The most important aspects that the greddy intake kit addresses are the cold side merge before the FMIC, and the tendancy of stock intake (black rubber) to partially collapse and restrict intake.
The intake path is also much smoother for airflow.
Strangely the fixing the merge reduces turbo shuffle but on AFM setups the smoother intake of the hardipe kit has been know to increase it!
If you have a 33 or 34 I would personally recommend keeping the stock airbox, and either modding the stock twin turbo pipe or lashing out on the nismo item.
Intake to airbox can be firmed up be KTS hardpipe kit or one of the reinforced silicon pipes floating around.
For me on my 32, I scored the greddy kit cheap second hand and because I was changing to MAP I could ditch the poxy foam filters for some (larger) quality K&N items.
For the average punter I don't think there's any noticable power/response changes, but intake noise is much more noticeable as is OEM recirc/bov... this is a pro/con depending on your preference.
  • Like 1
  • 3 months later...
Update:
Installed Tomei dumps this week ( Bought HPI dumps but couldn't fit on my R34 Gt-R, 15mm too short, would only fit R32/R33 apparently) and "hi flowed" the twin cats of my Nismo exhaust.
Result:
Couldn't tell that much difference, low to mid range was still laggy like before, not much untill 5k rpm. The pick up might be slightly better but can't say for sure as I've only driven it for a short while.
Best thing gained it now shoots little flames on soft limiter cut. Will be installing intercooler hard pipes next week, hopefully this will make more of a difference.
Update:
Result:
twin cats?
why 2 of them?
I don't want the one I got already lol
who tuned it and what they say it could be
twin cats?
why 2 of them?
Twin cats because it's a Nismo exhaust twin 2.5 inch into 3, still saving up for a bigger exhaust, so this will do for now. Car was previously tuned by JEM and will be on the dyno soon once all the parts are in so hopefully a tune will fix things up a little.
Doubtless been asked and answered but what boost controller do you have. Need to be sure the wastegates are shut unless you need them to be otherwise.
Boost controller are profec B II, not too sure how too adjust it, so gonna leave it to the tuner.
Hpi dumps not fitting is news to me. I bought some that were originally on a 33GTR, bolted straight up to my 34GTR setup (GTX2860's now -5's) no problem.
You sure they didn't try to fit them back to front lol?! as they are different for front and rear.
Shit son, haven't heard from you for a while
  • 3 weeks later...
Bought it from just jap, even they didn't belive me. But putting stock next to HPI and Tomei you can see that HPI was a bit shorter, unsure why, so they happily swap it for me.
  • 1 month later...
Update: Car has been tuned and dynoed.
First run: With only thing changed to the car being tomei dumps and 'high flow' cats. Not much difference at low and high revs, made extra 4 kw at peak, this could be due to change in temp or other variables. But did gain some mid range torque and peak boost happening maybe a bit earlier, nothing spectacular but the dumps and cats did make a small difference.
Second run: Now installed with Nismo hard pipe and Nismo 100mm intercooler, 1000cc injectors, 450L fuel pump. Peak power gained of 17kw to 313kw atw at same 19psi. More power and torque across the rev range, biggest difference is peak boost happens at 4550 rpm instead of 5000 rpm.
Drive: Car definitely feels more more responsive and pulls harder, response is still a bit slow compared to stock turbos but it's much better than before.
Cost: $1000 for every 100rpm of response or $300 for every kw gained, f expensive.
Conclusion: I think we are half way there, next on the list will be bigger exhaust and turbo inlet pipes.
    • Hi, i’m making a rb25det coil loom for Vag short coil. Can anybody tell me which Ecu signal wire belong to coil number 1 and 2,3,4,5,6? The connecting switch in above pic is 8 wire i think white is for +12v and black for earth.
    • Was there ever a model of the Stagea m35 that didnt have a badge on the grill? I thought I saw that somewhere, some aero edition or something? I cant find it again? davemoto
    • Its a 2002 vr-x four VQ25DET, silver. Coil overs, lowered, polished alloys and sport exhaust. Bit of a project, was sitting in a shed for a while but runs and drives great.
    • I wasn’t able to replicate the sound anymore. It was a one time sound so maybe it was just coincidence but it was like small pebbles being dropped in a coke can.   should I try cleaning the MAF? It could be it’s functioning but dirty? I don’t know.
    • Update 4: Hi all. The car drives again! Haven't driven for long, only to store it in the garage again, but the test drive was successful. The coolant and oil leaks seem to be fixed for now. Temps on the engine were also very good, while moving I never even saw 80C water during the approx. 30 minute drive. Ate up all the coolant in the reservoir though so will have to fill that even more when I go to the car next time. One thing that pisses me off is that the RPM gauge is still f**ked, I even resoldered the board twice and used copper paste on the silly screws that are used as connections. Next time I take it out I'll take apart the board and fit new components, I'll see if I can get a replacement IC for it.  I have an appointment set for 22nd of September for the engine tune to 370hp. Alignment also still needs to be done. My hope is that I can get all the legal stuff over with by the end of this season. Anyone of you have advice regarding intercoolers? Currently there is an APEXI core fitted, one of those weird hybrid ones, 600x270x76. I don't think it's bad but it's not new and now I still have the chance to change it now to legally include it in the paperwork. Only issue is that the only options that would arrive in time are a HKS Type R intercooler or generic Ebay spec intercoolers comparable to a JustJap one. Ideally I'd order a Plazmaman but it takes over a month to receive which would mean making the car legal has to wait until next season. Would love to hear some input on this. Same story for my injectors, the previous owner was a nunce and put ID 1050x on the engine. They work but are obviously not ideal at "normal" power levels. But I don't see a reason to change them unless the tuner says it's necessary. I read online before buying a different exhaust that the top secret style rear diffusers won't fit due to the size of the rear resonators. My buddy and I made it work by slightly "adjusting the shape" of the mounting bracket and making some spacers out of 3d print for the mounting bolts. Fits like a charm. Just putting this here in case someone has this problem. Even the hefty HKS Silent Hi Power rear can fits without hitting anything.
