sorry to bring up this thread again however i have recently found out about mambatek turbos, they seem to be of the same quality of kando turbos and the same price range except ball bearing :D and have been looking at this turbo in particular:
http://www.ebay.com.au/itm/MAMBA-GTX-Ball-Bearing-Turbocharger-GTX3063R-Nissan-Skyline-GTR-R31-RB20DET-300P-/181736850896?pt=LH_DefaultDomain_15&hash=item2a505c45d0
not knowing much about turbos myself would someone please tell me how this would work out on an rb20 lag/power wise? would be a great help if possible thanks
it is tempting and seems good value for money, i was going to get a kinugawa td05 18g 8cm before i found this
specs td05:
Compressor wheel: 50.5/68 mm
Turbine wheel: 49.2 / 56 mm
8cm housing
journal bearing
specs gtx3063r
Comp. Wheel : 47.1 mm / 63 mm/Trim 56 (11+0 GTX Billet Wheel w/ Extend Tip)
Turbine Wheel : 52 mm / 56.5 mm / Trim 84
ceramic dual ball bearing
10cm housing
This is the cropped GT30 turbine wheel not the real gt30 one.
It may perform anyway as the compressors is not that big.
I have the kinugawa version with much bigger turbine (garrett stage 3 wheel which is 65mm at the inducer), and a 20g compressor (52.5/68mm wheel).
With an EBC in good working order I was able to get 19 psi/1.3b at 4000rpm, without EBC I only get 14psi/0.9b at the same rpm and the engine doesn't relly wake up before 3500/3800rpm with a front facing plenum.
It was able to give 198rwkw/320 Nm at this boost through a standard S13 airbox and paper filter in it, FMIC, front facing plenum and 3 inch turboback.
This mambatek will spool fairly quicker maybe not as quick as you'd want, power wise I've no ideas but it will be able to break the 250 rwkw I guess.
In the same range of size sonic performance offers bolt-ons solutions based on the GT2860RS and GTX2860/2863/2867 but it ain't cheap.
too much hassle to get an adaptor and custom dump honestly, i've seen the range sonic performance offers and its probably a bit too much for me price wise, R_34 is your rear housing a 10cm or 8cm?
i can deal with it being at full boost by 3500, put a boost guage in recently and turns out my rb25 turbo is hitting 12psi by about 3400 and 7 at 2800 so that was a bad call on my part, sounds interesting, need some supporting mods before i get my turbo anyway so if i havnt gotten a turbo before 6 months i'll have a look at that too, the only thing putting me off this mamba turbo is the 10cm turbine housing
and what does your 25 turbo do at 6000, is it still holding 12psi?
My SS2.5 hyflow makes positive boost @ 2.8K and 20psi @ 3.8 and keeps it to 7500rpm
Not sure what kilowatts it make as I tune it myself
all my passengers have a big grin @ 4000
Mine is a 10cm², and it holds boost perfectly all the way to the rev limiter à 8200rpm when I was running 19psi.
I backed off because of the EBC and the gearbox which didn't liked the "high" boost.
Positive pressure begin in the low 2K but the turbo is lazy to gain boost and doesn't hit 0.5b before 3000 rpm with the ebc and 3500 without.
going by what you're saying the mamba turbo should spool faster than your kinugawa turbo with the smaller wheels and being ball bearing, if the housings are the same size it shouldnt be a problem for me then
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
    • Literally looks like direct port nitrous haha
