the head off my Kingchrome breaker bar by hand but never broken a ratchet, even with a 2m pipe hangin off it undoing the wheel nuts off my truck cause the shite Milwakee 3/4 rattle gun just won't quite cut it :(
I ended up getting a 70 cm breaker bar (biggest I could find at super cheap) and it took me pushing from the bottom and a mate pulling from the top to get the bastard loose. Honestly felt like the f**ker was welded on. Cheers for the help guys and the great comments !! :D
  • 1 month later...
  • 3 weeks later...
I just bought myself an Aircat Nitro 1200K Kevlar composite rattle gun. 1295 ft lbs of nut busting torque. OOoh yeah!!!
A million times better than the cheapo Supacheap crap I had before, and not a lot dearer (less than $250 shipped from USA)
  • Like 1
    • haha this shit box doesn't drink coolant, for now       Let me guess, they make heaps of power, use the car for straight line driving and don't care about noise
    • They’re so great that I know of someone pulling one out to go back to a sequential
    • Hello everyone. I've recently started the research into R34 GTR front bits and running into eye watering prices. On the plus site it looks like some places make 'replacement' fender liners for these cars. At eye-watering-but-less than stock prices. I also noticed there's plenty of diffuser options available too. What I would like to know is if my following assumptions are correct. 1) The OEM guard liners are actually only 'half' the liner. They go together with the OEM brake vents which are a separate item which looks to be quite a large 'panel' that is part of the liner. The GTR bumper has bolt holes along the front. I assume the ones in the vent correspond to the ones the OEM liner does not have (circled?)   2) The V-Spec front diffuser supplants the brake ducts in the above item. I am assuming these still work with the guard liners as there's no alternate part that I'm aware of. I don't see how they go together, so I'm making the assumption that they have to, somehow. I know the center splash guard is different on the V-Spec (and is the price of the damn diffuser alone). How does the liner interact with this? 3) There's alternate front diffusers that do away with it all. Annoyingly, a lot of the clones and CF different ones... have no brake ducts on them. I like the idea of them though. My brakes get hot on the track. These alternate diffusers are a lot cheaper than plastic splash guards. I'm assuming you don't have to/aren't supposed to remove guard liners to run a diffuser. I suspect that quite a few people actually do not run the guard liner because with a front undertray you're getting a lot of 'splash' guarding anyway, and most people remove liners given they're probably running a pretty aggressive setup with a diffuser at the front. It would also be nice to know if anyone has ever run the 'reproduction' guard liners and know whether the fitment is OEM quality or "OEM Quality". Example: https://www.ebay.com.au/itm/356254671561 https://carbonetics.net/products/nissan-skyline-r34-gtr-plastic-front-wheel-arch-set Is this knowledge still around?
    • Really, effort is pretty low. You hand fistfuls of cash over to someone else and pick it up when done...   And at least this shitbox isn't drinking coolant right?
    • And most chargers that most DIY people own would put bugger all power back into the battery between cylinders. I've always done it with jumper packs/second battery connected. And that's on any car.   Because race car, and wanting the lightness.  At least in an R33, putting a bigger battery in can at least help shift the weight balance backwards
