I believe if the block is older than the car it has to meet the emission standards of the model of car its in.
ie it would have to be bone standard and im240 tested etc
doable on e85...but e85 needs an aftermarket ecu....so technically not legal.
is modified...so not legal.
but would they pick it?
it's one of those things Mafs would need to be standard. injectors turbos etc
way to much effort to have a legal rb30....which for it to be legal would make 250kw
so imo build a 2.8 or 2.9
legal in the sense of using the oem block yes.
subject to capacity limits...but not many engieers will ask you to strip and engine to check...especially as it has all the factory numbers.
usually record of capacity is only needed if you were putting a turbo ls1 or something in a 32. where a ls7 7l looks the same as a 4.8l LS truck engine
actually...has anyone checked to see if darton 90mm sleeves could be used.
use a BC or spool 2.9 crank and rods with custom 90mm pistons.
might have to be siamese bore so cooling down the back of the motor might not be great.
would make it a short deck 3015cc RB
I built a Nitto 2.8 stroker and then i sold it.. Iam now starting my Nitto 3.2 stroker build. I would only go with Nitto (for strokers) because they're local and are proven to hold massive power.
    • But first....while I was there, I also swapped across the centre console box for the other style where the AV inputs don't intrude into the (very limited !) space.  Part# was 96926-4GA0A, 284H3-4GA0B, 284H3-4GA0A. (I've already swapped the top 12v socket for a USB bulkhead in this pic, it fit the hole without modification:) Comparison of the 2: Basically to do the console you need to remove the DS and PS side console trim (they slide up and back, held in by clips only) Then remove the back half of the console top trim with the cupholders, pops up, all clips again but be careful at the front as it is pretty flimsy. Then slide the shifter boot down, remove the spring clip, loose it forever somewhere in the car the pull the shift knob off. Remove the tiny plastic piece on DS near "P" and use something thin and long (most screwdrivers won't fit) to push down the interlock and put the shifter down in D for space. There is one screw at the front, then the shifter surround and ashtray lift up. There are 3 or 4 plugs underneath and it is off. Next is the rear cover of the centre console; you need to open the console lid, pop off the trim covering the lid hinge and undo the 2rd screw from the driver's side (the rest all need to come out later so you can do them all now and remove the lid) Then the rear cover unclips (6 clips), start at the top with a trim tool pulling backwards. Once it is off there are 2 screws facing rearwards to remove (need a short phillips for these) and you are done with the rear of the console. There are 4 plugs at the A/V box to unclip Then there are 2 screws at the front of the console, and 2 clips (pull up and back) and the console will come out.
