Hi Guys,
First of all i know the questions regarding these motors are all over the site, But none seem to have the information im after at the moment!
Quick run down, Car is being restored at the moment and im not dropping a stock motor back into the car.
My current spec list of the engine is
Holset HX35 Twinscroll 12cm housing
6Boost Top mount twinscroll manifold
Greddy copy inlet/HKS copy Rail
750cc Injectors (Still unsure on what to go for)
3.5" Exhaust
I will be using a Link G4 Or Haltech ECU,Fuel wil be 99RON V-Power.
For my goal of around 500HP ATF, Or possibly 450WHP say, Everyone i have spoke to says keep my immaculate bone stock block and leave it be. Dont open it if i dont have too.
Other reports say the compression is too high (9.1 Isnt high though surely??) And you need a good free flowing setup to minimize back pressure (Again as i have, Apart from say cams??)
One part of me says leave it be, and if i come into knock problems i will rebuild the head, fit cams and ARPs, MLS Gasket.
Compression wise also surely fitting just a thicker gasket will ruin the stock quench pads ability to prevent knock to some extent am i right?
What are peoples opinions on this?
Car wont be dragged, Rarely if ever tracked, Will be purely road use.
R34GeeTeeTees motor is pushing out incredible figures, and still stock block barring head changes yes?
Thanks
Toff
https://www.sau.com.au/forums/topic/452371-rb25det-neo-tuning-advice/
There is a guy running 760hp on the stock bottom end of a neo here in WA. If it is timed/tuned and maintained properly, your 450 will be fine.
I think what they are referring to about "free flowing" is the intake and exhaust. You will need a decent intake pod filter and a hi flow exhaust to make sure it can breathe because I believe the hx35 flow around the same as the gt35.
You will need to upgrade your fuel pump as well.
By near stock everything i mean the block. Everything from intake to exhaust will be new (Ie Greddy plenum, 6Boost mani,3Inch exhaust, Haltech ecu, Upgraded fuel pump, injectors, Intercooler,Custom intake, Etc etc etc)
Only thing left stock is the block.
Sorry for not explaining myself properly, All supporting mods will be there!
And thanks sleptema, 760HP On stock bottom end is insane, Have you got a link to that mate?
On that note also i have found these injectors, http://www.ebay.co.uk/itm/201145001596?_trksid=p2060778.m2763.l2649&ssPageName=STRK%3AMEBIDX%3AIT
What do people think? If i could get a set of say Deatchwerks (600cc) And a matching fuel pump i would rather do that, But these seem ideal if they fit the larger greddy plenum injector locations. Stock NEO Injectors are too short by approx 10mm, So i could mabye shorten the spacers and fit larger washers to compensate for the locators but would rather not...
Thanks
By "near stock everything" I meant, bottom end, top end, inlet and exhaust manifolds, and damn near the turbo too (as in, a decent Hypergear highflow is able to approach that sort of power!).
As to injectors, any matched set of NEW Bosch 1000cc or bigger injectors, in whatever length and o-ring size you need, will do the job. Stainless ones are the best for E85, but the older ones still go alright. Look up Scotty on here (search for Xspurt injectors) for someone (in Australia, not the UK) that you could buy from fairly easily if you want someone who damned well knows what works.
Your in the UK yeah, have you looked at the Syvecs S6, much better ECU then the Haltech and you have the joy of having Ryan G from Syvecs and Paul Blamire of Zen performance as a local tuners who knows that ECU inside out
Also ID1000s with a Walbro 460 as an intank would take care of all your feeling needs
Price up a Walbro 255 and 600cc injectors then price up the Walbro 460 and 1000cc injectors, for whatever extra if any it would be worth it to cover any future mods
Fishing meaddifore comith, my uncle once told me plenty of people catch of little fish on a big rig but very few people catch big fish on little rigs :thumbsup:
Sorry mate i didnt really think about what you said haha, Thanks for that mate. 1000ccs will be plenty of headroom, But will i need injectors that big?Surely bigger isnt better in the case of injectors? Am i right in thinking i need adapters again for these?
I am in the UK yes, And i considered Syvecs briefly but dismissed it too quickly, Just checked there website and they can build plug and play harnesses, which may be worth looking at over the Haltech/Link options!
And thats good then, was on the lookout for an intank that would flow enough.
umm ....simple 255 intank walbro , 600cc , a decent turbo , 3inch exhaust ,proper clutch and a management of your tuner choice ..no need to touch the moto .... 400-450 easily doable
Would a 255 not be pushing it though to get that sort of power?
Just what i wanted to hear on the engine part!
Hahaha thankyou mate, As commented above surely i would be pushing a 255. 1000cc injectors may be the way to go then!
  • 2 months later...
Little thread bump,
Just on with ordering bits up for the motor (Delayed i know) And currently have:
Thats were im thinking at the moment, Going for the UNOPENED Engine option as its a mint engine currently so no point in splitting it right? If the headgasket goes at a later date (Should it though if tune is correct?) I will have to put one in.
Goal for power is 550Hp At the Fly, so roughly 470Hp ATW, Or 360RWKW thereabouts.
Thanks
Toff
yeah I would personally not get fancy with manifolds and special "race spec turbos", Twin scroll and a GT35ish turbo sounds overkill and if not done right you could end with a dog of a thing when a simple stock manifold and hypergear will guarantee you results. The 3076 is king in your power range, Look up Mafia's thread, the sound is awesome.
Are you using 2 wastegates?
Edited by AngryRB
Thanks for the responses guys.
turbo and manifold I already have, Turbo was cheap at £450 new and there supposed to hit 600hp max so just a tad over my goals.
Need to dig a few dyno graphs/posts out of the turbo, supposed to be very responsive with the spec But we will see.
Will be using 1 large gate as it merges into one at the bottom, turbosmart 50mm perhaps.
what else would you change on it? 100% leaving intermale stock for now.
On the manifold point as well I thought stock was shockingly restrictive at 350rwkw onwards? Hence people killing motor's and hypergear cutting that one up and making a custom one? Twin scroll should bring the boost threshold down too.
For future reference I will put up graphs once the car is finished.
Thanks!
420rwkw (564rwhp)
Std NEO, std manifold externally gated, hyper gear turbo @27psi.
Run 420rwkw on Springy motors dyno and on my dynapack.
Credit to their work, welding is awesome (HAVOC fabrication)
id1000cc (increased base pressure)
dual walbro 400 pumps
std cams and springs
Hypergear ATR45SAT
splitfires would not hold up but D514a work fine at 0.8mm
Haltech plat Pro with wideband and flex sensor.
E85
11059493_10152601384742133_5126814348893
  • Like 2
    • You just need to remove the compressor housing, not the entire turbo. I would not be drilling and tapping anything with the housing still on anyways.
    • So, I put my boat on a boat. First of all, I'm going to come out and say it. Why is Tasmania not considered a holy goal, an apex that all road-legal modified cars go to, to experience? This place is an absolute wonderland of titanic proportions. If people are already getting club runs for once in a lifetime 30 person cruises to Tassy then I've never seemed to see it. It is like someone replaced the entire place with an idyllic wonderland for cars, and all of the people living there with paid actors who are kind, humble, and friendly. Dear god. After doing a lap of almost all of the place I've found that it's a great way to find out all of the little things that the car isn't doing quite right and a great way to figure it all out. All in all, I drove for 4 hours a day for a week and nothing broke. I didn't even need to open the engine bay. This is by all means a great success, but it has left me with a list of things to potentially address. I also now have a 3D printed wheel fitment tool which annoyingly hasn't got any threads in it to actually assemble it. I might be able to tape it together to check the sizing I actually want to use, but it'll likely involving pulling the shocks out to properly measure travel at least at the front, and probably raise the car while I'm at it, at least in the rear. I scraped on quite a few things and I'm not sure how else to go about it. I was taking anything with a bump at what felt like 89 degree angles. And address those 10 other tasks. And wash the car. God damn it is dirty. And somehow, the weather was perfect the entire time - And because I was on the top of Mt Wellington it turns out it was very much about to freeze up there. I did something I typically never do and took some photos up there in what must have been -10 and the foggy felt like suspended ice, rather than mere fog. If you own a car in Australia, you owe it to yourself to do it.
    • Damn that was hilarious, and a bit embarrassing for skylines in general 😂 vintage car life ey. That R33 really stomped. Pretty entertaining stuff
    • Hi, I have a r32 gtr transmission. Does any of you guys have an idea how much power it will hold with the billet center plate and stock gearset? At what power level and use did yours brake with or without billet plate? Thanks, Oystein Lovik
    • Saw this replica police car based on a Mitsubishi Starion XX parked next to a 'police box' (it's literally a box) in Hirohata, Himeji City in Hyogo prefecture the other day. It's owned by Morii-san who is a local Mitsubishi Starion enthusiast. According to a local radio station blog post, he always wanted to make a police car himself based on ones he saw in his favourite Manga comics.  As it's illegal to modify a car to look like a police car and drive on the road, Morii-san tried many times to get permission from Aboshi police station headquarters nearby. They refused initially by after they got tired of that they granted him permission. However, the car can only be displayed on private property and obviously can't be registered as long as the police livery is present. The car was completed at a cost of 1.5 million yen (US$ 10,000) in addition to the car cost. A location was chosen outside Hirohata Police box where the car can easily been seen from the street. Morii-san has two other Starion road cars, both widebody GSR-VRs.
