I was looking at buying an engine damper for my Skyline. However had a look at where the damper mounts to the engine, and based on the pics it seems to mount somewhere on the head of the engine. I thought Engine Dampers are usually mounted close to the engine mounts, i.e the support would be on the block, not on the head.
It got me thinking, wouldn't this cause extra stress to the head bolts on the side its mounted and cauld cause a failure or damage under hard shifting conditions? Sort of like trying to Pry open the head from the block with a pry bar?
Edited by sonicz
Think about where the pivot point of the engine is and what the damper is actually doing. You are trying to take some load off the engine mounts by 'dampening' the force put on them at a higher point. When the head bolts are done up, the clamping force is strong enough that you aren't really going to bother them at all given the force exerted on them (The damper absorbs some load it doesn't act as a solid brace)
If they caused damage to the engine people wouldn't buy them and use them. As for how much difference they actually make, this I cannot tell you. I have heard some people say they are great and other say they do next to nothing. Without ever having actually fitted one, I cant really be sure
I guess you will feel a massive difference if your current engine mounts are sloppy/worn. Probably a better idea to swap them over. The engine bay is crowded enough. Don't need to ad anything unnecessary.
  • Like 1
I put in new nismo mounts, and then one of these braces, and did notice a difference with it. My car is auto though, so i couldn't say for manual, but it did get rid of some of the 'slush'. They look like a gas shock but are just a metal rod going into the tube, with a hard rubber block in the middle. So it doesn't actually move more than a couple of mm under compression and fixes the engine in place while still not making it rigid with no vibration/small movement absorption.
It looks like it bolts to the head where you would usually bolt on the engine removal hook for the drivers side. Given that when removing the engine you are hanging the entire engine (and maybe the gearbox as well) from that same point, I don't think the damper is going to give you much grief! That being said, I don't think I would even bother installing one of these...
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
    • There is a really fun solution to this problem, buy a Haltech (or ECU of your choice) and put the MAF in the bin.  I'm assuming your going to want more power in future, so you'll need to get the ECU at some stage. I'd put the new MAF money towards the new ECU.
