Are you sure it's clear coat and not from grinding?
I'm beginning to wonder this. There is next to nothing a razor blade won't scrape off the windscreen, I've used it so many times and its always worked
As suggested by Ben, if its been near any sort of grinding, the grinding sparks can melt the laminated layer on the windscreen and leave you little marks on your windscreen, which if you cant get it off with a razor blade sounds more likely to be the issue.
No grinding of any sort, car hasn't been painted as such, I sprayed painted where the bonnet hinge is and got lazy with spraying clear on the area
If a razor blade doesn't take it off then I doubt it's overspray, should come off with ease! Or try wire wool and glass cleaner another easy option!
  • Like 1
Pic of affected area after clay bar and glass polish, specks really stand out when driving with direct sun on windscreen
Not overspray mate that's for sure, looks like tiny chips I had a 200sx with the same thing very annoying when sun hits it, can't see shit my screen was covered. Looks like your only option is new screen! :(
Use white spirits, on a rag and elbow grease
We use it all the time when vandals paint our (earthworks) machines. Works very well on glass
Do not let it touch any paint, it works like a thinner and strips paint unless its powdercoated
Or aeroguard, works aswell on paint on glass
    • Skyline R33 Series 2 sedan tail lights in excellent condition. These are becoming harder to find, especially in this state.    BOTH SETS ARE IN FANTASTIC CONDITION (REFER TO PHOTOS)    ✅ No broken covers or cracks ✅ Lenses are in flawless condition ✅ All rear mounting lugs intact ✅ Comes complete as pictured ✅ Perfect for restoration, replacement, or upgrade   These lights are ready to go, no surprises just quality OEM parts.   These are definitely one of the better sets we have seen in a while. With minimal wear and tear they will come as you see. Bear in mind they are not brand new they are almost 30 years old now. To find them in this condition isn’t easy they can only be obtained on the second hand market.   Australia Wide Postage Available At Buyers Expense. Silver Set:$850 Grey Set:$850 PM Me for purchase or any other questions  IMG_2166.dng IMG_2165.dng IMG_2172.dng IMG_2173.dng IMG_2174.dng IMG_2179.dng IMG_2180.dng IMG_2260.dng IMG_2258.dng IMG_2259.dng IMG_2261.dng IMG_2266.dng IMG_2273.dng IMG_2274.dng IMG_2276.dng
    • Unsolicited advice? Keep the engine as close to stock as you can. Nothing wrong with adding some boost and making a little more power, but given where you are, you really don't want to try to make it into a monster. I can't imagine the roads are up to it, and the lack of locla support when it grenades will be a ball ache. FWIW, If there is a dyno around that you can access, then brand new injectors are a good idea, which will lead you to (at least) putting a Nistune in it, which will allow you to put an R35 AFM on it, all of which will make it possible to make it much much nicer to drive and live with.
    • List all of your mods. It sounds like an aftermarket ECU hitting rev limiter. Like a valet mode, or a cold rpm limiter?
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
