Hey guys,
I have currently got an R32 GT-R on the way from Japan and I received photos of it sitting at the port.
One thing that worried me is that the car appears to have very little fuel in it. Pictured below:
I'm just wondering, if cars are this low on fuel do they actually fill them up enough to continue driving them or do they just decide to let it run out and then move it with a forklift? Really worried about the sills and rails being damaged as I have heard that they arent that careful when it comes to those kind of things :(
Thanks guys.
  • Like 1
I know when I imported my boat from America, it had about 150 ltrs of fuel (half tank) customs did not like that and almost got a fine, got let off because it was my 1st import.
Because it's only needs a small amount, just to drive off n on and to yard max 4 to 5 km depending on location.....
But that'was my boat hope it helps.
Never imported a car, I hope I will in a few years.
Let us know how your experience went.
Edited by pol1on1
Personally, I'd expect it to be shipped with minimal fuel.
I seriously hope they don't use a forklift at either end like they used to back when.
I'm sure during your search locally (Aus) you would not have seen many without marks on the sills or rails.
Speak with your importer.
Damn it looks so clean. Congrats.
Edited by Sinista32
My r34's low fuel light was on after the auction & before it was driven on the boat .And it was still on when i picked it up from compliance 10 weeks later.post-93096-0-64185700-1345286175_thumb.jpg
Compliance workshop might have put some in some in. I have jusr heard that they don't do that at the port.
Just picked up a V36. Compliance put in 10L in, enough for me to drive to a fuel station and put in a full tank.
Picked up 2 Evo's last year. Both did not have any put in but still had fuel light on and I had to limp 2-3km to fill up.
I think that's how it normally is?
Not so much worried about compliance. It's more when it's at the port. I have heard they use forklifts to move them around.
Yes forklifts smash the chassis rail like pancakes , then car is worthless , i also had seats , steering wheels , gear knobs and floor mats all swapped over for hacked up ones during storage/shipping .
Edited by NISSAN GTR
Or you could get the rails repaired.
My had something sharp used to take the badges @port in Aust, metal valve caps removed, rear boot clips taken. But that was in 2004. I'm sure the wharfies are much different now.......
Mine was imported late last year with zero fuel but the car only did 4km between the pre-purchase inspection and me picking it up from compliance. No damage to rails or anything but i did lose the contents of the glovebox somewhere along the line!
From my experience with equipment found at wharf facilities, their forks would do no damage to chassis rails.
A fork that can hump a 20t container is big gear with massive tynes that offer a huge area to spread the load, far greater than say, a tyre changing shop's air operated jacking equipment.
But once the car is shipped off to a road transport company, the size of the fork drops dramatically and these are the machines that might damage rails. (especially if the rails were suspect to start with)
Car haulage companies aren't keen on cars like Skylines which don't have the front bar clearance to clamber up their ramps so they often get forked onto the single vehicle spot above the cab.
You can be lucky, your car may still have the wedges in the front coils.
These raise the car's front eliminating problems for the drivers shuffling vehicles to/from the ship.
  • Like 2
    • Thanks mate, couldn't find in VIC, ended up ordering one from NSW, getting rwc to get new plates and registration done.
    • Before all the EFR fan boys come in, have a look at: https://www.garrettmotion.com/racing-and-performance/performance-catalog/turbo/g-series-ii-g30-825-58mm/ It also comes in a T4 1.06 divided housing. I would dare say if you want response & also decent power, this thing would chop.   AND apologies, just re-read your post, you've already bought the turbo... whatever you do, make sure you stick with divided housing and proper twin scroll manifold.
    • People have got to stop doing that. ShatGPT is not a search engine. It is a hallucination factory.   I also would recommend the 1.05. The .83 will "work" for you , in that it will be more responsive, but I think you'll find that it won't be anywhere near as good running it out to 8000rpm as the big housing will be.
    • Decided for the first time ever I would tow my car TO the track day on the same working theory as bringing tools and spares "if I have it I wont need it, but if I leave it behind i will 100% need it" all setup and ready to go out and try these A050 for the first time First session showed I needed to stiffen up the dampers a touch but still managed a few 1:21's without much effort. things were looking good. Came in a dropped the tyres down  to 26/28 as they had gotten to 35/33C from 22C cold The first lap of session two I managed to drop into 1:20's. Then in the second lap into the second session. Coming into T3 and I suddenly lost brake pedal followed by some huge rear end vibrations and scraping sounds. Got it back into the pits after session ended and found this. in the attached video, all of the wobble is in the hub its self, wheel is mint, and bearing feels tight. lKXLqpd - Imgur.mp4   Deciding it was a bent spindle I tried to find bearing/hub assembly locally but was unsuccessful so it was loaded back onto the trailer i luckily brought it on to drag it back home
    • 1.05 you’ve gotta let it breath
