First I'm going to start with restoring your headlights with toothpaste.
I'm guessing most people know about this but if you don't it's going to cost you 50c rather than a $30 headlight restoration kit from an auto shop.
If you have an old imported vehicle from japan it's most likely going to have yellow headlights. This is how you can make them brand new for next to no money.
1. Clean headlights with water and a clean rag.
2. Apply whole headlights with toothpaste
3. With rag scrub the tooth paste into the headlight trying to remove as much of the oxidation as possible
4. Clean tooth paste off with water and wipe dry
You can do this again to get them more clear if they are still a little yellow but it should work first time and look brand new!
tip - Clean one headlight first to see the difference and you'll be amazed.
(More post's to come later)
Ask to see room at hotel, steal toothbrush kit from bathroom while viewing room, then tell them u don't like 'the vibe' of the room and don't check in. Raid salvo's bin and nab old t shirt. Result, free tools for headlight mod.
But agreed, thread title could be 'broke-ass mods' or similar. Anyway, 2 faves are, plug up bypass hole in base of bov for more responsive throttle, and 3in pipe into rubber intake mods. Cheap n good.
  • Like 1
Nothings going yo make your na cat actually go better for free.
So, i actually reccomend a semi thought out hole in airbox will make some more induction noise and is free. Will suck hot air but won't matter. Will sound slightly better.
Not sure if na skylines have a resonance chamber type thing on their inlet, probably do. If so get rid of it. Car will sound better.
I cut a big slot on my R31's airbox, makes a barely audible purring noise when you close the throttle. Also makes the air filter dirtier quicker. Apart from that, no difference. In fact, complete airbox + snorkel apparently gives you slightly better fuel economy. LOL
Check tyre pressures.
I've been guilty of driving with lower than optimum pressures especially if the car sits for months at a time.
Yes! Me too. I was going to suggest buying a hand-held pressure gauge but that would make it not 'free'. :)
Take a big shit before a drive. Weight reduction ftw.
Also, diet. Save money on food AND go faster.
I've done this personally :)
Lost 20 kilos so I'm no longer a fat shit. Better power/weight ratio, fuel economy & health lol :P
But also taking out all the crap/junk that's in your car all adds up too for whatever little weight benefit it provides. At least you'll have a clean car for sexing the ladies ;)
This thread is going to provide some good laughs by the looks of it. My suggestion was what Hadouken beat me to, take off your CAT, bash it out, bolt back on. You get killa pop on the downshift sometimes and who doesnt want that?
  • Like 1
    • Hi all,  I am in the market for an R200 longnose diff out of a Z31 300ZX, or S12 RSX, DR30 skyline, or similar, in a 3.9 ratio.  Preferably a late model one with the M12 crownwheel bolts.  The only easy to find advert for one of these was my ad back in 2007 when I sold it on this forum.  I sold the diff as I had sold the car it goes to, but as it turns out, after 18 years I got the car back late last year, so now I'm looking for the diff !  If anyone knows where to find a longnose R200 LSD with the M12 crownwheel bolts, drop me a line at [email protected] - Bonus paid if soomeone comes up with the original diff (stranger things have happened !).  Cheers   Ben D
    • Hi everyone, I used to post here a bit from 2004-2013, when I owned various Nissans, in particular my S12 RSX gazelle, which was sold in 2007.  As luck would have it, after an 18 year hiatus, the car found its way back to me last year, and over the past 11 months I have had the pleasure of restoring it with my kids.  One thing that I am after in particular is a 3.9 ratio R200 LSD for it.  I actually sold the one out of the car here back in 2007 , and it would be incredible if I could track down who I sold it to, so I can see how they have progressed over the years (and to be honest, to see whether I can get the diff back !).  Anyways, hi all and let me know "where are the R200 Longnose diffs all at these days ?  Cheers Ben D
    • Arms will be the same as the G35 or 350Z, but as above, there was a change in the lower control arm where it connects to the ball joint.  That said, you can remove the ball joint cone from your old ball joints and fit them to the new ball joints.  To be honest, I didn't think the ball joints themselves were different. The main ball joint is a bit awkward to replace, you really need to remove the steering knuckle to press out the old one.  Some people have used tools to remove it in place, but it just seemed too hard to get to. If you are going to press out/in that ball joint, then you may as well just replace the bushings in the LCA and the compression rod.  You can buy the compression rod bushing from Nissan, but the LCA bushes, you will need to go aftermarket. Much cheaper than buying the whole arm.
    • Ha, well, it's been.... a bit of a journey. Things have taken much longer than I'd hoped. I'll probably put up a thread at some stage. Hopefully soon. The car's not done any kms since my update in June though, put it that way.
    • Here's the chart for fuel pressure vs. current draw, assuming your base fuel pressure is 3 bar and you run like 0.5bar boost on WOT, you should only momentarily hit 9amps here and there. (Ignore my prev post, I cannot read a chart these days it seems)
