Putting one of these into my S13, but unsure what D Bush to buy. SuperPro has them up to 24mm, but the bar seems to be 25mm (admittedly measured with adjusting shifter with measuring marks, tape backs this up but both could be 1mm out). I've also read some people state t's 26mm. Nolathane lists odd sizes.
Can any shed one some light on this?
Also do I need to use grease on the bushes when installing them? Seems to be a lot o conjecture around this also.
Edited by ActionDan
https://www.sau.com.au/forums/topic/454346-r32-gt-r-rear-swaybar-d-bush-size/
Um, Shirley this is a function of the actual bar that you have in your possession, and not something that anyone else can know?! Buy cheap plastic vernier calipers from Bunnings or Jaycar, measure and revel in your newfound ability to correctly measure this stuff.
As to the lube - any time urethane touches metal, moly grease goes in there.
Are you telling me Nissan just randomly put different sizes rear swaybars in the back of all their cars... surely there's a factory size.
Not grease - special lube.
I have Lithium grease, good enough or is it something more specific and does it normally come with the bushes?
I use moly grease on all urethane bushes. Always have. Always will.
OK, but now you tell us that it's factory. You didn't before. And I'm pretty sure that the factory GTR bar probably isn't that large, although I'm willing to stipulate that it might be. See below for comment on that. The manual GTSt one is ~17 or 18mm or something, the auto GTSt one is only ~13mm. Stiffness goes up with the 4th power of diameter, so 24mm is a hell of a lot stiffer than 18mm, even if comparing hollow with solid.
The heavy duty Whiteline GTR rear bar is 24mm. Not a real big step up from a factory 24mm bar.
Try the Nolathane site again. Do the Make/Model search
You will find rear sway bar mount bushing and it will be an ID of 18mm (part#42478)
The rear sway bar you have is likely aftermarket and requires 24mm.
I'll have to get some moly grease then, I only have generic heavy duty industrial and lithium at home.
The bar is definitely 24mm+ I'll buy some verniers and confirm.
Yeah I found the 18mm one, but this is much larger.
It could be after market but it was sold as having been removed from a 32 GT-R that was being wrecked, the colour/age implies that also. The same smokey black colour as all the others I've seen where as almost every after market bar I've ever seen was anything but black.
The size surprised me too, concerned it's going to be too stiff for a grip setup.
Edited by ActionDan
Just use the lithium grease
Shouldn't use a petroleum based grease on poly - many petroleum greases have moly in them, so I'm surprised that just a "moly" grease would be any good.
Lithium grease is made for situations where petroleum greases are not suitable, so perfect for poly bushes.
Edit: just had a quick search, and it looks like some (maybe most) moly greases are used in a lithium grease base. These would be OK. I know that they used to put moly into petroleum based greases (when I first came across moly greases 20 odd years ago) so guessed that this was still the case.
Just make sure that whatever grease you use has a lithium base and all should be good.
Edited by warps
Define "too wide". As in "too wide such that if I cut some off it it would be fine"?
FWIW, when I put the 24mm bar on the front of my R32, I spent about a half hour going back and forth between the car and the pedestal buff removing material from the outside of the bracket bushes so that they would fit inside the brackets.
    • Nope.    Grab a varex and turn it down as you get close to home, win win?
    • So, I've had my V36 for about a month now and have already copped an "excessive exhaust noise" notification from QLD TMR, reported by someone in my local area. It's a twin as per the original, and can have a bit of a throaty note to it when idling cold 😄 and if I do get up it a bit, it can be noisy, but it did pass a roadworthy inspection before sale, so.... ... but in the interest of being a good neighbour, I do want to quieten it down a bit. Is anyone here running a quiet aftermarket cat-back on their V36 or 370Z? And the big, bold question: does an aftermarket cat-back really make much of a performance difference on these cars?
    • The wiring diagram for the R33 RB25 is freely available, and is essentially the same same as most other RBs (just with differences as to which pin # does which job). To get the ECU to power up, you just need to provide power to the ECCS relay, and have the other power feeds that come in from the top left of the wiring diagram (wrt the ECU) that give perma power to the fuel pump relay, the ECU itself, etc etc, all connected. When you put power on all these it will just come to life. It's pretty clear from the diagram what needs to happen. Just follow the lines from the 12V + supply stuff in the top left over towards the ECU. I've even posted snips of such diagrams (not for vanilla 25, I think for Neo and 26) to various threads here in the last few months, talking about what it takes to get the fuel pump and FPCM up and going. Search these up and they will help get you started on doing the same with the vanilla 25 diagram. Hell, for all I know, I've done the same with that one in years past and have forgotten.
    • Yep...so unless someone posts up the answer you will need to probe from the ECU connector to the dash plug with a multi meter in continuity mode to trace the wires.  Note the ECU has multiple - and + (and across different key settings - Battery, IGN and Start) and most likely the power is fed from the connector(s) that is normally near the left hand headlight.
    • Thanks Duncan, I am actually just trying to get the Rb turning and running with the RB25DET S2 original loom itself  I am just trying to get it going outside the body and not thinking about the S15 or trying to match anything to the S15 loom at all I am only trying to see if anyone has done this and what pin they found to be the ignition trigger and ECU+/- on the dash connector, that's about it. Thanks
