I thought this might be the best place to ask this...
looking quite seriously at getting some sort of hydraulic kit installed in the R, but the options available are quite $$.
KW have their "HLS" system; theirs is a universal kit but it's almost as much as buying a full set of their coilovers with the HLS already included it seems.
JRi shocks do some, but you have to get their suspension, no universal kits.
The one i'm looking at the closest is http://www.ramliftpro.com/index.html, universal kit and the cheapest option (but still not that cheap).
So my question to the SAU community is how hard does it look to fab something like this up? Anyone interested in developing a kit? Local options are always nice and if done properly can obviously be used for almost any coilover application, so it won't be a "Skyline" thing.
It doesn't "seem" that complicated from the pictures, but then again i have no technical background in this area so could be way off the mark about it's ability to be developed locally.
thanks all.
https://www.sau.com.au/forums/topic/454695-hydraulic-lift-kits-for-coilovers/
*not sure if srs*
do you think it's possible Scotty? all i know is that if i want to change the ride height, i have to (or more accurately, get someone to) loosen this metal sheath thing on the shock and manually screw it down or up. I'm thinking that it has to be screwed up and down and could that be controlled by the Attessa pump? would it have enough power to handle the job?
aware this could be some very newb comments
As the entire suspension geometry changes with the height adjustment, I would say not to bother, as it will upset the way the car drives having variable height coilovers.
There are adjustable height setups out there, but nothing that screws on to standard coilovers that I know of.
Lowering the car so the driveshaft is past level when the car is on the ground will ruin the handling. If you like the tucked wheel look just get oversized tyres to fill the guards.
KW make a universal kit, this ramliftpro mob have their kit and JRi have a full setup, which i don't want.
It would ONLY be used for clearance situations, ie, driveways, car parks etc. Once on road, it will return to the normal heigh and geometry setup.
So it's more to allow me to setup the car as best as possible, not necessarily worrying about legalities of height, and raise when the time requires, ie purely very low speed manoeuvring and times when it needs to go to a workshop (to help with getting it on a hoist, Trent's dyno etc).
If your looking at air bags try the mob below, ive got one of their kits in the back of my ute, flick of a switch to raise or lower as needed, aircompressor pump and tank is under the vehicle....
http://www.airide.com.au/main.php
They do air struts, i will be adding them to the front of mine next time i need to change the shockers.
This would be a great thing if we could make up a locally manufactured option.
I have had the Aragosta "Roberuta" Cup Kit on my wish list forever.
But it is really hard to justify at that price.
http://www.nengun.com/aragosta/aragosta-cup
Many forget that there is a minimum ride height requirement and that is the minimum clearance under the vehicle.
This is measured without any bag inflation, in other words if you have an air system failure your car can still pass the minimum height requirement under the Law - what this means in reality is you car will be illegal and potentially unsafe if bagged. Sorry guys but I simply do not see the point as it has no mechanical or handling advantage on the highway because you alignment and other suspension parameter's will be way off optimal by dropping the car.
There are vehicles around here that have bags and one blocked the main street a while ago as it's air system failed and thus dropped on it's belly in the middle of the street, HOW it passed the regular machinery inspection I have no idea.
Now you mention hydraulic lift kit ?? so you can raise the car when needed or what , just trying to get an idea of what and why (Old fart here trying to understand the younger generation)
Edited by MozzMann
Hey MozzMann
this is nothing to do with lowering the car and noting to do with air bag suspension.
Its all about raising the front suspension to allow extra clearance for driveways, speed bumps etc.
In non-activated state the car will be at its regular ride hight
yeah, purely would be installed for clearance situations ONLY, otherwise it would return to the height where the geometry had been set.
as for air, i was under the impression that hydraulic in a performance setting is more favourable to air, less chance of variation?
plus, this ram lift kit appears to be a retro fit option as well, so i can maintain my current setup (although spring change is a possibility it seems).
i'm sure someone has the skills locally, whether or not it's worth their time and effort though...
thanks for the replies!
isn't it argued that our cars are unsafe if we run a FMIC and a POD filter ?
but yes air bags can be engineered and mod plated
on a similar topic, does anyone know if coilover sturts can be modified to insert longer stroke shocks?
Edited by Dan_J
incorrect. Airbags, laying frame, pinch, door are legal. And you can't put one persons cheap arbags and or lines etc into the same basket as someone who has done it correctly with quality gear that lasts and is regularly checked for splits kinks etc
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
