Hey guys, Just sharing some info and pics on my new car. Since I got into japanese sports car ive always had a soft spot for the 32gtr. Ive owned a couple of s15's , 180, xr6t, vl turbo, couple of ke70's so i figured it was time to give the gtr a go. I searched for a couple of months locally but didnt really come across anything I was overly happy with so i signed up with IRON CHEF imports and the search began. I realised it was probably going to take a little longer then i had thought to find a decent 32 so i began looking at 34's as they are considerably cheaper in japan but after getting one inspected and missing out on it i soon realised i wasnt going to get a high quality 34 with what i was willing to spend. Then i came across the car i now own, was a 4b with 83,000km , no rust, one owner, came with some history and manuals and was in great condition with no rust. Had it inspected, made a bid and won :)
1994 BNR32
Tomei TRB500 crate engine
Rays TE37 wheels
OHLIN suspension
Apexi cat back
Unknown front pipe
HKS oil cooler
HKS intake
ARC radiator
Greddy exhaust temp guage
HKS boost guage
HKS boost controller
The car is a daily but will be tracked on the odd occasion so keeping it fairly mild. General plans str to give it abit of a tidy, the front bar could use a respray and the engine bay has some oxidation going on which I want to clean up, also probably re route the oil cooler to neaten up. Once that is done ill start with some mods.
It did come with a Tomei crate engine which i have some rough info on although im not 100% sure. Here are the specs i got from the internet.Would appreciate it if anyone had any more info on these?
Bore & Stroke φ86.5 × 73.7
Emissions 2597cc
Compression ratio 8.3
Maximum output of 500PS / 7500rpm
Maximum torque 51.0kgm / 5500rpm
Supercharging pressure 1.2kg / cm2
TOMEI Forged Pistons
TOMEI piston ring
TOMEI metal connecting rod
TOMEI Ponkamu A type (In260-9.15 / Ex252-9.15)
TOMEI valve spring
TOMEI valve guide
TOMEI Metal Head Gasket
TOMEI 555cc injectors
TOMEI ECU
TOMEI fuel pump
TOMEI oil gallery orifice
NISMO thermostat
TOMEI oil pan baffle plate
  • Like 4
https://www.sau.com.au/forums/topic/452815-jasons-r32-gtr/
Thanks mate, its fairly neat, the interior is excellent aswell.
Plans are to tidy the engine bay up, respray the front bar due to a couple of marks and i want the n1 vents put in then once thats all done ill be buying some parts. Ive got a Bride ViosIII to go in from a previous car. Coilovers, HKS Kansai front strut brace, fujimura auto wing extension, ab flug front diffuser, are a few things i want first and then ill go for some performance upgrades down the track.
Edited by jaysevu
https://www.sau.com.au/forums/topic/452815-jasons-r32-gtr/#findComment-7463112
scrap that, hks changed their availability on the hipermax's so went with tein monosports 10/8 .. a little firm but i dont mind that.
I picked the car up from compliance mid week, the clutch needs replacing asap so ordered a Nismo super coppermix twin plate. Initial impressions of the car are great, love how planted the gtr feels compared to my s15. It feels quite quick too so pretty interested to get in on a dyno and see what the tomei motor is putting out.
Heres a pic of my previous and s15 and the black one is my first one i had years ago.
https://www.sau.com.au/forums/topic/452815-jasons-r32-gtr/#findComment-7470964
can confirm the car does have HKS turbo's .. pretty sure they come with the tomei motor so im assuming theyre HKS2530 .. having trouble figuring out how to set the boost on the HKS evc3 but running 0.6 bar atm and it feels fairly quick.. a little laggy tho.
https://www.sau.com.au/forums/topic/452815-jasons-r32-gtr/#findComment-7471785
front guards arent rolled nor have liners been removed but its not very low. It was scrubbing in the front at that height so ive got other wheels on atm untill my coilovers come. Ill probably get the guards rolled.
Yeah as am i :) The spec sheet i got states a Tomei ECU but i dont know too much about it. Haha ill be keeping the standard seats in for daily duties.. the bride is way too annoying to get in and out of!
Thanks mate, as does yours.
https://www.sau.com.au/forums/topic/452815-jasons-r32-gtr/#findComment-7473025
I run 18.9.5+12 (Te37's) as well. I've got guard liners and no scrubbing.
If you're talking about handling, going via those pictures, your car is too low at the front anyway.
Car looks to be in great condition, congrats.
https://www.sau.com.au/forums/topic/452815-jasons-r32-gtr/#findComment-7473087
yeah the fronts way too low although i actually dont mind the front rake look but not to this extreme.. i dont plan to run this car very low but have some tein's on the way so ill even the height out.
Cheers guys. Yeah i regretted selling that s15.
https://www.sau.com.au/forums/topic/452815-jasons-r32-gtr/#findComment-7473603
yeah i know im going to have real trouble parting with mine if i can bring myself to do it and change to a bnr34. If only i was mega rich and had a property with a ten car garage. le sigh
i could be wrong but im pretty sure when you have the ride heights correct eg sydneykid spec you iirc end up with a bigger gap between front tyre and guard than you do at the back. We all know looks are greater than handling though especially on a street car haha
https://www.sau.com.au/forums/topic/452815-jasons-r32-gtr/#findComment-7473694
Spot on :)
https://www.sau.com.au/forums/topic/452815-jasons-r32-gtr/#findComment-7473854
    • Oil change does not trigger code 21. Code 21 is for coilpacks primary side connection. You can try to clear the code with a battery disconnect, hold down the brake pedal to drain capacitors through the brake lights with the ignition on for 10-15 seconds before you reconnect the battery. I have seen R35 coil conversion permanently cause this code with no ill effects so it might be the resistance it wants to see isn't quite right on one or more coilpacks. Could be inside the ECU, could be the harness, could be a coil. You can test it all if you want or just ignore until the car actually starts misfiring.
    • I forgot you have a Nistune ECU. Use Nistune to do all the tests I mentioned instead of faffing with 30+ year old electrical connectors. You can read MAF volts off that too, there are reference values in the service manual to tell you roughly what it should be in different conditions.
    • No. I think it might be the AFM. Hence the use of the terms "swaptronics", which implies the use of swapping out electronics for the purpose of diagnosis. It's about the only way to prove that a small/niggling/whatever problem with an AFM or a CAS or similar is actually caused by that AFM/CAS/whatever. A known good item swapped in that still gives the same problem is likely to be caused somewhere else. They're all the same. Spraying AFMs with cleaner is an each way bet between cleaning it and f**king it.
    • Oh wow! This might actually work amazingly. Do you know the ratio of the diff? I was told the only thing you need to make sure of is if the front & rear diff ratios are the same. Ours is a 4.083 Thanks!
    • You think its the AFM? I know its a common issues on R32s. I find it coincidental how this issue raised right after cleaning the fuel system. As everything except the fuel system was fine before. I tried running it with the IACV unplugged but did not notice a difference and still stalled. However, the RPM gauge is not in the cluster right now, so I will need to connect the laptop again and use Nistune to check the RPM. I will check this weekend.
