Michael, looks like I owe you a round. I rotated the sensors and ran around the block where the error used to show in first 100 meters.
Now I need to change the connector on the old sensors and the reinstall.
Thanks!
  • Like 1
So checked the resistance on the sensors. R33 were 1.3k ohm and the R32 were 2.1k ohm. So I opted to make some 90 degree adapter plates instead of swapping the connector to put the R32 ones in.
Fingers crossed that this finally sorted it out.
Also the bolt thread are in the A-LSD half shafts where the non are in the CV
Most people would just put the diff in with the sensors that came with it so it probably hasn't been an issue yet :/
Yeah my A-LSD stopped working once I put the LSD up front, which I found out at SMSP-S last year :(
Yeah that'd be why - most just swap the entire diff.
lol - Is there ANYONE with a v-spec who hasn't gone through that agonising experience? :D
  • Like 1
Well I can confirm that the sensors have sorted out my dramas. The car ran all day Saturday at the Nulon nationals without a single Attesa error. All the rear 1.5 way goodness really helped on the wet Skidpan.
  • Like 1
  • 3 years later...
On 1/13/2015 at 11:37 AM, Pezhead said:
Yup changed my half shafts cause the alsd diff is so much wider.
What shafts did you end up using? Did you get non v-spec R33 ones. I'm just about to go through this conversion now. I have an R32 GTR diff that I am installing
Yup, ended up picking up some non V-Spec R33 GTR shafts and chucking the V-Spec ones.
    • Yeah, it's getting like that, my daughter is coming over on Thursday to help me remove the bonnet so I can install the Carbuilders underbonnet stuff,  I might get her to give me a hand and remove the hardtop, maybe, because on really hot days the detachable hardtop helps the aircon keep the interior cool, the heat just punches straight through to rag top I also don't have enough hair for the "wind in the hair" experience, so there is that....LOL
    • Could be falling edge/rising edge is set wrong. Are you getting sync errors?
    • On BMWs what I do because I'm more confident that I can't instantly crush the pinch welds and do thousands of USD in chassis damage is use a set of rubber jacking pads designed to protect the chassis/plastic adapter and raise a corner of the car, place the aforementioned 2x12 inch wooden planks under a tire, drop the car, then this normally gives me enough clearance to get to the front central jack point. If you don't need it to be a ramp it only needs to be 1-1.5 feet long. On my R33 I do not trust the pinch welds to tolerate any of this so I drive up on the ramps. Before then when I had to get a new floor jack that no longer cleared the front lip I removed it to get enough clearance to put the jack under it. Once you're on the ramps once you simply never let the car down to the ground. It lives on the ramps or on jack stands.
