the championship is fixed setup, but practice by yourself you can tune them. but its pretty counter-productive if you have to go back to fixed setup when racing.
Most of the "novelty" cars you cant much beyond tyre pressure and camber. The Jetta is an example. FWD FTW. would have come first last night by like 30secs if i had that beast :P
Yeh I adjusted brake bias in practice, then checked settings in the actual race and couldn't touch it all fixed
I saw you spin out at like the turn 4 hairpin did lol :P
Game is pre hard to get used to, definitely cant just throw it around like forza
Edited by UNR33L
The spec racer ford has a tonne of lift off oversteer. You correct it by getting very slightly on the throttle when you suspect the rear's going to get loose.
Basically to get the most out of it, the way to go is either left foot braking + a smidge of accelerator, or just wuss out and brake in a straight line, heh
I presume were running the Summit Point Raceway configuration for tonights round?
thats right, summit point. Unless stated otherwise consider it full track config each round :)
An hour till practice! Think I'll be needing this extra hour to practice as well!!! Hope to see a few of you on track tonight, summit point is a great track and the racing should be fun!!! See you there from 8pm :)
So another round over and done with, and what a race it was! After 20 laps I was exhausted!!!
Anyways here are the results from the race -
11334157_10154031025974386_2476048245063
Prac and Qualifying -
11334022_10154031025969386_7357860748882
And here are the standings for the season thus far -
11407138_10154031025944386_6070696805610
Thanks a heap for a great race everyone, was more than fun!!! See you all next month for Round 7 :)
  • Like 1
    • Cheers. Skyline is back on the menu, can’t get rid of it. It’s like a child you don’t want, or herpes
    • I got back to Japan in January and was keen to get back on track as quickly as possible. Europe is god-awful for track accessibility (by comparison), so I picked up a first-gen GT86 in December just to have something I could jump into right away. The Skyline came over in a container this time and landed in early January. It was a bit battered after Europe, though—I refused to do anything beyond essential upkeep while it was over there. The clutch master cylinder gave out, and so did the power steering. I didn’t even bother changing the oil; it was the same stuff that went in just before I left Japan the first time. Naughty. Power steering parts would’ve cost double with shipping and taxes, so knowing I’d be heading back to Japan, I just postponed it and powered through the arm workout. It took a solid three months to get the car back on the road. Registration was a nightmare this time around. There were a bunch of BS fees to navigate, and sourcing parts was a headache. I needed stock seats for shaken, mistakenly blew 34k JPY on some ENR34 seats—which, of course, didn’t fit—then ended up having the car’s technical sheet amended to register it as a two-seater with the Brides. Then there’s the GT86. Amazing car. Does everything I want it to do. Parts are cheap, easy to find, and I don’t care what anyone says—it’s super rewarding to drive. I’ve done a few basic mods: diff ratio, coilovers, discs, pads, seat, etc. It already had a new exhaust manifold and the 180kph limiter removed, so I assume it’s running some kind of map. I’ve just been thrashing it at the track non-stop—mostly Fuji Speedway now, since I need something with higher speed after all that autobahn time. The wheels on the R34 always pissed me off—too big, and it was a nightmare getting tires to fit properly under the arches. So I threw in the towel and bought something that fits better. Looks way cleaner too (at least to me)—less hotboy, less attention-seeking. Still an R34, though. Now for future plans. There are a few things still outstanding with the car. First up, the rear subframe needs an overhaul—that’s priority one. Next, I need to figure out an engine rebuild plan. No timeline yet, but I want to keep it economical—not cutting corners, just not throwing tens of thousands at a mechanic I can barely communicate with. And finally, paint. Plus a bit of tidying up here and there.
