Will need to be repaired and blue slipped to get off written off register I believe??
I had a car written off and paid out 3500 but only cost 400 to buy it back... Might be worth it depending on repair costs.
first quote was 7600 :/ reason why im so concerned about this is because ive just put about 7k into the motor
What do you reckon they will say dale? I still have to get one more quote an see what happens. Has anyone ever fought a insurance company in regards to writing a car off due to hail? Because by the look ofthe first quote im going to be right on the boarder line of being written off.
I'm betting that they'll write it off; it's only insured for $4k, and this is the last year we were going to fully comp insure it.
Because it's with Shannon's; I'm hoping that they'll pay it out, let me retain the "wreck" and then simply restrict us to 3rd party property insurance in future.
Could always buy it back? Not sure on how that process works though
With Shannon's I have first refusal for the wreck; but my repairer reckons that they'll probably just let me have it with a slightly reduced payout, to account for the buy back value.
Just read through it. Yeah i can buy the car back for salvage and have first pick. Still dont know what % of value they work off though
They'll have it valued for auction, when I bought mine the valuer told me what he was going to tell the insurance company it was worth (sneakily) and they offered the same price to me.. ie no mark up
Yes, it's insured (as a Genki) for $17,400, so the damage doesn't come into the 80 percentile whereby it could become a write-off.
Volvo XC T6 - $3,400 for PDR only.
* Note that after the panels are all smooth again...
a) all dented mouldings are mandatory replacement items so that no water can enter any crevices
* But...
b) any scratches created by the hail are not covered and thus; no polishing is included in a hail claim
* After I get the cars back, we'll have to see about that! I shall need proper lighting to reflect and refract any scratches, because unless the paint is in its former condition, I believe that according to the PDS, I have a case for complaint.
I'm not surprised by the damage to the Mazda Terry; it's comparable to the last time Shell's car was damaged by similar sized hail.
Interesting how much less pdr is required on the XC60; clearly a lot more high tensile steel panelwork on it.
I agree regarding scratches from hail; the car MUST be returned to it's pre-hail damaged condition, for the repairs to be considered complete.
If the roof required replacement; they couldn't just hand it back in guide coat.
Hope you have a good outcome Adrian!
Still waiting for am answer on ours, Shannon's rang yesterday to ask when the car was going to be presented for assessment; it's already been viewed and photographed, our repairer had obviously neglected to submit his quote.
I'm wondering whether he is the right man for the job...
    • I don't know it is due to that. It could just be due to load on track being more than a dyno. But it would be nice to rule it out. We're talking a fraction of a second of pulling ~1 degree of timing. So it's not a lot, but I'd rather it be 0... Thicker oil isn't really a "bandaid" if it's oil that is going to run at 125C, is it? It will be thicker at 100 and thus at 125, where the 40 weight may not be as thick as one may like for that use. I already have a big pump that has been ported. They (They in this instance being the guy that built my heads) port them so they flow more at lower RPM but have a bypass spring that I believe is ~70psi. I have seen 70psi of oil pressure up top in the past, before I knew I had this leak. I have a 25 row oil cooler that takes up all the space in the driver side guard. It is interesting that GM themselves recommend 0-30 oil for their Vette applications. Unless you take it to the track where the official word is to put 20-50w oil in there, then take that back out after your track day is done and return to 0-30.
    • Nice, looks great. Nice work getting the factory parts also. Never know when you'll need them.
    • Thanks @jtha7 I will have a look around tomorrow but it is a prick of a spot. These are some photos i tried taking
    • I take it that the knock retard is from bearings tapping a little tune? Thicker oil is a fragile bandaid. You need a much bigger oil cooler and probably the bigger pump being discussed.
    • Hi @Chupapy i had several leaks from coolant pipes being corroded, i also had one leak on back of the head onto transmission. For me that leak was from the turbo water line. Follow the line to the back of the head The hose and metal pipe had perished these are the best pics I took of it at the time
