hi guy i have a tonne of stuff i need to sell due to finical difficulties and i don't have the time atm to finish off this project
i have a r34 gtr Vspec 99 model rolling shell suitable for track only as i never got it complied, has no motor in it needs a little bit of work done to it to have it track ready. has no brakes, has all guards, bonnet, doors, windows, dash, gearbox, wheels, seats and interior trims. asking $15000
also have
RRR block still in plastic asking $8000
HKS step 2 2.8lt stroker kit $7000
tome oil pump brand new $2000
HKS 3037 high mount twin turbo kit $5000
brand new r34 gtr front diffuser $800
genuine vspec rear diffuser $2000
after market vspec style rear diffuser $1000
rays te37SL in satin black 19x10.5+15 with rubber on it $3200
serious buyers only don't bother lowballing me as you will be ignored.
every thing is located in Victoria
please contact me for pictures as every thing is kept at another location and not at my house so i have to travel out to get pictures
Please pm me you number for pictures, it prob can be complied if. You have time to find out, Aaron at import monster had the import approval papers for it a while ago for me but I never had time to put car back together to get it complied, please note it was about 2 years ago as well car has been sitting in my garage on pieces as I had other plans for the car
  • 5 months later...
also have
Can you send me a text please so we can discuss particulars 0422816917
  • 1 year later...
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
