Zen guy watermarks as 300CP. Sure he'll post up some cracker shots like he did last time.
yup. He's taken our shots at wtac show n shine as well as a previous texi. Pretty nice shots too :)
https://www.facebook.com/300CPO
Hi All,
Zen Guy here, AKA 300C-PO, AKA Sam.
Few of my favourite shots from the day here. Full set up on Facebook
11080707_623895884407823_763887021309284
11080313_623896977741047_627134589739496
11080630_623897314407680_221666135607984
10537487_623897457740999_798070584354444
Thanks for the pics! Like your page and got them already! Used one of your pics for my FB cover photo! hahah
