Hi I'm installing a Bee*R in my auto r34 GTT and I need some help finding the correct wires to splice into. I've found pin diagrams but I'm not sure which is which and there are multiple for some. Could anyone confirm where which wire goes?
Any help would be greatly appreciated !
Black Ground 25 or 32?
Yellow crank angle sensor 1° 46
Green crank angle sensor 120° 44 or 45 ?
Red 12v power supply 67 or 72 or 80?
Here's photos of where the wires need to go
Here's pics of the pin diagram for auto r34 gtt's
post-135000-0-12747300-1414832830_thumb.jpgpost-135000-0-47370400-1414832869_thumb.jpgpost-135000-0-96711000-1414832892_thumb.jpg
Yeah I know I've read a lot of bad stuff but also know people who have them on for years and no damage. I have a warranty for my car so if something does go bang it won't f**k me too hard
Oh alright then. Well if you have anymore info on how the ecu prevents excess fuel from going into the exhaust feel free to share as I'm curious as to how it does this. And possibly the tachometer may be wrong, I'll test it out next time and see !
Oh alright thank you. Well the revlimiter has a 6500 rpm setting I could set it too for road use which will shut off ignition before the stock ecu shuts off the fuel. Also cheers for the info as I was planning on setting it to 7000 rpm. Also if you guys know how many rpm should it be set to for launch control without getting too much wheelspin ? I'm thinking between 3000-3500 ?
id hate to tell you but if you were to fit this the warranty wouldn't be worth the paper it is written on.
But if you still want it fitted and are unsure of how to do so, I suggest having a professional fit it
  • Like 1
    • Initially I thought having a pair of Recaro seats would be a big bonus, it turns out these do get a little uncomfortable on long journeys (my fault, not the seat). I had a look through the GSM Performance website at reclining seats and booked an appointment to visit their show room. I got the Recaro Sportster CS for the R34 from here, was very happy with the service received so of course a re-visit was in order. Unfortunately the two Corbeau seats I had chosen aren't on display but they had 4 other options available. Two seats dug into my back, one dug into my legs and the other was perfect. I also found out that Recaro seats use a larger bolt pattern so some adaption was required. Luckily GSM offer some universal adaptors that should solve this problem. I searched the interwebs for price comparisons and Corbeau themselves were the cheapest at £300 cheaper (for the pair). I asked GSM if they could price match, unfortunately they couldn't. I later received an email saying Corbeau would honour them the same discount, but the purchase was already made. I did however order the brackets from GSM, both arrived on the same day. I started with the passenger side seat, knowing this was going to be a little trial and error. There are 3 mounting holes at the front and 2 at the rear on these JURAN Racing seat rails.  With the adaptor brackets mounted, the allen cap bolts started to push into the seat, NOT GOOD!  The rear mounting holes lined up but there were issues at the front. The holes were 1/2 hole out, so the brackets got a tickle with the drill to modify the holes. The supplied bolts weren't going to be long enough and a spacer was needed to stop the adaptor bars from bending. A local fasteners company supplied be with some nylon spacers and longer bolts (M8x30, although these will be replaced with 35mm long shortly) A before and after I pre-drilled the front bracket before making a start on the driver's seat to save some time. And in no time at all that was in the car too. The all black seats have transformed the interior and these are MUCH more comfortable. The only downside with the new Corbeau seats is I sit a little higher, but I'll happily accept that over discomfort. The Youtube video can be found here: https://www.youtube.com/watch?v=wPyttKPktXA
    • All 3 I guess. The car came with the JASI Aero 4 door Type R Full Kit unpainted so this was one thing at the top of my list to complete then I noticed there were body panels parts for this kit so i picked them up along with some black mesh to fill in the front bumper and front side air vents. car is at a paint and body shop atm completing this work. Next I will be addressing the internal bells and whistles, great summer project I can do with the kids.  full interior removal - ,boys car sound deadening - pads and spray ,boys stereo, sound, lighting - Big 3, GTT or bigger alternator ,kids head lining - dye black add star lighting mod ,daughter. That's it for the next 5-6 months. I have some motor maintenance  work i have to plan out. oil filter relocation, gaskets, mounts. beyond that, mind is starting to turn over if i can use a DET intake plenum, block off turbo ports & pipe in a air intake.
    • roller coaster of a ride. Alarm system was removed & main harness was repaired where possible. still no fix just random successful starts. moved on to the replacing the ignition switch and relay. well all this troubleshooting & repair has been going on, the car is at a paint and body shop being pushed around. Ive been going down there on odd days after work to get it sorted.
    • 5th November if you want to come out for a spin wakfield
