woohoo cars developed a missfire which rapidly became undrivable when warmed up.
possibly head gasket/ fluid in cylinder type thing...possible coilpacks...possible ignitor.... possibly just the wrong temp air in that part of town...ok now im just hoping for the best.
*BACK TO THE SHOP*
nanananaNANANANAnananana
Edited by GH05T
ok good news. heads fine. coolant looked a bit... off colour so well flush  it and keep an eye on it. you never know their might be an underlying problem but for now she's running sweet again.
im over spitfires and ignitors so I'm now running R35 packs. much simpler. problem solved. cheap outcome is a good outcome.
now back to working out how much to spend on bushes and coilovers.
My vote MCAs.
I went over the top, put MCA reds in my 33, Josh at MCA tuned the valving for me after a chat about what i wanted.
Took all of the sketchness out of bumps on hills roads like up to Lobethal that my old Tiens had. Feels stable in the corners but doesn't jar the spine on Port Road. I'm sure their street options would be just as good, but perhaps give them a call to chat.
They're also perfect for sitting in the garage with engine out too, sigh.
  • Haha 1
  • 1 month later...
odd question, my collant is overflowing normally into the overflow tank when the engin is shut off but its not drawing back in when cooling.
imusing a 1.3kg cap which is the highpreasure cap, is this likley to cause an issue for basic driving? shoudl i revert to the nomral 88kpa cap?
Awesome build!
Sounds like a lifted head or gasket not sealing somehow. To exceed that cap pressure you'd have to really be running that motor hot and I don't suspect you are. A lifted head or bad head gasket seal will push coolant like that at operating temp and pressurize the system. When the motor cools the pressure is still there because it wasn't caused from heat in the first place. Are your rad hoses rock hard after you romp on the car a bit?
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
