Good evening talented folk of SAU :)
Recently converted my 32 to a neo engine, but after taking it to the pits one day it suddenly lost all boost.
Still runs fine but can never make it to positive boost.
I've tried looking for leaks and replacing vacuum lines etc with no success.
Today I decided to YOLO it and disconnect the hose running to the wastegate actuator.
Surprise, Surprise she started to boost! Then I quickly took my foot off the loud pedal and went home and connected the hose again.
I'm assuming the spring has shat itself as you can see the arm moving when revving the engine in neutral with no load.
Does this sound like a correct diagnosis? and what are my options?
Can the actuator be repaired or should I hunt down a new one?
Kinda regret throwing the RB20 in scrap metal... Despite having a hole in the block I could of at least stolen the actuator off it to try out :(
Thanks.
edit: engine / turbo is stock rb25det neo gear, sorry if this is in the wrong section. Long time lurker, rare poster :)
Edited by self_slaughter
https://www.sau.com.au/forums/topic/453161-broken-wastegate-actuator/
Options are;
1) 2nd hand RB25 actuator for same same as what you had, with pretty low risk of it also failing.
2) 2nd hand RB20 actuator which would take you to 10 psi which is damn near perfect (for unmodded fuelling & ECU).
3) New higher pressure actuator from someone like Hypergear, but likely that you won't be able to get less than ~14 psi on one of those and therefore need to tune it.
Fixing the broken one is not really a workable/useful option.
  • Like 1
Thanks for the quick replies and good answers, much appreciated. I'll try the hose tomorrow, I think it may of had 2 restrictors in it for some reason. One seemed to be on a bit of an angle so I tried to square it up with a screwdriver but no luck. Will have a better look and see anyway. Still takes a fair bit of effort to pull the actuator manually so you may be right.
Found an rb20 actuator for $50 so I may end up replacing it anyway for the extra bit of boost. :)
Pretty sure it was only getting 5 psi after the swap into the 32.
edit: just thinking, but if that hose was blocked wouldn't it be more inclined to overboost rather then no boost?
Sorry if that sounds dumb but I'm no mechanic and still trying to work things out as I go.
Spent far too much money getting this thing running again as is. Need to learn how to do more myself. ;)
Picked up the rb20 actuator and got some boost back finally :)
Doesn't feel like much though and only registers about half way on the stock boost guage. (nismo cluster)
Do I need to do anything about the stock boost solenoid?
I think that's probably iffy as well as it was only getting 5psi after the conversion on the dyno, unless that was just from the actuator starting to fail
RB25 actuator is 5 psi. You get 7 when the solenoid is switched. So the 5 you were getting was correct and could indicate that the solenoid is crook. Given that you have a 10 psi actuator on there now, you probably don't want the solenoid to add more boost by bleeding, so you're possibly better off bypassing it anyway (if it's working) and if it's not working, you might as well put it in the shed/bin.
  • Like 1
lovin it, thanks for all your help.
I'll rip it out over the weekend. Less crap on top of my engine. Trying to keep it looking as stock as possible to try minimise attention if I ever have to pop the bonnet :)
If running the R32 actuator then bypass the solenoid. It bleeds off from 5 to 7 psi, so is completely pointless being connected.
Make sure you block off the other hose though as if you had installed a boost T.
I'd also say replace the hose with restrictors, no need for that when you have altered the boost yourself.
I am also no mechanic or expert and don't fully know why they are there in the first place.
    • I can see between the water jacket and cyl 3 there wasn't a hard line of combustion gas. It certainly appears that the issue is coming from there. Yes, checked the tension. All at 100ft lbs where I set them 5 years ago. These blocks can crack but generally when they have been over bored. Mine is only 0.5mm oversize at 89.5mm. They break between cylinders around the 91mm mark. No sign of that with mine. My gut feeling is the head gasket lifted a while back when the studs stretched and i bandaided it by retorquing the studs. It's finally let go.
    • My Nismo 1.5 churps a bit on reverse turns when cold, but besides that feels like a stock diff.
    • Yes, but, I paid cash and I'm pretty sure the receipt was in the bin 10 minutes after I got home Note to self, keep all receipts
    • Bunnings would have just handed you your money back on that one!
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
