I came in here expecting lots of angst n sh!t. Instead it's all sorta - well civilised - until now. I wonder how many simply vote the way their parents have. Or how many girls upon marrying, then vote the way their husbands do? Do most Catholics still vote Labor? Do most Protestants still vote Liberal? Do most Army guys still vote Labor? Do most RAAF guys still vote Liberal? Do most teachers still vote Labor? And if you vote against the tide of any stereotype do you just stay quiet? Just throwing in some questions to fuel the fire! BTW, I was teaching a group the other day on "How to run a chook raffle" and all the attendees during coffee break loved talking about their beloved Labor Party. Actually I lie. Just more fuel for the fire. But because I could tell a ball-faced lie and not hesitate, perhaps I should take up politics? Rofl
Its a never ending cycle. The Liberals bank all the money and then labor come along and spend it all. Unfortunately they spent so much last time they were in it will take about 30 years to pay the debt off if ever.
  • Like 1
this, Rudd made an absolute mess of our finances and to make it worse australia was revesion proof before he handed all the money out
  • Like 2
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
