  • 8 months later...
Update time! Engine is running again and I changed a few things up while it was apart:
  • Switched to a Hall Effect setup for timing, very similar to the setup @HarrisRacing has (Thanks again for the clarification on the wiring mate)
  • Running a Holset HX40 from TurboLab instead of the ProBoost GTX35
  • Had the head ported while it was off
  • Degreed the cams
  • Drilled out the oil drains to 10mm
  • Made a swirl port and larger header tank
  • Working speedo and a battery isolator
  • Threw in a NPC clutch
Heaps of other little things went on but those were the big time killers. Anyway, onto the pics
Before fitting the new pump I picked up a busted one for free, which I used as a template to make a bracket for the crank trigger (busted pump not in pics)
Took a couple goes to line everything up and still have it clear the balancer, but I got there eventually
Tapped a M12 x 1.0 thread into the left support bracket, and just using the 2 supplied slim nuts on the other; all with Loctite.
That 12T wheel is from Hi Octane Racing
About 2-3mm clearance for the balancer at the closest point
The guts of a gutted and free CAS housing rocking a GT101 sensor
Managed to use all of the existing bolt holes to secure the sensor itself and fitted the other one just to keep water and whatever else out.
Only needed a bit of smoothing out with the die grinder to get it to sit level. Then chopped up a bit of 6mm plastic to secure the body of the sensor and clamp everything down; again Loctite on everything.
Didn't really get any pics of the bolts on the cam but it's basically the same as Harris.
Grinded down the standard bolts, then got a longer M7 bolt and spaced it out with one M7 nut and 2 (from memory) 1mm washers. All with Loctite and also grinded the bolt face smooth so the letters aren't causing dramas.
More for my reference but I'm sure someone else might find this handy.
Header tank and swirl pot ready for paint. Already made the brackets and made sure they'd fit, also leak checked.
These were more of a welding practice project but I'm happy with how they turned out.
Fair bit bigger than the little cylinder ebay items and used all the available space without going too crazy. I have all the dimensions for this if anyone wants them.
Swirl pot sitting pretty too. Does clear the bonnet, but only just haha
59e6d325b0416_WP_20170923_19_03_13_Rich(2).thumb.jpg.05f5a188953eae4567886f19d5d051da.jpg
Using a Acewell 3100 dash for tacho and speedo, this is the supplied speedo sensor fitted up off the tailshaft centre bearing.
Had to cut and tap a sleeve for the magnet to sit in, probably would have flung off otherwise.
Got it to within 5k's for the moment, will dial it in a bit more at the next track day.
Holset HX40 sits very nice in the bay, only needed to change the oil drain a tiny bit for it to fit up
Most of the hard work done
Finally fitting up the BOV, welds slowly improving too :)
All finished!
For now anyway
  • Like 4
  • Thanks 1
Works a treat and can't complain for only $400
Basically the closeness of the turbine blades to the housing is what grabbed my interest, the old turbo had an easy 5mm gap. See vid below for what I mean.
A few other things went into my decision but compared to the old turbo, this Holset is better all round.
Old setup on the left, new on the right.
Boost coming along a lot earlier despite the turbos being very similar in wheel sizes.
Admittedly the head being ported would have had an impact in this as well, but not nearly 1000rpm worth.
Also the hall effect sensors have visibly cleaned up the power curve.
FYI, I rate PITS and ASG very highly. This pic is not about comparing the 2 shops, simply observing the difference in engine behaviour between my 2 setups.
22251138_10155569798626655_2081988257_o.thumb.jpg.0b3a7cd9361665dbc6dc65b35cd8de12.jpg
  • Like 1
Looks good! But are you going to screw more into it? If not why such a big turbo for power a gt30 can easily make with a lot better response?
Edited by klutched
It's all set for E85, so once I commit to that it will really shine
But at the moment going to E85 is a bit of a pain and I'd like to have a better clutch and the GTR rear end fitted ahead of time, which is more money and time.
I just want to drive the thing again for now
  • 2 months later...
Hey mate just on the diff ratio youre using, does it feel spot on or do you think something a touch shorter like a 3.7 would be perfect? Im about to put a cd009 in my rb25 r32, from what iv read the gearbox ratios are nearly the same as an r34 gtr 6 speed and they use a 3.54 diff ratio i believe
Edited by Nistico
Spelling error
Yeah a 3.7 or 3.6 will definitely be the sweet spot for it IMO
On ‎22‎/‎07‎/‎2016 at 8:14 PM, Yonz said:
Also... Left is my setup with 350Z box, right is standard R33 gtst
5791f1ceb1142_350ZvR33.thumb.jpg.326ef79
Edited by Yonz
Quote and attachment
    • I certainly fall into the annoyed camp, but glad to hear that if it's happening at low boost then I'm not likely going to blow a turbo and end up with metal shards in my oil. Just feels like it prevents me from really driving it without hesitation and "peak" performance. Wonder if it's the VCAM, it did an impressive job of shifting the torque curve and faster spool, but maybe now it's "too fast" and there's too much air for how open the throttle is.  Based on some other threads, will also do some reading on synchronizing the actuators. They are the default actuators that come on the Garrett's and I would think they would be set the same coming from the factory, but if the turbos don't actually work exactly the same way at the same time as previously mentioned, it would be worth making sure the actuators are actuating together properly
    • I went down this rabbit hole before, ended up sourcing a motor from the UK (I'm in Japan) which also didn't function correctly. With the original motor, I disassembled it and reassembled it and it works somewhat, sometimes. What I could deduce from all my screwing around is that there is calibration of the gears on the inside of the motor and two ramps on the main gear which activate switches that operate the motor and move the sunroof either to retract into the roof or tilt. Where I got stuck was that, it seemed in my case that one or both of the switches that are activated by the ramp on the gear did not always activate and thus the motor did not move, causing it to sometimes not retract or tilt (apologies, I've forgotten which way it didn't work.).  Of course this part is discontinued at Nissan now, it's the same part in the S15 but no other models. I also contacted the manufacturer of the component for schematics - forgot the name, they're based in Gifu - but they declined to share the information due to being bound by an NDA, sadly. Looking through my pictures now, it seems I last had a crack at this in 2022. See, I so kindly wrote "open" and "close" next to the switches. If you figure it out, please do tell me. Those little switches, with the red buttons may need to be replaced.
    • It says 300ZX, does that make it an Aus delivered car? Funny how back in the day I just couldn't care less about Z32's and these days I am just in love with them. Back when Nissan was into pushing the envelope. 🤣
    • Hi guys, just after some guidance with an R34 sunroof that has stopped working correctly. It still opens and closes perfectly fine, but it no longer tilts/vents up or down. As a result, the rear of the glass now sags a bit as it drops down slightly in order to retract into the roof, but now it can't pop upwards into a flush position. I’ve probed the pins on the back of the switch connector with a multimeter and it seems like both switches (for open/close and tilt/vent) still work correctly. Any ideas on what it could be, or where I should even start in terms of diagnosing? I'm sure someone's had this issue before but I haven't been able to find anything online relating to this specific issue, most of the issues are with the seals leaking or the motor failing entirely. Thanks in advance!
