I have a r32 with a stagea rb25det neo.
It isn't running right and im thinking maybe the ecu has something to do with it.
The r32 is manual converted.
The current ecu is 23740 0V300
I'm sure this is the 4wd auto stagea ecu.
if my car is rwd and manual, would the ecu possibly need to be changed to a different ecu?
https://www.sau.com.au/forums/topic/449772-wrong-ecu/
That's the wrong ecu. It doesn't matter if its manual or auto but the OV300 is a Hitachi ecu for a series 1 Stagea that has the R33 engine. You need a Jecs ecu for a series 2 Stagea which had the Neo engine such as .23710 aa501 (or an R34 GTT ecu).
https://www.sau.com.au/forums/topic/449772-wrong-ecu/#findComment-7409874
That's the wrong ecu. It doesn't matter if its manual or auto but the OV300 is for a series 1 Stagea that has the R33 engine. You need an ecu for a series 2 Stagea which had the Neo engine (or an R34 GTT ecu).
Yup says ov300, that would explain why its running so crap, doesn't like to boost. If i was to get a the neo ecu, would it be hard to swap over?
https://www.sau.com.au/forums/topic/449772-wrong-ecu/#findComment-7409881
If the car runs then I doubt the ecu is your issue.
I would open one thread with ALL the information so you can get some help.
Actually, if the car runs, and is notionally a Neo engine using an R33 era ECU.....what's the chances of it being all normal stuff in there? I thought the ECU pinout was different between R33 era stuff and R34 era stuff. There are certainly different devices (like the boost sensor) on Neo stuff. If the engine is being run by an R33 style ECU, then it's quite possible that some sensors and stuff have been changed or rewired on the Neo engine.
This car needs to be put in front of an expert who can look at it all at once and work out what it is and what to do with it. These piecemeal threads on this car are not helping. Advice I gave in the other thread about Nistuning the ECU will be invalid if it turns out to be an R33 ECU!!!!!!!
Edited by GTSBoy
https://www.sau.com.au/forums/topic/449772-wrong-ecu/#findComment-7409936
Photos with rose tinted glasses perhaps?
The engine is not from a 4WD stagea. Traction control rules that out. The ECU, if the lid matches the contents, is definitely from the early S1 Stagea. That should not plug into a Neo ECU loom plug.
You definitely have some sort of bitsa going on there.
https://www.sau.com.au/forums/topic/449772-wrong-ecu/#findComment-7410399
Yea i'm really confused, what is the engine from do you know? i'm taking it a expert tomorrow
https://www.sau.com.au/forums/topic/449772-wrong-ecu/#findComment-7410403
You also have that ling long turbo.
Why so many threads on all these problems? I think guys should have one thread "my car is a mechanical abortion"
Go out and get a power fc or something tunable so that you can make it run the way it should. Unless you know you have low compression in the motor and didn't check it before purchase.
https://www.sau.com.au/forums/topic/449772-wrong-ecu/#findComment-7410529
    • But first....while I was there, I also swapped across the centre console box for the other style where the AV inputs don't intrude into the (very limited !) space.  Part# was 96926-4GA0A, 284H3-4GA0B, 284H3-4GA0A. (I've already swapped the top 12v socket for a USB bulkhead in this pic, it fit the hole without modification:) Comparison of the 2: Basically to do the console you need to remove the DS and PS side console trim (they slide up and back, held in by clips only) Then remove the back half of the console top trim with the cupholders, pops up, all clips again but be careful at the front as it is pretty flimsy. Then slide the shifter boot down, remove the spring clip, loose it forever somewhere in the car the pull the shift knob off. Remove the tiny plastic piece on DS near "P" and use something thin and long (most screwdrivers won't fit) to push down the interlock and put the shifter down in D for space. There is one screw at the front, then the shifter surround and ashtray lift up. There are 3 or 4 plugs underneath and it is off. Next is the rear cover of the centre console; you need to open the console lid, pop off the trim covering the lid hinge and undo the 2rd screw from the driver's side (the rest all need to come out later so you can do them all now and remove the lid) Then the rear cover unclips (6 clips), start at the top with a trim tool pulling backwards. Once it is off there are 2 screws facing rearwards to remove (need a short phillips for these) and you are done with the rear of the console. There are 4 plugs at the A/V box to unclip Then there are 2 screws at the front of the console, and 2 clips (pull up and back) and the console will come out.
    • So, a bit of a side trip, but one that might be interesting for people with JDM cars and japanese head units. I know @Pac previously posted about a carplay/android auto adapter he installed which used the AUX input, and @V35_Paul put in one of the Tesla style units that replace both screens. The option I went with was a Lsait LLT-YF-VER5.87_2 (https://www.alibaba.com/product-detail/Lsailt-8GB-Android-Multimedia-Interface-for_1601187633672.html). Price was $1,150 for a single unit although they are much cheaper if you are willing to buy 2....$857ea. Make you you get the version 2 not version 1, it is faster and has a better UI - this is the manufacturer listing: http://www.lsailt.com/product/348.html. BTW if you've never bought from Alibaba before, don't be concerned....these guys can't stay in business unless they are responsive, ship fast etc, they were excellent (probably faster shipping than most local places) So, this was my task for a lazy Sat afternoon....looks complex but was all done in a few hours (it probably helps that I had some of it apart before so it was a bit familiar). I also decided to add a HD USB drive recorded at the same time and the unit also supports an aftermarket reverse cam (if you don't want to retain factory) and also AV in and HDMI out It looks much worse than it is, in fact in was genuinely all plug and play (no custom wiring at all). This video was pretty good (skipped a few steps), unfortunately they are an Aussie seller but no longer sell this unit (I guess Carplay/AA adapters are easier to install and much cheaper) https://www.youtube.com/watch?v=T5hJfYOB8Dg
