NEW SUPER RARE ARC Swirl Pot BNR32/ BCNR33/ BNR34 $1575
NEW 86.5 CP Pistons $950
86mm Aries Pistons Including Rings (Used less than 10,000km) $600
Eagle RB26dett Rods (Used less than 10,000km) $400
NEW HKS Oil Cap $235 (2 off) (The type you got when you bought a stroker kit)
NEW OEM RB26dett Coil Pack Loom $115
NEW Greddy/Trust RB26dett Extended Sump $450
R34 GTR RB26dett Ceramic Coated Dump Pipes $250
ID2000 Injectors (Used less than 5,000km) $900
HKF FCON V PRO ECU to suit BNR34 $800 (Used but in VGC)
R34 GTR Engine Under tray $450 (Used but in VGC)
R34 GTR Steering Wheel including Airbag $600 (VGC)
Adjustable RB20/25/26 Cam Gears (Anodised Blue or Gold) $100
Toshiba R34 GTR MFD Screen $220
Aftermarket Fuel Reg $150
Nismo R1 Turbo Kit $1,800 (Used less than 10,000km)
ARC Diffuser Panel (Titanium) $650 (Used but in VGC)
For pics text me on 0422 289 568
Edited by GTR600
It connects to your radiator and seperates the mixtures of air. I just sold one last week. I have pictures I could post if it would help also. Very rare piece. Comes with two tanks, two caps and all hoses, claps etc..
Please call me about the R34 gtr steering wheel. I tried calling you. I can't receive text messages. So please call 0411171616.
Thanks
Justin
BUMP
Adjustable RB20/25/26 Cam Gears (Anodised Gold) $100
Also now have a used JUN oil Pump $900 ono
ALSO please only comment if your interested in buying.
If you have any issue about pricing, my number is above, we can discuss.
  • 3 weeks later...
UPDATED LIST:
NEW PARTS
NEW SUPER RARE ARC Swirl Pot BNR32⁄ BCNR33⁄ BNR34 $1,575 http://www.nengun.com/arc/air-removal-tank-normal-set
NEW Nismo Rb26 Engine Mounts $200
NEW HKS Oil Cap $235 (2 off) (Stroker RB26 kit oil cap) Very Rare item https://www.hks-power.co.jp/usa/images/Pid=2390.html
USED PARTS
R34 GTR⁄GTT Crank Angle Sensor $250
RB26dett Head $650
Adjustable RB20⁄25⁄26 Cam Gears (Anodised Gold) $100
Jun Oil Pump Used $850
R32 GTR Rear Diff Housing (2 type of rear covers) $100
R32⁄3 GTR Front Diff $200
R32 GTR Front Sway Bar $20
R33 GTR Front Sway Bar $20
R33 GTR ABS Pump $100
R33 GTR A⁄C Evaporator $100
R34 GTR Sump Complete with Diffs $300
R33 GTR 4wd Pumps & Boot Tank $100 each
R33 GTR V Spec Rear Driveshaft’s $100
R33 GTR Front Strut Brace $40
R33 GTR Front Steering Rack $175
R33 GTR Brake Booster $30
Rb26dett Water Pumps (used) $20
Rb26dett Manifolds $20
RB26dettEngine Mounts $20
Rb26dett Throttle Bodies $100
Heaps of other parts available 0422 289 568
Strictly no time wasters, inquire only if and when your ready to inspect/purchase.
Edited by GTR600
Money deposited for the Jun oil pump on friday arvo..........thanks Chris.
Hopefully will get it later next week???
Money Received mate thanks.
Boxed and will be sent Monday. Thanks mate
UPDATED LIST:
NEW PARTS
NEW SUPER RARE ARC Swirl Pot BNR32⁄ BCNR33⁄ BNR34 $1,575 http://www.nengun.co...tank-normal-set
NEW HKS Oil Cap $235 (2 off) (Stroker RB26 kit oil cap) Very Rare item https://www.hks-powe...s/Pid=2390.html
USED PARTS
RB26dett Head $650
  • Like 1
    • The front prop shaft from my GTR had very notchy unis, which obviously needed replacement but unfortunately uses the (usually) non-replaceable (staked) type.     A new shaft is something like $2K plus shipping from Japan.   I wouldn't even bother asking the local Nissan spares dept.     Rang Hardy Spicer but no go, which surprised me a little.     There's a place over Dandenong way that would make me a 'performance' shaft but un-necessary in my situation.   They claimed to be getting the equipment in to replace staked unis but couldn't give me a timeframe.   Anyway, long story short, found a place to do the work just 5 mins from me: https://knoxdriveshafts.com.au $420 (cash) and about a week later I have my driveshaft back.   Price includes balancing. Owner is a one man band working out of a shed in his backyard but from what I could see he's very well setup with some expensive equipment.
    • Thanks. That's what I was after. One of the kits, the o-ring side is too big diameter. The other kit is a plate with a o-ring to seal and the hose connection offset.
    • oops that seems much easier lol.
    • Are you using the factory rail?  Is there any reason you don't want to use one of the two you already have, they don't have to attach to the fuel rail directly.  If you 100% must have a FPR that directly bolts to the fuel rail, you could get a Radium setup. I use a radium fuel rail and the direct mount regulator, it is quite a sexy setup.
    • https://www.google.com/search?q=adjustable+fuel+pressure+regulator+nissan+fuel+rail+adapter&sca_esv=6710113de42d5150&source=hp&ei=GhPbaNHfNZeinesPyPqEiQc&iflsig=AOw8s4IAAAAAaNshKnLkjQGMWYT5EyclmXEJm8ZXSWDb&ved=0ahUKEwjR1JOCjf-PAxUXUWcHHUg9IXEQ4dUDCCE&uact=5&oq=adjustable+fuel+pressure+regulator+nissan+fuel+rail+adapter&gs_lp=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_EFhqEHecdnjv2SBwYyLjU1LjGgB7XnArIHBjAuNTUuMbgH4UXCBwgwLjUuNTEuMsgHiQI&sclient=gws-wiz
