When wise people dont have what to tell,they just dont speak,i think you are not one of them.
Already found some info,that with this ecu car runs around 350-400hp,so it means that i need to throw it away?i dont think so
thats what i did today,was making topic yesterday,thinking,that somebody have exactly same ecu and can share info.Ofcourse my tuner said that standalone is the best,but he said also that its a good start with that ecu aswell,cause my funds wont let me standalone right now and i got this ecu for free
http://www.sau.com.au/forums/topic/130685-blitz-access-ecu/
Quick google search revealed this from 9 years ago.
As Benny said. What's it tuned for?
Looks like it's a "remap" of god knows what. How does the ecu know what YOUR car wants/needs?
Ditch it, get a decent ecu and don't do things twice.
gave this ecu to my other friend,who has R32,but with R33 GTST engine and harness,we have driven a bit and he told,that he feels a big difference,than stock ecu,he has big FMIC,3" exhaust,a bit bigger turbo than stock with 1 bar boost,Pink AFM,cold intake,Walbro fuel pump,almpst everything,what Blitz states has to be added for that ecu,we will try to go on a Dyno day,which is every saturday,so we can check what is what
what you mean?the car was runing very good,he has all wideband stuff and gauges in the car,so we see,that A/F ratio is very good,its even more rich,than with stock ecu,what is good and safe,detonation gauge shows no signs of detonation,we are not noobies in the cars,so dont think that we are doing everything blind
Your arent noobs but ask some seriously noob question about a random ecu...
Even more rich than the stock ecu is mental.
Is your detonation gauge set to the correct frequency? Do you know what pinging sounds like?
Good luck with it all.
i dont think that its a noob question to ask if somebody had any experience with such ecu,to share experience.Detonation gauge we use is from pro race,a lot of guys in my country use it in profesional sport,so i trust it 100%.With rich fuel,i mean,that we already see,that fuel map in this ecu is set for more fuel,so basicly its always good in hard driving to be in safe A/F ratio
Ok.
You are silly to trust a gauge 100 percent.
They need to be setup to detect the correct frequency based on bore size. Get that wrong and it won't work correctly.
One more time. Do you know what pinging sounds like?
More fuel than stock is crazy. Not good.
At the end of the day, if you are happy and the car runs for a while that's all that matters.
Please update this thread if you have any issues with the car.
Edited by Ben C34
So you call all these profesional guys that installed this gauge stupid? Interesting, you even dont know how they are good and you talk like this.Gauge is set correct way, i am 100% sure, they know their job.You should know, that in drift,guys run fuel maps at least 11 a/f ratio, to avoid detonation, and our a/r is around 11.5/12 on fool load, I am really sure that its not too rich, we run our other cars same way with standalone, other thing, when you use car only as a daily.
Pinging, I dont know that word, can you explain?
    • Forgot to include this but this is the mid section of my steering rack that looks like it has a thread/can be turned with that notch mentioned in the post:
    • Hey everyone, Wanted to pick some brains about this issue I'm having with rebuilding my 33 rack (PN is 49001-19U05). All of the tutorials/videos I've seen online are either R34 or S Chassis racks which seem to be pretty straightforward to disassemble but this process doesnt carry over to my rack. Few of the key differences that I've noted The pinion shaft on the other racks bolt on with 3 torx bolts: Whereas my rack bolts on with 2 allen head bolts: These changes are pretty inconsequential but the main difference is how you pull the actual rack out of the housing. The other skyline/s chassis racks can be taken out by tapping the rack out of the body with a socket and it just slides right out. I'm unable to do that with my rack because there's a hard stop at the end that doesn't let the seal/shaft be tapped out. Can also see a difference in the other end of the rack where mine has a notch that looks like you're able to use a big wrench to unthread 2 halves of the rack whereas the other racks are just kinda set in with a punch. My rack: Other racks: TLDR; Wanted to know if anyone has rebuilt this specific model of steering rack for the R33 and if there were any steps to getting it done easier or if I should just give this to a professional to get done. Sorry if this post is a bit messy, first one I've done.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
    • Can I suggest you try EBC directly again and link them to as many competitor catalogues as you can to show their listing is incorrect, eg https://dba.com.au/product/front-4000-series-hd-brake-rotor-dba42304/ If you have access to an R33 GTST VIN and your VIN, you could also use a Nissan Parts lookup like Amayama to show them the part number is different between 33 GTST and 34 GTT which may get their attention
    • So i got reply from EBC and they just this site where you can clearly see those 296mm fronts on R34 GTT. I send them photos and "quotes" that 296mm are not for 34 GTT and they are too small. But it will be very hard to return them cuz nobody here knows 100% and they just copy those EBC catalogue :-D https://ebcbrakesdirect.com/automotive/nissan/skyline-r34
