Hey guys.... ive done some searching but unable to find an answer..hoping someone will know
Im running a r32 with an exhaust and airfilters.. pretty much stock...
I have remove the boost resrictor and running 14 psi perfectly for the last 4 months
I install a power fc (afm model) yesterday and the car wont boost past 5psi... any ideas?
Thanks
Justin
https://www.sau.com.au/forums/topic/452479-power-fc-r32-gtr/
What he said ^.
I would say, given the unknown origin of this PowerFC, we will assume for the moment that it is 2nd hand and has a tune in it for some other car. It could be set up for massively different sized injectors to what you have (ie they'd likely be larger than yours) and so your mixtures and quite possibly your ignition timing would be waaaaaaay wrong. If you starve an engine of fuel that badly, be thankful that you only managed to get it to 5 psi and didn't burn through something.
  • Like 1
R32 GTR runs 10psi actuators standard, which means the MIN boost to open the gates is 10psi.
Doesn't matter what setting a boost controller has, so unless the gates are powered by an external air supply the min they'll open at is 10psi.
I'd be looking at tune, do a data re-init and start again.
I'd check the opening pressure of your actuators too, might have some dodgy actuators fitted.
Boost on.
Don't worry about the fact it could have a totally gumby tune in it. what's a dyno run vs engine rebuild cost analysis?
Did you ever think it could possibly be a brand new untuned PowerFC that only has the base map on it?
A base map is so you can drive it onto a dyno and tune it properly
It is also possible to reset a second hand PFC back to a clean base map
Yes - DATA INIT on ETC menu
btw, if everything else on your car is stock(ish) you can drive with that PowerFC base map as long as you like, it wont hurt anything as its set up for stock injector sizes and stock timing.
No mate, but out of the box its looking for the Apexi boost control Kit which isnt installed.
Justin turned off the option and his car is now going ok :)
Similar thing happened when I put a PowerFC on my RB25
    • Hi everyone, I've been wrestling with this for a while now and have been trying to find out the cause. For context, the turbos used are Garrett 2860 -5s, the BOV is a BNR32 HKS SSQV IV kit, the car is currently tuned to ~470 whp on 17.5 psi. The car drives normally, pulls well when it doesn't happen, and I can replicate it fairly easily. It does not sound like turbo shuffle or flutter. The engine has only a thousand or so miles and has had this behavior since it was completed. After my engine was built for my R32 GTR, I noticed that the car now sometimes makes an air discharge sound on what appears to be positive boost pressure that sounds really similar to a BOV. I had thought that it was a BOV issue but even when replacing it with a brand new unit, the sound persisted. It seems like it's coming from the passenger side but I may be mistaken. The closest scenario I could find was this post here https://www.gtr.co.uk/threads/maybe-a-boost-leak-opinions.147955/https://www.gtr.co.uk/threads/maybe-a-boost-leak-opinions.147955/ started by @yakshii and it sounds very similar. As in, at partial throttle once I reach positive boost I begin to hear the same psh psh psh psh psh sound like air is leaking somewhere when I keep the throttle in the same position. It most commonly happens in 4th gear at around 3-3.5k RPM and 5th gear around 2.5-3k RPM, which seems to coincide with normal positive boost thresholds. It might be similar to what @Austrian GTR mentioned about his own HKS SSQV. Notable difference would be that when he applies more throttle when it happens, it stops. In my scenario if I apply more throttle during this repeated psh psh psh sound, the cadence of the sound gets faster and louder rather than stopping. If I lift off slightly and apply throttle again, it will normally stop and pull without issue. I've checked all rubber couplers to ensure that they are tight, but have not gotten the opportunity to properly do a pressurized boost leak test. If anyone has had similar experiences or thoughts on what might be the cause, I'd be very keen to hear them. I also have a video of it happening from inside the cabin, if that would make it easier to understand: https://youtu.be/2zqZXcx8jbA
    • I'd want at least $40K for mine, but thats easy to say cos I'm not selling anyway.
    • That's incorrect. We have 4 seasons, consisting of pre winter, winter, post winter and a small glimpse of hope!
