Car Trouble Bnr32 1990
Attached is the Nistune Log fresh this morning along with the items that the dealer have changed. My Car studder and shivers between 1k-2k rpm no matter what gear it is. The problem partially went away after they changed the items like gasket , maf,o2 sensor, and seals. But it still happens and I cant pinpoint the problem, last time the car was serviced it took them two weeks before getting my car back. It is my daily and I cant really afford that long down time >_< . This just happens in that rpm range >_< usually happens when the car is cold and even when the operating temp is reach it still happens , but not as much.
sorry i guess the board dont like csv files and put it on mega.
https://mega.co.nz/#!SBklkCzb!ow2js3z8UwZTcmoz1LaLRC1dstauRNDMWzZxWqqee-E
Get a good ECU for starters for a GTR.
Could be AFM's or harness.
new AFMs , ECU dont matter when it is in stock tune and the previous ECU is a chipped tune.
What spark plugs brand, heat range and gap are being run?
Have the coil packs been checked?
oem plugs , nissan dealer checked the coils.
Is this just in gear ?
could be looking at a drive train issue.
its in gear, why would it be drive train ? it happens at a specific part of the revs. I can rev the engine in Neutral up to 5k drop it in gear and it would still sputter back down to 1-2k
ill check and borrow one of the guys coils here and see if that fix the problem
shivering under 2k in gear i was thinking possible clutch shuddering, still sounds like a coilpack "type" issue.
mine did this and while I was changing plugs and pissing off the 32 carbon tips on the coil spring I found both my black earth wires had been pinched and atleast half the wires had been severed (bad earth = weak spark) possibly got caught in the back of the coil cover. new coil pack harness for about 100 bucks is a good idea anyway as the original has been cooked to death.
yup, there is a trader on here somewhere who sells them.
just work your way back
copper plugs, correct head and gap
coil packs (there just old and should be replaced if not done so far)
coilpack loom, as stated.... cooked.
ignitor, also just old
just do the basics man, as you will have the sparkplugs out, do a simple compression test,
pull off rubber (usually crispy by now) vac hoses and check for cracks leaks,
check your fuel filter ect
so many threds on this kinda stuff..
i know your mechanic has checked them but really man there is only so much you can just check without replacing anyway.
  • Like 1
 Share
    • The stock one will outperform any aftermarket standard position exhaust manifold. If you don't believe me, do a back to back test (same turbo, same boost, same timing) and you'll be super surprised.
    • Any recommendations on a decent replacement manifold that doesnt break the bank or require additional mods for the stock turbo setup? I figure if I'm going to pull the manifold off anyway to fix the studs might as well replace it.
    • So I checked the turbo out today. Very minimum play at all just enough for the oil to take up when it's running. I did find an exhaust leak at the manifold. 1 stud all the way in the front is missing and the one all the way in the back is broken off. Front has visible signs of an exhaust leak. I'll fix that soon but that's not my problem still.  I also found that the nipple coming off the turbo had the hose capped off and a hose ran from the j-pipe by the bov going to the wastegate. I removed that hose and capped that nipple and put the turbo nipple hose back on the wastegate.  There was a ton of oil residue all through the charge side of the intercooler piping going to the throttle bodg. I'm thinking that's from the pcv. Doesn't seem to be coming from the turbo that was all clean on the pipes side.  Haven't had a chance to check fuel pressure yet, haven't had time been having to pull a lot of doubles at work. I did pick up some carb cleaner to clean the iacv but wanted to make sure I had a fresh gasket in case the old one rips when I pull it off.  I'm waiting on a MAF that was supposed to be here today but delayed to Monday. Have a double Monday and Friday and work all of next weekend so going to try to find some time in the middle of the week to try that out. Did about a 10m trip around the block today and towards the end the issues were coming back. Fingers crossed on this MAF but if not just going to throw a fuel pressure gauge in and see where I'm at.  Did notice today that I can definitely hear the injectors pulsing. Very audible clicking coming from them. Assuming that's normal? Should also mean CAS is functioning somewhat properly. After it warmed up when I started it the intermittent misfires came in again. Did start doing that before it was fully warmed up.
    • This morning I carefully reinstalled the manifold and started looking at a couple of things I need to do.  Heat wrap arrived sometime today so I popped into the shed with the missus dishwashing gloves and started wrapping the first half of the dump and the screamer/plumb back.  Once I do the second half I'll be able to final fit the turbo and exhaust up.  Also pulled the harness out today and started terminating it at the ECU end. A connector is done, just need to run the remaining wires that arent in the harness - 12v, gnd and couple I/O
    • A31 is pretty much the same thing without HiAIDS I mean CAS, no improvement lol. Not to late to send it.
