Looks quite nice, im starting to get old enough I appreciate the retro style of keeping someone original even if it does look as good.
I was trawling the cars for sale and I notice you posted on quite a few r32 gtr for sale threads before you got this one. Congrats on finally having her in the garage
haha, yeah i bugged allot of people.
im amazed i actually ended up buying in adelaide tbh.
now im pestering all the for sale threads :P
Edited by GH05T
  • Like 1
i have a 32GTR also that i am restoring
Regarding your HICAS issue - sounds very similar to the issue i had. Do you have an aftermarket steering wheel by any chance? If so you may have the wrong boss kit which is incompatible with the hicas clock behind your steering wheel
In my case fitting the correct boss kit and aligning the steering wheel and hicas clock correctly fixed my issue. My HICAS light would come on exactly after 10kms of driving on the freeway
Jase
Thanks jase. Tested this today. Reset the counter and yup, bang on 10km the light pips on. New wheel should fix.
hit the paint on the bonnet today,
the bonnet particularly had been buffed or something before and had allot of swirling.
the paint was smooth after a good clean and the claybar but harsh big swirls.
this is a photo after the claybar where in this light you can really see how bad the bonnet was.
25ab3a05-2a2e-48d5-9661-c840017bcd62_zps
i did try quickly with the electric buffer but the pads old and i didnt want to balls it up so i went back to hand for this one.
not sure how well you can see it but what a difference after just a quick cut.
cut on the left vs uncut on the right.
finished it off with some good wax. soooooo smooooooooth but also nice and deep., cant wait to get some more gear for the rotary buffer and go over more of the car but happy the bonnet is now done. luckily this was the only panel which had this much swirling.
Edited by GH05T
  • Like 1
it seems i still have a coolant issue to chase,
seems to be either the same small line at the back of the engine has let a clamp go, or something similar.
cant quite see with the car on the ground but its right up on the head.
always the way with pressurized cooling systems, fix one week link and wait for the next to go.
decent amount of coolant coming out too.
possible suspect.
  • Like 1
As suspected the coolant leak was the next link in the system, damn heater hoses at the back.
One has gone, the other looks aged. the third looks ok but im not pulling the manifold of to do only 2.
annoying thing is two are out of melb stock but the third is out of japan apparently...
good news is, seeing as we are taking the manifold off anyway it gives me a good excuse to have the throttle body linkages all adjusted and set correctly to bring my idle down from the slightly annoying 1200rpm which has been bugging me.
cars off the road until these damn hoses come in.
Grats on the purchase and I'm sure you'll get great enjoyment for years to come.
I've had mine for about 5-6years now and had been in storage for the last year, getting some work done and back will be back in my hands shortly.
I recently put on a set of RPF1's 18x9.5 +15 in matte black (car is BNR32/KLO) and they look great. If you need any pics for fitment/etc feel free to PM me as I pestered alot of guys on here before I put down the money.
Mine will be a daily soon
  • Like 1
Always a good idea to have some pressure testing equipment in the garage and give the cooling system the odd test. Doesnt hurt to get it up to temp either and give the top radiator hose a sqeeze and see if the radiator cap is still working and holding pressure.
basically the same as what i will get except silver.
there seems to be a few places doing cheap deals on them brand new too.
You could go wider depending on what you wanted but that'll need work and won't be stock styles as you've mentionned earlier in the thread.
I think 9.5+15 are a pretty good fit. Pulled out my guard liners for now, might put the rear half on later...
Think it was around $1.6k iirc or something like that, could be cheaper now etc
heater hoses done, they managed to get to them faster by removing the brake master,
haven't tackled the throttle linkages as we didn't remove the intake plenum but were gonna do that at the same time as we do the timing belt and squeaky tensioner.
will probably dyno and up the boost at this point.
    • So stock ECU does not like anything above 10 psi?  That Nistune one is just for "try" if it will be any different, I know it need to be tune for that. I know but YOU may know about these problem but i/we dont. They few little Skylines here let alone people who know anything about tham so that is why iam asking here
    • So now we have a radiator with no attachments whatsoever. It lifts up with a particularly tight spot between the drivers side air box mount and the lower radiator outlet, but if you've got this far you will sort that too. This is the lower mounts with the rad out so you can see where the rubber bushes go, it is a straight shot upwards Done! Assembly is the reverse of disassembly, with blood less likely to be shed.
    • Right, onto the second last trick. The Air Con condenser is mounted to the front of the radiator and stays in the car when the radiator is removed. There are 2x 10mm headed self tappers holding the top of the condenser to the radiator, remove those The bottom of the condenser is attached to the radiator with clips. You need to lift the condenser out of those clips and clear (up, then forward). f**ked if  could work out how to do that last bit with the front bumper on. I hope you can, and you share the trick.  Bumper removal probably deserves its own thread one day once I've recovered the will to live, but basically you need to remove the wheels, front inner guard liners (clips and 10mm headed bolts), the self tapper between the guard and the bumper at the rearmost point of the bumper (same as an R32 that bit), any remaining clips at the top/front of the grill, an absolute bastard design with a plate that holds the top of the bumper above the headlight each side (only 1 bolt which is tricky to get to, but the plate catches 2 places on the bumper and must be removed....carefully!) and push clips between the bumper and guard under the headlight. If you've done all that you will be faced with wiring for the fog lights on both sides and in ADM Q50 RS at least, 4 nasty tight plugs on the driver's side for the ADAS stuff. So, the clips at the bottom look like this on drivers side (looking from the front) And on the passenger side (also from the front), you can see this one is already out Clearance on both of these are super tight; the condenser needs to move up but the upper rad support mount prevents that, and the radiator can't move down far because it is (rubber) mounted. Once you achieve the impossible and drop the condenser off those mounts so it does not stop the rad moving, you are good to go
    • OK, next the shroud needs to come off and there are a couple of tricks. Firstly, there is a loom from near the passenger side headlight to the fans, coolant temp sensor etc and there is no plug to undo.  In my case I was OK to leave the shroud on top of the engine so I just undid the passenger side fan plug and about 10 of the clips which gave enough free wire to put it aside. The fan plugs were super tight, the trick I used was a small falt screwdriver to push down on the release tab, then a larger flat screwdriver to lever the plug out of the fan unit....be careful with how much force you apply! If you need to remove the shroud altogether for some reason you will have to deal with all the plugs (tight) and clips (brittle)....good luck. I removed all of the clips and replaced them with cable ties that I will just cut next time. Also, in the Red Sport / 400R at least, the intake heat exchanger reservoir hose is bolted to the shroud in 2 places with 10mm headed bolts; so remove them (the hose stays in the car; no need to undo it at the t fittings down at the radiator lower mount. Once you've dealt with the HX hose and the wiring loom, there are 3x 10mm headed self tappers holding the top of the shroud to the radiator; remove those.   The shroud then lifts out of the bottom mounts where it sits on the radiator, up and onto the engine out of the way. Simples
    • Ok, disregard my “rate them” comment, sorry for my unrealistic input
